digger72
ArduinoPixed - Potential Topic to cover in MagPi
Thu Feb 01, 2018 2:33 pm
I launched my project ArduinoPixed on Kickstarter - it adds 3 USB ports and an on board Arduino off the 4th USB port of the Hub. All this using just 4 Mounting holes. None of the 40 Pin connectors are used and these are available for anything that users may want to do.
The details can be found on kickstarter here - https://www.kickstarter.com/projects/17 ... r-pi-zero/
This is a topic worth covering in MagPi. I have couple of Rev A boards that I can give out if required to get into details of it. This is a sequel to my popular Hubpixed project - the first of its kind Hub for Raspberry Pi Zero.
robthez
Re: ArduinoPixed - Potential Topic to cover in MagPi
Mon Feb 12, 2018 11:15 am
Hi - it's better if you email me about this stuff than post in the forum! My email is rob.zwetsloot@raspberrypi.org :)
digger72
Fri Oct 19, 2018 1:44 pm
Hi Rob,
I sent you couple of emails. Not sure if you received it.
Best Regards,
digger72
Thu Mar 21, 2019 11:52 pm
Just wanted to let everyone know that ArduinoPixed has been covered in the March 2019 Issue of MagPi. You can read online here - https://www.raspberrypi.org/magpi/arduinopixed-review/
Return to “The MagPi”
