geosapien wrote: ↑Wed Jan 02, 2019 10:00 pm
Koop,
I am an RF technician with alot of free time on my hands, so my boss handed me a raspberry pi and told me to make an encoder out of it. I think i am a little greener than you are.....
Ultimately i will need to use FFMPEG and push the stream via UDP to a client server on a local network, but getting the thing to work at all is step 1.
Here is my new error...
pi@raspberrypi:~/yavta $ ./yavta --capture=1000 -n 3 --encode-to=file.h264 -f UYVY -m -T /dev/video0
We're encoding to file.h264
Device /dev/video0 opened.
Device `unicam' on `platform:unicam 3f801000.csi1' (driver 'unicam') is a video capture (without mplanes) device.
stride is 0
stride is now 1280
Video format set: UYVY (59565955) 640x480 (stride 1280) field none buffer size 614400
Video format: UYVY (59565955) 640x480 (stride 1280) field none buffer size 614400
Unable to get frame rate: Inappropriate ioctl for device (25).
vc.ril.isp:in:0(UYVY)(0x158efb0)type: video, fourcc: UYVY bitrate: 0, framed: 0 extra data: 0, (nil) width: 640, height: 480, (0,0,640,480) pixel aspect ratio: 0/0, frame rate: 0/0 buffers num: 3(opt 1, min 1), size: 614400(opt 614400, min: 614400), align: 0Created pool of length 3, size 0
Enable encoder....
Create pool of 3 buffers of size 0 for render
Create pool of 3 buffers of size 0 for encode ip
Create pool of 3 buffers of size 460800 for encode/render
Writing data to file.h264
Create pool of 8 buffers of size 262144
Sent buffer 0x1598d58Sent buffer 0x1598f30Sent buffer 0x1599108Sent buffer 0x15992e0Sent buffer 0x15994b8Sent buffer 0x1599690Sent buffer 0x1599868Sent buffer 0x1599a403 buffers requested, V4L2 returned 3 bufs.
length: 614400 offset: 0 timestamp type/source: mono/EoF
Buffer 0/0 mapped at address 0x7246a000.
Importing DMABUF 8 into VCSM...
...done. vcsm_handle 155648
Exported buffer 0 to dmabuf 8, vcsm handle 155648
Linking V4L2 buffer index 0 ptr 0x159a760 to MMAL header 0x15954c0. mmal->data 0xC0000003
length: 614400 offset: 614400 timestamp type/source: mono/EoF
Buffer 1/0 mapped at address 0x723d4000.
Importing DMABUF 9 into VCSM...
...done. vcsm_handle 159744
Exported buffer 1 to dmabuf 9, vcsm handle 159744
Linking V4L2 buffer index 1 ptr 0x159a7d0 to MMAL header 0x1595698. mmal->data 0xC0000004
length: 614400 offset: 1228800 timestamp type/source: mono/EoF
Buffer 2/0 mapped at address 0x7233e000.
Importing DMABUF 10 into VCSM...
...done. vcsm_handle 163840
Exported buffer 2 to dmabuf 10, vcsm handle 163840
Linking V4L2 buffer index 2 ptr 0x159a840 to MMAL header 0x1595870. mmal->data 0xC0000005
select timeout
