Hi guys -
I'm trying to find a solution, that hopefully might already be available to solve this problem. I have 2 waterfall / ponds (they're pretty elaborate), that use commercial grade pumps to flow the water (10,000 gallons per hour). One is in the front, and one is in the back. Unfortunately, on a daily basis, due to a leak or something else going on that would virtually cost a fortune to rip and replace... both ponds slowly lose water throughout the day, and thus have to have water added to them at various points.
I know they make "valves" that utilize a 2 wire connection solenoid, and potentially a wireless one as well, that could be soldered into the copper line that could turn the valve on or off. I'm trying to find a solution using a Pi, a sensor, and valve, such that when the water level drops a few inches, it would trigger the valve to open and flow water back into the pond, and when the water level reaches the full mark, it will shut the valve off. I'd love it if there were a wireless solution, but my gut tells me that's probably not likely for the distance between where the sensor would need to be installed in the pond to the raspberry pi / valve.
I don't think a "float" type trigger would work, as pond retention areas aren't that deep, just wide, therefore only an inch or 2 in drop.
Does anyone know if there's a viable solution out there for this? I've been trying to wrap my head around for about a year now.
