Abuzar
i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation
Wed May 08, 2019 7:04 am
i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation with a particular set of coordinates from GPS module.
It supposed to do the surveillance on its own after receiving the the set of coordinates.
Please suggest me a good algorithm to do task. Thank in advance
Joel_Mckay
Re: i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation
Sun May 12, 2019 2:19 am
Have a look at ROS or MRPT.
You will need to be more specific about the platform, as guidance and navigation are separate classes of problems.
Cheers.
J
LTolledo
Sun May 12, 2019 2:53 am
Do you "need":
1. a guide to make the the algorithm?
2. a full running algorithm ( as in served in a silver platter)?
Some people be like:
PhatFil
Sun May 12, 2019 3:00 am
kiss when forward path is obscured turn right.
ElEscalador
Sun May 12, 2019 3:56 am
Look up A*? Or go with ROS and try gmapping or hector...not really enough info and likely gps alone will not be adequate. There is so much error in sensors that typically a bunch are used and the data fused and vetted. indoor? Outdoor?
Giving away some sensors and robot parts in advance of my book release! The first review and giveaway below!
https://youtu.be/fCX0HaeQiyw
LTolledo
Sat May 18, 2019 10:54 am
.... topic on watch list.... possible spam-bot generated content....
Return to “Advanced users”
