Carolyn28
When NOOBS 3.1.1 update?
Mon Jul 08, 2019 4:20 pm
When NOOBS 3.1.1 is updated so this "E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'" is fixed?
I know there are instructions how to fix this in terminal but i would like that the first-boot setup wizard works perfectly.
DirkS
Re: When NOOBS 3.1.1 update?
Mon Jul 08, 2019 5:08 pm
When NOOBS 3.1.1
Once NOOBS is installed it is never automatically updated.
NB: NOOBS is just the OS installer / selection program.
Are you actually referring to Raspbian? If that's the case then you have to post the command you're issuing and the *full* error message.
Carolyn28
Mon Jul 08, 2019 5:38 pm
I downloaded NOOBS 3.1.1 and then installed Raspbian full recommended.
It runs first-run setup wizard and in the end of wizard it tries to update raspbian and gets error:
In this forum there is instructions how to fix that, but i want to wait when what ever causes this is updated, Raspbian?, and then install latest NOOBS/Raspbian so wizard update finishes correctly.
DirkS
Mon Jul 08, 2019 7:08 pm
As I said: there will be no NOOBS update that will fix your problem. A newer version will *reinstall* NOOBS & Raspbian and you will lose everything that's on your card now.
Mon Jul 08, 2019 7:33 pm
That's one more reason to replace NOOBS with PINN. PINN has a self-updater.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Return to “Beginners”
