Hey folks,
I use the wifi for connectivity to my router, is there a way to allow the ethernet port to feed another device? I am installing a DNS server too in to the pi.
There are many ways of configuring the network interfaces on a Pi, but you have to describe what you want, better than that, if you want some useful help.to allow the ethernet port to feed another device?
The word "feed" is going to cause some confusion, what on earth do you mean by that?
It does, but what is an "Acurite Access" ? and does it need internet connection ?
Indeed.what is an "Acurite Access" ?
Following that link:CountryEd wrote: ↑Fri Oct 04, 2019 5:17 pmhttps://www.acurite.com/access-my-acuri ... oring.html
I would like to find a way to have my wifi connect to my router and the above device connect to my pi's ethernet port. So a DNS server can run and also be used with Acuparse.
For now, that might rule out getting help from the many UK based volunteer helpers in these forums.AcuRite.com is currently unavailable in most European countries. We are engaged with the issue and committed to looking at options that support our full range of digital offerings to the EU market.
