Quote from obarthelemy on September 29, 2011, 15:51
This semi-recent linux torrent clients comparison is interesting:
http://pastehtml.com/view/5tx16jw.html
- Actual download performance is pretty much the same for all. The test covers single-torrent leeching, not seeding nor multi-torrent, but extrapolating should be valid.
- Memory usage varies widely. transmission is very good, rtorrent and qbit are OK (rtorrent figures are misleading because it uses the OS'cache, not its own), uTorrent is bad (you have to add Wine and x11)
- CPU usage: same as above
Other test (sorry, no source):
My take is: use transmission unless it misses features you need.
+1 for transmission !
For my "seedbox" under Debian Lenny without X
I run the web app torrentflux-b4rt to manage my torrents, with transmission client, I think that Rasberry Pi can run it without problem !
