"Configuration" is per user (it creates a config file in the user's home directory)jpezz wrote: ↑Sun Feb 03, 2019 3:11 pmI read the manual and did a search of this topic and I'm still confused. It appears there is only one place to have all the configuration settings (such as homepage and options set. It also appears one could start kweb with the options and homepage on the command line. What I can't find is a way to set a per-user version of all this so when I configure the kiosk user (or any other user), the settings are all read from a local file in the user's home directory customized for that user or read based on the command line or an environment variable. Right now, one must put in the admin password to make any changes and that means the changes would be the same for all users.
This browser appears to be perfect for my needs otherwise.
"Settings" are variables used by different tools of the kweb suite (kwebhelper, ytdl-server and omxplayerGUI). The settings are global, but both the ytdl-server and omxplayerGUI can be started using a different settings file (command line option).
