I cannot get the overscan to work on my Raspberry Pi 4. The screen does not fit on the TV that I'm using. I did not have this issue with my Raspberry Pi 2b. Here is what I have in my config.txt on the Raspberry Pi 4
# uncomment this if your display has a black border of unused pixels visible
disable_overscan=0
overscan_left=40
overscan_right=40
overscan_top=40
overscan_bottom=40
# overscan.
framebuffer_width=1280
framebuffer_height=800
