https://www.amazon.co.uk/gp/product/B07 ... _qh_dp_hza -
Have purchased this for a play around with a project i would like to do just a simple tracker that i could remote access to pull the data and track in real time.
I also have a raspberry pi zero to use with it.
A couple of questions though as my knowledge of linux is so so i can get by from tutorials.
I had first initially thought GPS was not free but from my researching it seems it is widely free is that correct?
The add on hat has a coin cell battery - Does this mean that it could sit in a state of low power and only activate if i were to wake up the pi zero?
I have read a few guides on GPS and found the scripts that it takes to run so that shouldn't be too much of a headache * Famous last words.*
The part of the GSM is where i am struggling to get to terms with.
Since this part will only function over 2G in my country from what i gather (UK) will i still be able to remotely access the device this way and what software would i use to be able to do this?
Will i be limted by 2G speeds when downloading this data?
What will the real time tracking be using to track the device from home? GSM or GPS? i.e would i need to send a call to the device to wake it up?
I plan on running this from a powerbank will this be OK? Since i only want to activate the device and send a wake up script and a shutdown script when i am finished. (currently the 20,000mah battery i used for a pi 3+ lasted around 3 days give or take)
Is there a better alternative like those batteries you can attach direct to the pi.
Sorry my questions are a little out of frame.
Hopefully someone may understand!
Thank You.
