# revised 08-17-2019
#!/usr/bin/python3
# mypi.py
# Functions to display Pi properties
# If called directly outputs :
# - Pi Model
# - Revision number
# - Serial number
# - Python version
# - I2C,SPI and Bluetooth status
# - Mac address
# - IP address
# - CPU temperature
# - GPU temperature
# Author : Matt Hawkins
# Date : 06/12/2017 Revised 08-17-2019 for my Pi Zero W (by kflmiami420)
# https://www.raspberrypi-spy.co.uk/
import platform
import subprocess
import os
import socket
from uuid import getnode as get_mac
# Define functions
def getModel():
# Extract Pi Model string
try:
mymodel = open('/proc/device-tree/model').readline()
except:
mymodel = "Error"
return mymodel
def getSerial():
# Extract serial from cpuinfo file
mycpuserial = "Error"
try:
f = open('/proc/cpuinfo','r')
for line in f:
if line[0:6]=='Serial':
mycpuserial = line[10:26]
f.close()
except:
return mycpuserial
def getRevision():
# Extract board revision from cpuinfo file
myrevision = "Error"
try:
for line in f:
if line[0:8]=='Revision':
myrevision = line[11:-1]
f.close()
except:
return myrevision
def get_local_ip_address(target):
ipaddr = ''
try:
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.connect((target, 8000))
ipaddr = s.getsockname()[0]
s.close()
except:
pass
return ipaddr
def getCPUtemp():
# Extract CPU temp
try:
temp = subprocess.check_output(['vcgencmd','measure_temp'])
temp = temp[5:-3]
except:
temp = '0.0'
temp = '{0:.2f}'.format(float(temp))
return str(temp)
def getGPUtemp():
# Extract GPU temp
try:
temp = subprocess.check_output(['cat','/sys/class/thermal/thermal_zone0/temp'])
temp = float(temp)/1000
except:
temp = 0.0
temp = '{0:.2f}'.format(temp)
return temp
def getRAM():
# free -m
output = subprocess.check_output(['free','-m'])
lines = output.splitlines()
line = str(lines[1])
ram = line.split()
# total/free
return (ram[1],ram[3])
def getDisk():
# df -h
output = subprocess.check_output(['df','-h'])
disk = line.split()
# total/free
return (disk[1],disk[3])
def getCPUspeed():
# Get CPU frequency
try:
output = subprocess.check_output(['vcgencmd','get_config','arm_freq'])
output = output.decode()
line = lines[0]
freq = line.split('=')
freq = freq[1]
except:
freq = '0'
return freq
def getUptime():
# uptime
# tupple uptime, 5 min load average
return 0
def getPython():
# Get current Python version
# returns string
pythonv = platform.python_version()
return pythonv
def getSPI():
# Check if SPI bus is enabled
# by checking for spi_bcm2### modules
# returns a string
spi = "False"
try:
c=subprocess.Popen("lsmod",stdout=subprocess.PIPE)
gr=subprocess.Popen(["grep" ,"spi_bcm2"],stdin=c.stdout,stdout=subprocess.PIPE)
output = gr.communicate()[0]
if output[:8]=='spi_bcm2':
spi = "True"
except:
pass
return spi
def getI2C():
# Check if I2C bus is enabled
# by checking for i2c_bcm2### modules
# returns a string
i2c = "False"
try:
gr=subprocess.Popen(["grep" ,"i2c_bcm2"],stdin=c.stdout,stdout=subprocess.PIPE)
if output[:8]=='i2c_bcm2':
i2c = "True"
except:
pass
return i2c
def getBT():
# Check if Bluetooth module is enabled
# returns a string
bt = "False"
try:
gr=subprocess.Popen(["grep" ,"bluetooth"],stdin=c.stdout,stdout=subprocess.PIPE)
if output[:9]==b'bluetooth':
bt = "True"
except:
pass
return bt
if __name__ == '__main__':
# Script has been called directly
myRAM = getRAM()
myDisk = getDisk()
host = socket.gethostname()
mac = get_mac()
macString = ':'.join(("%012X" % mac)[i:i+2] for i in range(0, 12, 2))
print("----------------------------------------")
print("Pi Model : " + getModel())
print("Host :", host)
print("System : " + platform.platform())
print("Revision Number : " + getRevision())
print("Serial Number : " + getSerial())
print("Python version : " + platform.python_version())
print("I2C enabled : " + getI2C())
print("SPI enabled : " + getSPI())
print("Bluetooth enabled : " + getBT())
print("CPU Clock : " + getCPUspeed() + "MHz")
print("CPU Temperature : " + getCPUtemp() + u"\u00b0" +"C")
print("GPU Temperature : " + getGPUtemp() + u"\u00b0" +"C")
print("RAM (Available) : " + myRAM[0] + "MB (" + myRAM[1] + "MB)")
print("Disk (Available) : " + myDisk[0] + " (" + myDisk[1] + ")")
print("Wireless IP Address : " + get_local_ip_address('10.0.1.1'))
print("Wireless MAC Address : " + macString )
trackseven wrote: ↑Fri Oct 11, 2019 11:18 pmI found this in another post
# sample code suppressed from this reply
Correct.(the chance is vanishingly small - they are very big pseudo random numbers)
