And it's this that seems to have made my HDMI sound intermittently choppy / strange sounding. This problem was persistent across reboots.
sudo rpi-update a08ece3d48c3c40bf1b501772af9933249c11c5b
Done: https://github.com/raspberrypi/linux/issues/2981dom wrote: ↑Mon May 20, 2019 4:19 pmCan you create an issue here: https://github.com/raspberrypi/linux/issues
and describe the minimum steps you need to do to see the problem with 4.19 vs 4.14.
Can you create an issue here:Chimneyfactory wrote: ↑Mon May 20, 2019 11:59 pmAnd it's this that seems to have made my HDMI sound intermittently choppy / strange sounding. This problem was persistent across reboots.
If I can provide any further info that might be useful, please let me know.
Having tinkered a bit more today, I've discovered a problem with reporting it - I can't reproduce the problem outside of this pi and it's installationdom wrote: ↑Tue May 21, 2019 11:14 amCan you create an issue here:Chimneyfactory wrote: ↑Mon May 20, 2019 11:59 pmAnd it's this that seems to have made my HDMI sound intermittently choppy / strange sounding. This problem was persistent across reboots.
where we can try to work out what caused the behaviour change.
I've managed to get it repeatable on a fresh install, so logged here https://github.com/raspberrypi/linux/issues/2983dom wrote: ↑Tue May 21, 2019 11:14 amCan you create an issue here:Chimneyfactory wrote: ↑Mon May 20, 2019 11:59 pmAnd it's this that seems to have made my HDMI sound intermittently choppy / strange sounding. This problem was persistent across reboots.
It seems so. I just did an update and reboot on one Pi and it's now running 4.19.42itsmedoofer wrote: ↑Thu May 23, 2019 7:47 amShould we be seeing the 4.19 kernel when we do an apt update ?
Yea all on stretch.....rpdom wrote: ↑Thu May 23, 2019 8:58 amIt seems so. I just did an update and reboot on one Pi and it's now running 4.19.42itsmedoofer wrote: ↑Thu May 23, 2019 7:47 amShould we be seeing the 4.19 kernel when we do an apt update ?
Is your Pi 2 running Raspbian Stretch?
Doh !! Just looked at the up time, 30 odd days, rebooted and I'm magically on 4.19 now.binaryhermit wrote: ↑Tue May 28, 2019 3:37 amI can't help but think the pi2's update slipped through unnoticed and it'll be on 4.19 once rebooted?
And you're on 4.19.42 or 4.19.46?DarkPlatinum wrote: ↑Tue May 28, 2019 8:59 pmUsing fake KMS, 192mb split on RPi 3B+ chromium 72. Getting stuttering in 480p video (non fullscreen).
I am on 4.19.42.kozman wrote: ↑Tue May 28, 2019 9:45 pmAnd you're on 4.19.42 or 4.19.46?DarkPlatinum wrote: ↑Tue May 28, 2019 8:59 pmUsing fake KMS, 192mb split on RPi 3B+ chromium 72. Getting stuttering in 480p video (non fullscreen).
Are you saying this configuration has worked better with a previous kernel? If so, which one.DarkPlatinum wrote: ↑Tue May 28, 2019 8:59 pmUsing fake KMS, 192mb split on RPi 3B+ chromium 72. Getting stuttering in 480p video (non fullscreen).
It had worked better on the 4.14 kernel, (not sure what version but one of the latest ones).dom wrote: ↑Wed May 29, 2019 12:06 pmAre you saying this configuration has worked better with a previous kernel? If so, which one.DarkPlatinum wrote: ↑Tue May 28, 2019 8:59 pmUsing fake KMS, 192mb split on RPi 3B+ chromium 72. Getting stuttering in 480p video (non fullscreen).
Can you identify the exact update which caused this. See:DarkPlatinum wrote: ↑Wed May 29, 2019 6:23 pmIt had worked better on the 4.14 kernel, (not sure what version but one of the latest ones).
sudo rpi-update <hash>
Probably not likely to help much but is it any different under 4.19.46?DarkPlatinum wrote: ↑Thu May 30, 2019 7:46 pmWhat I have found so far with the 4.19.42 kernel is the full-kms driver works fine in 720p fullscreen whereas the fake-kms lags. Could just be a driver issue?
Upgrading to 4.19.46 is going to be a problem. I use this Raspberry Pi for daily use so if I have issues with the kernel I may lose some data. For the time being I only update with apt-get update (rather than rpi-updat/upgrade).
DarkPlatinum wrote: ↑Fri May 31, 2019 10:01 amUpgrading to 4.19.46 is going to be a problem. I use this Raspberry Pi for daily use so if I have issues with the kernel I may lose some data. For the time being I only update with apt-get update (rather than rpi-updat/upgrade).
What I can do is provide data to be used as a comparison on your system.
Kernel 4.19.42, Raspberry Pi 3B+, 192mb split, full-kms:
glxgears averages 53 fps
Raspberry Pi desktop opengl test averages 6 fps.
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 58G 1.2G 55G 3% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 6.2M 457M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/mmcblk0p1 43M 23M 21M 53% /boot
tmpfs 93M 0 93M 0% /run/user/1000
uname -a
Linux raspberrypi 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.9 (stretch)
Release: 9.9
Codename: stretch
df -h
/dev/root 58G 1.3G 55G 3% /
tmpfs 464M 12M 452M 3% /run
uname -a
Linux raspberrypi 4.19.46-v7+ #1230 SMP Tue May 28 16:18:48 BST 2019 armv7l GNU/Linux
Nope. Minor kernel bumps rarely cause issues so you shouldn't expect a problem, but there are rare exceptions.
