Got a new pi 4 4gb model today.
After etching Buster and initial set up system would not boot with dual monitors connected.
Would boot with only one monitor in hdmi 0 (did not matter which of the two monitors i used, they are the same model number)
After lots of troubleshooting solved dual monitor boot up issue you guys may be having by using the following.
when turning on the Pi 4 (plugging in or from reboot) I have to power cycle one of my monitors (plugged in hdmi port 1) so that the monitor does not time out (no signal displayed on monitor) before the pi displays the 4 pis on the primary screen. If i time it right, i get a rainbow square on the other screen.
I have tried many ways in config.txt to fix this timeout issue but I believe its part the pi problem, part Buster problem, and part my monitor.
if i do not time the power cycle of the monitor right, the unit locks up after the 4 pis and will not display anything on either monitor and will not boot far enough to permit an SSH connection.
Hopefully this helps someone else
