EOFFJM
Shut down multiple raspberry pis via SSH at once
Thu Jul 18, 2019 12:26 pm
Hi
I would like to know if there is a way to shut down multiple RPis (9 maximum) via SSH at once. Right now there is a connection to 9 RPis via SSH from a Windows 10 PC. To shut them down I connect to them via SSH (putty) one by one and then use the
sudo shutdown -h now
command. This takes a lot of time to do for 9 RPis. Is there a way to shut them down all at once? Some kind of batch file or something?
Thanks.
RaTTuS
Re: Shut down multiple raspberry pis via SSH at once
Thu Jul 18, 2019 12:37 pm
Covfefe
B.Goode
Thu Jul 18, 2019 1:25 pm
Yes. Some kind of batch file.
Wouldn't a .BAT file for Powershell or the DOS Command Line under Windows be trivial to create? The same Command 9 times, with just the target hostname or IP address being different?
Hint: SSH is not restricted to running interactively - you can also use it to invoke specified commands on the target (remote) host.
jahboater
Thu Jul 18, 2019 1:46 pm
Yes, that's what I would do:-
ssh pi@pi4 'sudo poweroff'
multiple times in a batch file.
EOFFJM
Thu Jul 18, 2019 1:47 pm
Alright great! Now I'll just have to figure out how to do that...
EOFFJM
Thu Jul 18, 2019 1:48 pm
Cool. Got it.
jahboater
Thu Jul 18, 2019 1:53 pm
You will need password-less authentication.
ssh-keygen -t rsa
ssh-copy-id pi@pi4
Do it once for each Pi, then scp and ssh will not require a password (which is obviously bad news in a batch file!)
Return to “Raspbian”
