ImagineZA
Running two different OS at the same time
Thu Mar 28, 2019 8:04 am
Hey Guys,
I was wondering if it would be possible to simultaneously run two different OS builds on the Pi at the same time.
More specifically, Raspbian and an Android OS, like Emteria.
The reason behind it:
I'm currently using the Pi with Raspbian to "monitor" a few things around the house, Digital IO's, Light controls etc, as well as running a web server that displays the status of the things being monitored.
I'd like to run an Android OS on the Pi at the same time to theoretically turn a dumb TV in to a Smart TV, via HDMI and Wireless Keyboard.
It seems like it might be quite a hassle for the Pi in terms of hardware limitations, but I was wondering if it is possible and if it is, how to go about doing it.
Cheers,
jahboater
Re: Running two different OS at the same time
Thu Mar 28, 2019 8:17 am
Do you mean running the second OS in a virtual machine?
I'm not sure whats available on the Pi. VirtualBox doesnt support ARM.
It may well be easier just to use two Pi's - they use little power and are cheap.
The new 3B+ (with the plus) is the most capable model.
ImagineZA
Thu Mar 28, 2019 8:23 am
I assume running both on an ESXI type OS would be the way to do it?
I was thinking about getting another Pi to do the job, but wanted to see if it was possible, the Pi is pretty much a tinker toy, so trying these things out is always a win for me, even if they fail.
Cheers,
jahboater
Thu Mar 28, 2019 8:40 am
I suppose look on the VMware website, but I would be astonished if anything like that was available.
Wouldn't it be very expensive too?
ImagineZA
Thu Mar 28, 2019 8:46 am
I have had a squiz and they do have posts about how the "demo-ed" an ARM version on a Pi at some recent IoT/EDGE Expo, but nothing in full release yet, so was curious to see if there was something similar.
Link to the VMWare Blog on ESXI 6.8 on RPI (if anyone else is interested): https://vinfrastructure.it/2018/11/vmwa ... pberry-pi/
Cheers,
HawaiianPi
Thu Mar 28, 2019 9:28 am
The biggest problem is limited RAM.
So, can you do it... there's probably a way.
The real question is, should you do it... and the answer to that is almost certainly, no.
Running a guest OS in a VM with only 1GB of RAM is not likely to provide a usable system.
But ... I have not tried it myself, so ... ¯\_(ツ)_/¯
jahboater
Thu Mar 28, 2019 9:30 am
With VMware ESX you are effectively running 3 OS's at the same time!
ImagineZA
Thu Mar 28, 2019 11:00 am
I also read that the Pi4 will have better hardware and a possible Android GO official OS:
https://www.linux.com/blog/2019/2/new-p ... android-pi
Thu Mar 28, 2019 11:21 am
That is pure speculation and nothing Official has been stated :roll:
adieu
Andyroo
Thu Mar 28, 2019 1:18 pm
See this thread viewtopic.php?f=63&t=236676
Need Pi spray - these things are breeding in my house...
hippy
Thu Mar 28, 2019 3:34 pm
With just £290 pledged of the £2,559 goal, with only 12 days to go, it doesn't seem that effort to deliver Android GO is really getting off the ground.
Thu Mar 28, 2019 3:40 pm
I doubt we will have a official Android version in the near or even medium term. We are not working on one. I suppose we could take someone elses one and make it official, but seems unlikely.
Thu Mar 28, 2019 4:03 pm
Well, better hardware seems obvious. Otherwise we could just continue selling the Pi3B+......
rpdom
Thu Mar 28, 2019 4:35 pm
Does that mean you're going to stop selling the 3B+ when the 4B comes out? Unlikely, I suspect.
ImagineZA
Fri Mar 29, 2019 5:44 am
So the best option/only option supplied would be to double up on the Pi.
Fri Mar 29, 2019 7:31 am
Correct. It's not good enough to run virtual machines.
This is a doctor free zone.
Gavinmc42
Fri Mar 29, 2019 8:30 am
I would have said no, but I have been running 32bit Raspbian and 64bit aarch64 Linux at the same time.
Very much bleeding edge and only a few like Sakaki know how to do it.
In the meantime you could use two Pi's and VNC into them.
Does Android have a VNC server app?
The problem I see with Android is the high optimization for web stuff will not work in Raspbian.
Browsers and Youtube are better optimized in Android.
PI's are getting there with OS's like Gentoo64 which is newer than the standard Raspbian Debian.
Pi's are cheap enough to use more than one and VNC is not bad.
I'm dancing on Rainbows.
ghans
Fri Mar 29, 2019 8:53 am
QEMU+KVM should make this possible.
https://github.com/sakaki-/gentoo-on-rp ... -under-KVM
ghans
code_exec
Wed Apr 10, 2019 8:35 pm
You can run two Linux distributions alongside each other by running one in a container and one natively. For example, you could run armhf Raspbian alongside arm64 Ubuntu. But since you're using Android here, things get more complicated. You could try UserLAnd (which I use on my Galaxy S9 with DeX mode) but 1GB RAM on the Pi could present a bottleneck.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
code_exec
Wed Apr 10, 2019 8:37 pm
He probably means that the RPF could just continue selling the Pi 3B+ and not launch an Pi 4B at all if the Pi 3B+ was powerful enough for the task of running two operating systems side by side.
Return to “Other”
