Imperf3kt
Re: Fixing the Pi 4 usb C issue by hand
Thu Nov 14, 2019 1:24 pm
procount wrote:
Thu Nov 14, 2019 11:01 am
Or maybe just add 2 back to back adaptors:
Usb-c/micro-usb -> micro-usb/usb-c.?
I can confirm that USB-C cables do not appear to work when used like that.
(I've tried)
55:55:44:44:4C
52:4C:52:42:41
procount
Thu Nov 14, 2019 2:49 pm
Thanks for confirming it doesn't work. It was a suggestion someone made to me.
I guess it depends on whether the USB-C/micro adaptor contains the necessary cc resistors for power delivery. Often they don't say.
emma1997
Thu Nov 14, 2019 3:31 pm
hippy wrote:
Thu Nov 14, 2019 11:00 am
I doubt any company would create an adaptor for commercial sale as it would probably be too costly given the small market for such a board
What do you mean 'small market'? There have to be at least 3 individuals here in the US alone desperate for such a solution. Considering design and tooling should be able to produce such an item for as little as $200-$300 per. lol
I think there was a Shakespeare play on the subject: Much Ado About Nothing?
Imperf3kt
Fri Nov 15, 2019 12:41 am
Stopping and thinking about it for a moment, a smart charger is supposed to default to just supplying 5v if it's plugged into a non smart device. At least, it does with micro USB.
What would happen if someone was to take a USB-C cable and only connect the vcc and GND wires into the Pi with something like this?
https://core-electronics.com.au/micro-u ... -pi-4.html
55:55:44:44:4C
52:4C:52:42:41
supersjimmie
Fri Nov 15, 2019 7:32 am
What I meant with the usb-c male/female could also be done with something like this:
https://www.aliexpress.com/item/33005988619.html
Then do exactly the same with adding one 5.1k resistor on te same pin.
That should work?
Or easier to compose, but less pretty:
https://www.aliexpress.com/item/4000026719770.html
clicky
Fri Nov 15, 2019 8:19 am
Brilliant! :D
HawaiianPi
Fri Nov 15, 2019 8:35 am
supersjimmie wrote:
Thu Nov 14, 2019 9:30 am
Instead of having to modify the rPI4 board, would it be possible to add the 5.1k resistor inbetween a male/female usb-c connector?
That way we can have just a small converter-cable with the resistor instead of the risk of ruining the rpi4 board.
Power adapter USB-C -> diy USB-C [male] -> diy cable with resistor -> USB-C [female] -> RPi4
Sure, that would probably work, assuming you made the correct connections, but I've got as even easier and less risky solution...
Just buy the official power supply. :roll:
davidcoton
Fri Nov 15, 2019 9:57 am
Somewhere here there is a thread that discussed how to modify a cable. Remember it has to work with both orientations of the plug. IIRC a one-resistor modification in the Pi end plug would work. Of course, the cable/adaptor is now useless for anything else. If you really need to use a smart charger, the mod to the Pi itself is as easy (not that easy, but within the scope of a competent amateur solderer) and saves having to buy extra kit (extra power connectors are in themselves a Bad Thing ™). If you don't want to modify your Pi, Just buy the official power supply.
Signature retired
supersjimmie
Fri Nov 15, 2019 10:00 am
Sure, but that won't answer the title of this discussion.
Fri Nov 15, 2019 10:12 am
No, but it will be cheaper.
HawaiianPi
Fri Nov 15, 2019 10:22 am
Already been answered. Was there some other answer you were looking for?
procount
Thu Dec 26, 2019 5:43 pm
(I've tried)
@imperf3kt - Despite your experience, I decided to buy a pair of USB-C socket to micro-USB plug adaptors and tried one with my microUSB socket to usb-C adaptor. I chose these Arktek one's from Amazon (https://www.amazon.co.uk/ARKTEK-female- ... B071W8WQBD)
One of the adaptors was faulty, and wouldn't even work as a MicroUSB charger.
However, the other one worked fine back-to-back and allowed a USB-C PD charger to power my PI4.
So, it seems it would depend on the characteristics of the adaptor you use and specifically whether it includes the 2 CC resistors to tell the PD charger to deliver power.
Imperf3kt
Thu Dec 26, 2019 10:02 pm
Nice to know.
I would mention the adaptor I have appears to includes some electronics.
This is the exact one I purchased.
https://www.bunnings.com.au/antsig-usb- ... k_p4360482
55:55:44:44:4C
52:4C:52:42:41
