torak666
Re: Raspberry Pi 4 usb boot?
Wed Oct 30, 2019 5:36 pm
Just tell me what i did wrong on this?
Initial cmdline.txt
console=tty1 root=PARTUUID=5e3da3da-02 rootfstype=ext4
5e3da3da-02 my SD CARD right?
modified for SSD:
console=tty1 root=PARTUUID=9ec0e712-02 rootfstype=ext4
9ec0e712-02 my SSD partition ROOT is ok?
Then:
/etc/fstab the PARTUUID of the rootfs = 9ec0e712-02
Then reboot and os should be start right?
For me the Os is not starting, i have only display of the 3 Raspberries
Regards
RonR
Wed Oct 30, 2019 5:49 pm
What is on the SSD and how did you put it there?
dickon
Wed Oct 30, 2019 5:50 pm
If that's the entirety of your cmdline.txt, you should see a lot more than just three(!) raspberries. I'd expect four raspberries, and a few screenfuls of text showing the boot process.
ejolson
If only three processors are online, you may have hardware problems.
Could you please check whether three or four Raspberries are displaying?
torak666
Wed Oct 30, 2019 6:30 pm
hum sorry, since i have modified the file /etc/fstab the boot is not working i start in shell but i cannot modify the /etc/fstab file it is in read only, certainly forced read only because the pi boot with this file. I have no linux on my main computer to modify the file in SD card
i have to reinstall again raspbian buster i will make screenshoot. And my try to install raspbian buster with NOOBS on the SSD fails, the OS doesn't want starting.
dickon
Wed Oct 30, 2019 6:48 pm
You should be able to edit cmdline.txt in any random PC text editor, line endings notwithstanding. Add 'init=/bin/bash' to the end of it and boot, and you should end up at a root prompt. If you have 'quiet' in there anywhere, remove it. That should get you a lot of boot log output, which should help identify the problem.
'quiet' is another abomination that shouldn't be anywhere near working operating systems, if you ask me[0]. Fine for the likes of LibreELEC and OpenWRT, but for general use, it hasn't any business being on a commandline, as it hides far, far too much useful information without which debugging issues like this becomes impossible.
[0] You didn't. I appreciate that. Tough.
RonR
Wed Oct 30, 2019 7:06 pm
After you get Raspbian running on an SD card, simply run usb-boot, selecting copy the SD card to the USB device. When you reboot, you will be up and running on the SSD. No manual configuration necessary.
torak666
Wed Oct 30, 2019 7:23 pm
I have to copy PARTUUID = 4ea876e6-02 and replace in /etc/fstab and in cmdline.txt then reboot and that's all no?
The SSD content is copy of rasbian buster by software SD Card Copier, i said that few replies before page 15.
Ok finally it works fine with the script boot.
I see all PARTUUID are the same modification i done my self in fstab and cmdline.
The problem should be on SD CARD Copier or there is an other modification i had not done and the script do this.
I thinks i won't sleep less stupid tonight.
RossDv8
Wed Oct 30, 2019 10:56 pm
It sounds like the updated usb-boot script would have saved me some editing.
And it should prevent the 'I edited stuff but it still won't boot' problems :D
Remember, nobody is listening to you
until you fart ...
LTolledo
Thu Oct 31, 2019 10:17 am
Hey!
Glad you two finally achieved your "interim goal" without further "pain" and "frustrations"... :D
our thanks to RonR for lovingly maintaining and updating the script....
....and of course ..... lets be a little more patient until the procedure for the "ultimate goal" is available....in due time..... ;)
Some people be like:
Thu Oct 31, 2019 10:57 am
Hey!
Bootloader guy is now working fully on USB boot. No timescales as yet.
rpdom
Thu Oct 31, 2019 11:21 am
Good to hear. I'll be glad when I can get my Pi 4B4 booting from its SSD :)
But I'm prepared to wait.
LTolledo
Thu Oct 31, 2019 11:52 am
jamesh wrote: Bootloader guy is now working fully on USB boot. No timescales as yet.
Great news! :o
Thanks! (and most specially to the Bootloader guy/team) :D
me in no rush too.... :mrgreen:
all systems running fine at the moment.... ;)
RossDv8
Wed Nov 06, 2019 1:17 am
After my experience when I changed to the bootable SSD on my Pi 3B+, I think the only real advantage I will have when this facility is added to the Pi 4, is that loading pictures from my digital camera will not tie up a USB 3 port :-)
It is great that the Raspberry Pi is so flexible and the team so dedicated.
I haven't turned on another of my computers for two weeks now other than to print something, or simply to boot one of the computers, any of which performs an auto clean of my inkjet printers on boot.
On the odd occasions when I had another computer running, I am surprised by how sluggish the more powerful computers are compared with the Pi 4, when doing the mundane tasks like browsing or word processing now that the Pi 4 is running on SSD.
I understand that the boot system differs from that in the Pi 3B+.
Is it likely that the behaviour will end up being similar to that of the Pi 3B+? Once SSD boot is enabled, if the Pi detects a bootable microSD, it will default to booting from that, but of there is a non-bootable microSD, it will just mount it as storage?
until you fart ...
rpdom
Wed Nov 06, 2019 9:37 am
As the Pi 4B has an eeprom with the initial bootcode in, I suspect at some point the boot order will be configurable.
Gavinmc42
Thu Nov 07, 2019 2:09 am
That would be nice, the uSD timeout adds seconds when booting from USB.
Is that also going to be an option for netbooting?
I'm dancing on Rainbows.
andrum99
Thu Nov 07, 2019 2:37 am
The boot order is already configurable, for the beta bootloader with netboot built in:
BOOT_ORDER=0x21
will try SD card first, then netboot. Whereas:
BOOT_ORDER=0x12
Will try netboot, then SD card. Alternatively:
BOOT_ORDER=0x1
will try SD card only. And:
BOOT_ORDER=0x2
will try netboot only.
There's also SD_BOOT_MAX_RETRIES and NET_BOOT_MAX_RETRIES to configure things.
See https://github.com/raspberrypi/rpi-eepr ... ot_beta.md
Presumably when USB boot arrives it will be 0x4, but that's just a guess.
andrum99
Thu Nov 07, 2019 2:43 am
I'm now picturing someone with "bootloader guy" on their T-shirt :D
I may have taken that too far.
Gavinmc42
Thu Nov 07, 2019 2:59 am
Depends on how long he takes ;)
Could be free beers or boos if he shows up wearing that T shirt :lol:
Sounds like netbooting is now worth playing around with, had not been paying enough attention.
andrum99
Fri Nov 08, 2019 11:37 am
It's only available on the beta firmware - see the above linked github repo for details.
Gavinmc42
Sat Nov 09, 2019 1:32 am
Yep, understood, rpi-eeprom-update.
Now if only I had a USB booting PI4 I could use as a server to test the net booting ones ;)
Not sure who wrote the code for the Pi3 USB boot but it works well with my USB3/SSD dock.
Give them a few beers.
Same dock will halt my Pi4 when it boots from an uSD, it continues when I unplug.
Anyway, looks like my netboot testing will need to use a Pi3 with SSD at the moment.
USB3/SATA dock details, is it a quirky one?
[ 2433.589953] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 2433.611671] usb 2-1: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 1.00
[ 2433.611682] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2433.611687] usb 2-1: Product: USB3.0 HDD DOCK
[ 2433.611691] usb 2-1: Manufacturer: JMicron
[ 2433.611696] usb 2-1: SerialNumber: 0000AB123519
[ 2433.635627] scsi host0: uas
[ 2433.636911] scsi 0:0:0:0: Direct-Access     Crucial_ CT240M500SSD1    8101 PQ: 0 ANSI: 6
[ 2433.639059] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[ 2433.639068] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2433.639339] sd 0:0:0:0: [sda] Write Protect is off
[ 2433.639345] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
[ 2433.639869] sd 0:0:0:0: [sda] Disabling FUA
[ 2433.639876] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2433.640728] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
jj_0
Sun Nov 10, 2019 10:07 am
The reboot problem is likely due to power backfeed from your USB3/SSD dock to the Pi's USB3 port - assuming you power it externally of course. The easiest way to fix that is to connect it via an USB3 hub that does not backfeed power to the USB3 port. The hard part is finding such a USB3 hub. The TP-Link UH400 and UH700 USB3 hubs work for me. Another way to fix it is to use an USB3 cable with the 5V wire cut.
As to needing quirks, the best way to find out is to do some tests, if you get 'uas' error messages in the log when copying large files to the SSD then you need to disable uas or maybe upgrade the firmware (at your own risk).
mahjongg
Sun Nov 10, 2019 2:21 pm
If the boot-loader will be revised, will it be able to boot from an exFAT partition? All previous RPI boot system were only capable of booting from a FAT32 partition, but with larger than 32GB SD-Cards getting cheaper all the time more and more cards will be formatted exFAT. I know that many people no longer use NOOBS, but wouldn't it be nice if exFAT booting could be implemented?
if booting from exFAT means we need to pay MS licences, then forget that I asked.
Sun Nov 10, 2019 2:26 pm
Microsoft have open source'd FAT and exFAT. No fees required.
This is a doctor free zone.
trejan
Sun Nov 10, 2019 3:34 pm
It'll be the cost of writing an exFAT module for the VPU from scratch. The one in the Linux kernel can't be used as it is GPL. The initial patch for it was nearly 11,000 lines so it is a lot more complicated than FAT.
