This sort of thing? :RhE wrote: ↑Sun Jul 28, 2019 5:10 pmI have a tool that I use all the time. Do not know what to call it so I will try and describe it. It looks like a pen. When you press on the top spring loaded wire fingers extend from the bottom. Put a screw into the fingers and the spring retracts the fingers to hold the screw. You can then start the screw and switch to a screw driver to finish. I first saw this tool used by model railroaders. It has saved me from screws dropped behind mother boards more than once.
Chinese from aliexpress: https://nl.aliexpress.com/item/32759206262.html
