royhenderson
How to update from 2019-07 to 2019-09?
Tue Oct 01, 2019 9:18 am
What is the recommended process to update Raspbian 2019-07 to 2019-09 in place?
TIA
topguy
Re: How to update from 2019-07 to 2019-09?
Tue Oct 01, 2019 9:20 am
sudo apt update
sudo apt dist-upgrade
pcmanbob
Tue Oct 01, 2019 9:23 am
As it has been for many years now
sudo apt-get update
sudo apt-get dist-upgrade
or the more up to date version
sudo apt update
sudo apt full-upgrade
B.Goode
Tue Oct 01, 2019 9:35 am
TIA
Already answered now, but there is existing Raspberry Pi documentation on the topic: https://www.raspberrypi.org/documentati ... pdating.md
royhenderson
Tue Oct 01, 2019 11:13 am
Thanks for prompt responses - apologies, I should have stated that I had already run the apt commands but it came back saying no packages to be updated.
Has the 2019-09 actually completed on my machine without my realising or might I be doing something wrong around the apt?
Can't pull screenshot at the moment but basically tried both sudo apt and sudo apt-get variants and got back no packages to be updated.
As before, TIA.
Edit: jumped on another machine and pulled the following --
pi@rpi-1:~ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
pi@rpi-1:~ $ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Then ran uname --
pi@rpi-1:~ $ uname -srm
Linux 4.19.66-v7+ armv7l
So - for some reason looks like the kernel is neither the 2019-07 nor the 2019-09 versions mentioned in the release notes.
Slightly confused ...
ShiftPlusOne
Tue Oct 01, 2019 11:28 am
Releases take a while.
The repo should be in sync soon if it isn't already.
B.Goode
Tue Oct 01, 2019 11:30 am
What is in /etc/os-release ?
royhenderson
Tue Oct 01, 2019 11:35 am
pi@rpi-1:~ $ sudo cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
B.Goode
Tue Oct 01, 2019 11:51 am
So you do appear to be running Raspbian Buster as you first reported, and the response from Moderator/Engineer @ShiftPlusOne is probably the best current advice.
(the reason for asking was that if you had been mistaken and were still running a Raspbian Stretch OS, updated packages are getting less frequent.)
topguy
Tue Oct 01, 2019 12:01 pm
Didn't buster include add a cron job to do daily update of packages ? Or do I remember wrong...
ShiftPlusOne
Tue Oct 01, 2019 12:03 pm
It only runs a list update not an upgrade of packages.
royhenderson
Tue Oct 01, 2019 12:25 pm
Thanks to all for responses - I will retry the apt route over the coming days. Additionally I will burn a 2019-09 Lite to SD and have a wander round that just as an exercise.
Gerbertus
Tue Oct 01, 2019 2:45 pm
Has something changed here? "apt update; apt dist-upgrade" hasn't normally done the trick of moving to a new Raspbian when the release contains new packages, as it does this time. Won't rpi-eeprom and Mousepad, at the least, be missing?
ShiftPlusOne
Tue Oct 01, 2019 2:52 pm
Yes, but the rpi-eeprom change is still not something we want everybody to get automatically - gradual rollout just in case there are any issues. And the mousepad change is optional and mostly just there for the x86 build.
Return to “Raspbian”
