planteg
Apache2 error about ${APACHE_RUN_DIR} not set
Tue May 07, 2019 8:32 pm
on latest Raspbian stretch, April 2018, I got this error after installing apache2:
[Tue May 07 16:07:12.221849 2019] [core:warn] [pid 1067] AH00111: Config variable ${APACHE_RUN_DIR} is not defined
apache2: Syntax error on line 80 of /etc/apache2/apache2.conf: DefaultRuntimeDir must be a valid directory, absolute or relative to ServerRoot
I get the same error when running
apache2 -S
Where is that variable supposed to be defined ? I installed apache2 on previous version of Raspbian and never got that error.
Things is apache2 seems to run fine because if I enter localhost in the browser, the page is correctly displayed.
Many thanks
Re: Apache2 error about ${APACHE_RUN_DIR} not set
Tue May 07, 2019 10:02 pm
Use
sudo systemctl start apache2
or
sudo apachectl start
This is a doctor free zone.
planteg
Tue May 07, 2019 10:31 pm
Dougie,
I found out here https://bugs.debian.org/cgi-bin/bugrepo ... bug=879571 that now we must use apacthe2ctrl as you noted.
Does that mean that the installation is wrong stating that the variable is not set ? Running
apache2ctrl -S
states that
ServerRoot: "/etc/apache2"
Gilles Plante
Tue May 07, 2019 10:46 pm
The systemd stuff sets the right environment variables on Raspbian Stretch systems.
Just use sudo systemctl start apache2.
