Ultibo
Updated revision information for CM3+
Tue Jan 29, 2019 11:29 pm
Just a prompt for someone with the relevant information available (James ?) to update the Revision codes page on GitHub with the latest information for the new CM3+
Assuming that everything else can be determined from the schematic and the device tree data, the revision code should be all that is needed to correctly identify the new board from code.
Thanks in advance.
Ultibo.org | Make something amazing
https://ultibo.org
Threads, multi-core, OpenGL, Camera, FAT, NTFS, TCP/IP, USB and more in 3MB with 2 second boot!
Re: Updated revision information for CM3+
Wed Jan 30, 2019 10:43 am
Yes, already aware, just waiting to confirm the exact revison code number, so will be updated today.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
Wed Jan 30, 2019 10:53 am
And done, should move from github to live within an hour.
Ultibo
Thu Jan 31, 2019 1:33 am
Excellent, thank you!
https://ultibo.org
