pi@raspberrypi:~$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi:~$ ifconfig wlan0
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet6 fe80::91bd:8bd6:abf7:bd83 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:d2:b9:29 txqueuelen 1000 (Ethernet)
RX packets 1856 bytes 414959 (405.2 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1865 bytes 254256 (248.2 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
pi@raspberrypi:~$ sudo wpa_supplicant -B -i interface -c /etc/wpa_supplicant/wpa_supplicant.conf
Successfully initialized wpa_supplicant
Could not read interface interface flags: No such device
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=interface disabled_11b_rates=0
interface: Failed to initialize driver interface
pi@raspberrypi:~$
Jul 03 06:49:19 rpi31 systemd[1]: Starting Daily apt upgrade and clean activities...
Jul 03 06:49:50 rpi31 systemd-networkd-wait-online[972]: Event loop failed: Connection timed out
Jul 03 06:49:50 rpi31 apt-helper[969]: E: Sub-process /lib/systemd/systemd-networkd-wait-online returned an error code (1)
Jul 03 06:49:54 rpi31 systemd[1]: apt-daily-upgrade.service: Succeeded.
Jul 03 06:49:54 rpi31 systemd[1]: Started Daily apt upgrade and clean activities.
Jul 03 08:14:19 rpi31 systemd[1]: Starting Daily apt download activities...
Jul 03 08:14:50 rpi31 systemd-networkd-wait-online[1098]: Event loop failed: Connection timed out
Jul 03 08:14:50 rpi31 apt-helper[1096]: E: Sub-process /lib/systemd/systemd-networkd-wait-online returned an error code (1)
Jul 03 08:14:52 rpi31 systemd[1]: apt-daily.service: Succeeded.
Jul 03 08:14:52 rpi31 systemd[1]: Started Daily apt download activities.
If that is so, it may depend on use case. I prefer less screen tearing and frame loss. Running only one or two programs in X without pretty animations or transparencies is fine by me.PeterO wrote: ↑Thu Jul 04, 2019 10:08 amxcompmgr seems to be contributing to poor openGL and openGLES performance. See this thread.
https://www.raspberrypi.org/forums/view ... 2#p1491828
[...] can it be disabled by default please ?
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
I can't say I have noticed that. Every re-boot I have done with Buster has always got a DHCP assigned 192.168.0.x address.
root@raspberrypi:/# apt-get install php-smbclient
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
libavahi-client3 libcups2 libjansson4 libldb1 libpython2.7 libsmbclient libsodium23 libtdb1 libtevent0 php-common php7.2-cli php7.2-common php7.2-json
php7.2-opcache php7.2-phpdbg php7.2-readline python-talloc samba-libs
Suggested packages:
cups-common php-pear
libavahi-client3 libcups2 libjansson4 libldb1 libpython2.7 libsmbclient libsodium23 libtdb1 libtevent0 php-common php-smbclient php7.2-cli php7.2-common
php7.2-json php7.2-opcache php7.2-phpdbg php7.2-readline python-talloc samba-libs
0 upgraded, 19 newly installed, 0 to remove and 0 not upgraded.
Need to get 9461 kB of archives.
After this operation, 39.8 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Looking at this.nachoparker wrote: ↑Sat Jul 06, 2019 12:22 am`php-smbclient` pulls in PHP7.2 dependencies, even though Buster defaults to PHP7.3. Or regular Debian, `php-smbclient` does not pull in PHP7.2, but depends on PHP7.3.
Having exactly the same issue.mark.carline wrote: ↑Thu Jun 27, 2019 8:02 pmI am trying to get this Aeotec Z-Stick Gen5, Z-Wave Plus USB to work on Buster:
https://www.amazon.co.uk/Aeotec-Z-Stick ... th=1&psc=1
I don't see this device appear when i connect it:
/dev/ttyACM0
It talks to the device via a serial connection and i then use it via Home Assistant. Has something changed for USB drivers?
I'm going to cross post this over on the HA forum for awareness.
https://community.home-assistant.io/t/t ... rk.carline
I opened this guthub bug report:
https://github.com/raspberrypi/linux/issues/3027
Thanks!
fd_ wrote: ↑Thu Jun 27, 2019 9:02 pmI eventually rebooted after some 4 hours, and the result is again that keyboard layout selection is completely garbled (some layout names are displayed in French, some in Dutch, some as black squares, really strange):fd_ wrote: ↑Thu Jun 27, 2019 6:56 pmThanks for all your efforts for the new hardware and OS - greatly appreciated!
I just flashed Buster Lite on a fresh SD card and put it into my Pi Zero W. It does boot fine, reports to resize the Boot Partition and boots again. The boot process is also working the second time, but it’s the automatically started update process that’s worrying me a bit: it has been running for multiple hours now, with no more information than something along the lines of “Checking and downloading updates” (seems I can issue commands while the setup is still running, and I made the mistake of running dmesg, so I no longer see the original message). It never reported to have completed. This is the second run of going through the setup process, I rebooted the first one impatiently, and the result was a system with garbled keyboard layout names, so I reflashed.
Is the setup process of a fresh install supposed to take that long? Does it report when it’s finished? Is there any way to see what exactly it’s doing behind the scenes (and get a more fine grained progress report)?
Here are the steps that allow me to reproduce the issue:
1) Download the Buster Lite Image from the official website (The checksum does match for my download)
2) Use Etcher on macOS to flash the image (I let Etcher extract the zip for me)
3) Remove and reinsert the card in the MacBook SD slot to mount the boot partition in macOS
4) Duplicate the LICENSE.broadcom file, then rename the duplicate to “ssh” and delete its contents
5) Eject the card and insert into the Pi Zero W (Pi has Internet connection via USB hub + Ethernet dongle)
6) Power up the Pi
7) The Pi will get stuck at “[OK] Started Daily apt upgrade and clean activities.”
At this point, it is possible to use a USB keyboard (attached to aforementioned hub) to log in and issue commands. This allowed me to verify that the Pi has Internet Access (Ping Google.com) and (after having waited for ~4 hours), to reboot via sudo reboot
8) Steps Continue below screenshot
That’s as far as it boots up. No input was entered to this point.
8) Reboot
9) Log in using default credentials (via the Pi itself, ssh is not actually used)
10) Start raspi-config
11) Choose Localisation Options > Change Keyboard Layout
12) Layout names are partly in French, partly in Spanish (or is it Italian?), partly black squares; It’s impossible to find the correct configuration without proper labels. See image above.
[68948.088433] sda:
[68951.087475] sda:
[68953.103311] sda: sda1
[68956.435010] sda: sda1
[68962.641073] sda: sda1
[68975.681865] sda: sda1
[68975.879601] sda: sda1
[68975.967227] sda: sda1
[68984.159740] sda: sda1 sda2
[68986.721122] sda: sda1 sda2
[68994.875205] sda: sda1 sda2
[69083.854402] sda:
[69088.170271] sda:
[69090.950554] sda: sda1
[69093.942812] sda: sda1
[69099.416598] sda: sda1
[69112.339203] sda: sda1
[69112.418902] sda: sda1
[69112.529015] sda: sda1
[69120.954523] sda: sda1 sda2
[69124.335282] sda: sda1 sda2
[69133.827331] sda: sda1 sda2
[69142.017127] sda: sda1 sda2
[69142.219821] sda: sda1 sda2
[69142.293088] sda: sda1 sda2
[69144.542514] sda: sda1 sda2
[69159.685263] sda: sda1 sda2
[69205.802032] sda: sda1 sda2
[69215.460343] sda: sda1 sda2
[69223.711878] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x66695a54)
[69223.711904] F2FS-fs (sda2): Can't find valid F2FS filesystem in 1th superblock
[69223.722518] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[69223.722548] F2FS-fs (sda2): Can't find valid F2FS filesystem in 2th superblock
[69223.723767] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x66695a54)
[69223.723793] F2FS-fs (sda2): Can't find valid F2FS filesystem in 1th superblock
[69223.723813] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[69223.723823] F2FS-fs (sda2): Can't find valid F2FS filesystem in 2th superblock
[69262.905311] sda: sda1 sda2
[69282.682374] sda:
[69282.797421] sda:
[69288.429939] sda:
[69306.522341] sda: sda1
[69404.236448] sda:
[69407.695480] sda:
[69409.945398] sda: sda1
[69411.161657] sda: sda1
[69413.170043] sda: sda1
[69417.282511] sda: sda1
[69426.996638] sda: sda1
[69427.116032] sda: sda1
[69427.200099] sda: sda1
[69435.388106] sda: sda1 sda2
[69440.996482] sda: sda1 sda2
[69447.244114] sda: sda1 sda2
[69455.383439] sda: sda1 sda2
[69455.506322] sda: sda1 sda2
[69455.601124] sda: sda1 sda2
[69457.688921] sda: sda1 sda2
[69472.078228] sda: sda1 sda2
[69514.874671] sda: sda1 sda2
[69523.651822] sda: sda1 sda2
[69531.287051] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x66695a54)
[69531.287079] F2FS-fs (sda2): Can't find valid F2FS filesystem in 1th superblock
[69531.288650] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[69531.288673] F2FS-fs (sda2): Can't find valid F2FS filesystem in 2th superblock
[69531.288798] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x66695a54)
[69531.288812] F2FS-fs (sda2): Can't find valid F2FS filesystem in 1th superblock
[69531.288828] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[69531.288837] F2FS-fs (sda2): Can't find valid F2FS filesystem in 2th superblock
[69944.170014] usb 1-1.3: USB disconnect, device number 4
[69948.569858] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[69948.705574] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0727, bcdDevice= 2.50
[69948.705603] usb 1-1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[69948.705616] usb 1-1.2: Product: USB Storage
[69948.705630] usb 1-1.2: Manufacturer: Generic
[69948.705641] usb 1-1.2: SerialNumber: 000000000250
[69948.713811] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[69948.735137] scsi host0: usb-storage 1-1.2:1.0
[69949.781954] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0250 PQ: 0 ANSI: 0
[69949.787410] sd 0:0:0:0: Attached scsi generic sg0 type 0
[69949.900935] sd 0:0:0:0: [sda] 15353856 512-byte logical blocks: (7.86 GB/7.32 GiB)
[69949.902805] sd 0:0:0:0: [sda] Write Protect is off
[69949.902832] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
[69949.904286] sd 0:0:0:0: [sda] No Caching mode page found
[69949.904312] sd 0:0:0:0: [sda] Assuming drive cache: write through
[69949.919117] sda: sda1 sda2
[69949.934597] sd 0:0:0:0: [sda] Attached SCSI removable disk
[70074.647683] sda:
[70077.994533] sda:
[70080.240750] sda: sda1
[70083.908219] sda: sda1
[70091.655685] sda: sda1
[70104.422587] sda: sda1
[70104.579763] sda: sda1
[70104.664981] sda: sda1
[70114.381594] sda: sda1 sda2
[70125.544325] sda: sda1 sda2
[70135.102848] sda: sda1 sda2
[70135.174030] sda: sda1 sda2
[70135.234646] sda: sda1 sda2
[70150.523458] sda: sda1 sda2
[70199.843670] sda: sda1 sda2
[70209.969310] sda: sda1 sda2
[70219.728868] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x66695a54)
[70219.728895] F2FS-fs (sda2): Can't find valid F2FS filesystem in 1th superblock
[70219.754083] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[70219.754111] F2FS-fs (sda2): Can't find valid F2FS filesystem in 2th superblock
[70219.754242] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x66695a54)
[70219.754256] F2FS-fs (sda2): Can't find valid F2FS filesystem in 1th superblock
[70219.754271] F2FS-fs (sda2): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[70219.754281] F2FS-fs (sda2): Can't find valid F2FS filesystem in 2th superblock
terminate_dialog (_("Could not mount partition."));
ip address add 192.168.x.x/24 dev eth0 && dhcpcd -4
fatrace -f W
root@piman-401:/home/hamish# fatrace -f W
Cannot initialize fanotify: Invalid argument
[ 194.847842] dvbdev: DVB: registering new adapter (Realtek RTL2832U reference design)
[ 194.870344] i2c i2c-3: Added multiplexed i2c bus 4
[ 194.870360] rtl2832 3-0010: Realtek RTL2832 successfully attached
[ 194.870460] usb 1-1.3: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 194.895629] r820t 4-001a: creating new instance
[ 194.902491] r820t 4-001a: Rafael Micro r820t successfully identified
[ 194.925045] Registered IR keymap rc-empty
[ 194.925167] rc rc0: Realtek RTL2832U reference design as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/rc/rc0
[ 194.925382] input: Realtek RTL2832U reference design as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/rc/rc0/input1
[ 194.925745] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
[ 194.925890] usb 1-1.3: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 194.939633] usb 1-1.3: dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialized and connected
[ 194.939878] usbcore: registered new interface driver dvb_usb_rtl28xxu
[ 295.679295] r820t 4-001a: destroying instance
[ 295.679705] dvb_usb_v2: 'Realtek RTL2832U reference design:1-1.3' successfully deinitialized and disconnected
[ 307.758828] dvb_usb_rtl28xxu 1-1.3:1.0: chip type detection failed -110
[ 307.758865] dvb_usb_rtl28xxu: probe of 1-1.3:1.0 failed with error -110
[ 313.939080] usb 1-1.3: reset high-speed USB device number 3 using xhci_hcd
[ 319.069235] usb 1-1.3: device descriptor read/64, error -110
FTFY, you're welcomedrmullins wrote: ↑Sun Jul 07, 2019 5:08 pmNew installation of buster on RPi 4 B 4GB
After issuing :
sudo gparted /dev/sda
with intention of reformatting a partition of /dev/sda,
the following is displayed in terminal window :
Unit tmp.mount does not exist, proceeding anyway
followed by standard libparted : 3.2 message
Next I unmount /dev/sda1 successfully using gparted GUI
However then trying to format /dev/sda1 as ext4 via gparted GUI fails with attached error message :
Help !
All this works fine in stretch and jessie
GParted 0.32.0 --enable-libparted-dmraid --enable-online-resize Libparted 3.2 Format /dev/sda1 as ext4 00:00:11 ( ERROR ) calibrate /dev/sda1 00:00:01 ( SUCCESS ) path: /dev/sda1 (partition) start: 2048 end: 1953522863 size: 1953520816 (931.51 GiB) clear old file system signatures in /dev/sda1 00:00:00 ( SUCCESS ) write 512.00 KiB of zeros at byte offset 0 00:00:00 ( SUCCESS ) write 4.00 KiB of zeros at byte offset 67108864 00:00:00 ( SUCCESS ) write 4.00 KiB of zeros at byte offset 274877906944 00:00:00 ( SUCCESS ) write 512.00 KiB of zeros at byte offset 1000202043392 00:00:00 ( SUCCESS ) write 4.00 KiB of zeros at byte offset 1000202567680 00:00:00 ( SUCCESS ) write 8.00 KiB of zeros at byte offset 1000202649600 00:00:00 ( SUCCESS ) flush operating system cache of /dev/sda 00:00:00 ( SUCCESS ) set partition type on /dev/sda1 00:00:10 ( SUCCESS ) new partition type: ext4 create new ext4 file system 00:00:00 ( ERROR ) mkfs.ext4 -F -O ^64bit -L '' '/dev/sda1' 00:00:00 ( ERROR ) mke2fs 1.44.5 (15-Dec-2018) The file /dev/sda1 does not exist and no size was specified. ========================================
