sticklerer
Wifi host and use in same time
Mon May 13, 2019 3:29 pm
Hi! I want to connect to a wifi network and host a wifi network at the same time on a Raspberry Pi 3 A+ using Raspbian stretch.
Is this possible ?
Andyroo
Re: Wifi host and use in same time
Mon May 13, 2019 4:52 pm
You will need to add another WiFi card via USB for this.
Just check that the dongle works with the Pi - possibly look at the official suppliers rather than cheaper alternatives that just say a whole series of computers in their listing.
Need Pi spray - these things are breeding in my house...
sticklerer
Mon May 13, 2019 5:10 pm
I have a TP-LINK wifi dongle. How can i check it's work with pi or not ?
Andyroo
Mon May 13, 2019 5:20 pm
It all depends on the chip set inside the dongle.
First thing is to find the exact module of dongle and then search on the forum here for others with the same model for the fix process. Unfortunately TP-Link boxes often need a specific driver - for example https://www.raspberrypi.org/forums/view ... 48#p433048
sticklerer
Mon May 13, 2019 5:44 pm
I searched for this model (TL-WN821N V.4/ RTL8192CU) on forum but i didn't find any topic from this version.
Mon May 13, 2019 5:45 pm
https://www.raspberrypi.org/forums/view ... 28&t=62371
adieu
sticklerer
Mon May 13, 2019 6:00 pm
This driver installer doesen't have the driver what i need . But thanks the link .
Andyroo
Mon May 13, 2019 6:15 pm
Strange, this post https://www.raspberrypi.org/forums/view ... ?p=1260237 uses that dongle as the AP.
As for setting up the link - that’s beyond my networking skills I’m afraid :lol:
sticklerer
Mon May 13, 2019 6:19 pm
He is using V5 of dongle,but i try this method maybe it's work with the v4 too.
sticklerer
Mon May 13, 2019 6:26 pm
Installer doesen't have the drivers for my device (RTL8192CU).Maybe because it's version 4 and not 5.
Andyroo
Mon May 13, 2019 6:38 pm
Just thought - if you have WLAN1 does that not mean it’s been recognised :shock:
sticklerer
Mon May 13, 2019 6:40 pm
Yes i didn't think it,that's the reason why i edited the comment befor 5 minutes . :|
Andyroo
Mon May 13, 2019 6:56 pm
Their are instructions for setting up an AP on github using the Ethernet port that may work for you with care but my networking is not good enough to walk you through it or debugging issues :oops:
I’m not sure these standard instructions https://www.raspberrypi.org/documentati ... s-point.md still work but it’s been so long since I abandoned that project I’ve lost the updated link. A QUICK check points me to https://github.com/XECDesign/documentat ... s-point.md
I do not think that just changing ETH0 to WLAN1 will work as you need to connect one WiFi to the existing network and I’ve not seen any notes on how to do this. Really wish I did a networking course before starting the python set I’m going through :lol:
sticklerer
Mon May 13, 2019 7:40 pm
Thank you for trying to help me with this project.Tomorrow i will try to make something from the link you send ,maybe i can get the wifi network work . :D
Andyroo
Mon May 13, 2019 7:58 pm
Good luck :)
A quick read (your fault I’m now intrigued) seem to show you add a name into the network details in wpa supplicant and then link this to the IP address and device name in the dhcpcd config but how you get the IP tables set up etc looses me very quickly.
Tempted to play but I’ve only got a zero free at the mo and despite having two spare dongles I've no hub at home :lol:
Mon May 13, 2019 8:03 pm
RTL8192 should be supported in Raspbian Stretch by default.
adieu
Andyroo
Mon May 13, 2019 8:10 pm
Think we got past that bit in the end :lol: The next problem (setting it up) is beyond me and despite having a quick surf it’s not an area I can learn in a couple of days.
Mon May 13, 2019 8:29 pm
It possibly could be that the included driver / firmware does not support access point mode ?
adieu
