Did you run "sudo apt update && sudo apt dist-upgrade" first ?r1ckdu wrote: ↑Mon Sep 02, 2019 5:19 pmTrying to install kodi from the pipplware repository i get the following error:The output ofCode: Select all
apt install kodi Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: kodi : Depends: kodi-bin (>= 2:18.3-2~buster) but 2:17.6+dfsg1-4+b1 is to be installed Depends: libshairplay0 but it is not installable E: Unable to correct problems, you have held broken packages.
however shows:Code: Select all
apt policy kodi
What now?Code: Select all
kodi: Installed: (none) Candidate: 2:18.3-2~buster Version table: 2:18.3-2~buster 500 500 http://pipplware.pplware.pt/pipplware/dists/buster/main/binary Packages 100 /var/lib/dpkg/status 2:18.3-1~buster 500 500 http://pipplware.pplware.pt/pipplware/dists/buster/main/binary Packages 2:17.6+dfsg1-4+b1 500 500 http://httpredir.debian.org/debian buster/main arm64 Packages
