moojuiceuk
Pi TV Hat questions
Fri Nov 23, 2018 12:46 am
Just got a Pi TV hat working - so far so good.
Does anyone know what the 2-pin header on the PCB is used for that I've circled in red below...?
Is it possible to use more than 1 tuner card stacked up? Can multiple devices share an SPI bus?
Can it also receive DAB radio streams? Looking at the spec, VHF Band III is supported (174 - 230MHz) which is the same frequency allocation as DAB in the UK. If so, what software is used for that?
Has anyone managed to exploit the Sony chip as a true SDR and if so, what frequencies can it cover?
noggin
Re: Pi TV Hat questions
Sun Nov 25, 2018 12:00 pm
I asked. It's apparently for programming the HAT ID EEPROM with the correct contents during manufacture. Nothing useful for end users.
Official HATs have an ID EEPROM that is read via I2C so that the Pi knows which HAT is connected and loads the correct drivers/device tree?
ViacheslavGrytsyk
Fri Jan 11, 2019 9:56 am
Hello to All!
Can I get data from CXD2880 about Signal Quality such as MER (Modulation Error Ratio)? SNR (Signal-to-Noise Ratio) and CNR (Carrier-to-Noise Ratio) as additional parameters of quality. How if possible? Thanks!
jaket91
Sun Jan 13, 2019 10:34 pm
Did anybody discover whether multiple TV hats can be connected to the GPIO of the same Pi?
Mon Jan 14, 2019 1:29 am
They can't work because both would use the same SPI chip select/chip enable pin unless you can change the hardware (which isn't possible for a hobbyist).
If you look in https://github.com/raspberrypi/linux/bl ... verlay.dts you'll see which pins are used.
This is a doctor free zone.
JanSyk
Sun Jan 20, 2019 7:04 pm
Hi
I´m solving similar problem with not working raspberry TV tuner
Actual configuration is:
RPi3 + hifiberry Digi+ and Raspberry TV tuner
If there is connected only RPi3 and raspberry TV tuner without hifiberry Digi + it is working, but all together I can´t see in TVheadend any tuners.
I think problem is how to switch raspberry TV tuner to second raspberry SPI port (Hifiberry also working over SPI)
My logs:
https://paste.osmc.tv/ehakidogol
Anybody have same configuration?
Thanks for your help
Jan
hippy
Sun Jan 20, 2019 10:26 pm
I don't see why it isn't possible for a hobyist. Hardware-wise it would be easy enough to build a T-shaped strip-board / vero-board / PCB construct which routes GPIO to two or more tuners with separate SPI enable to each.. And there may be add-ons available which can do that.
As to whether any software would support that having done it; I have no idea.
cellipo
Sat Sep 14, 2019 8:22 am
Hi
My logs:
Jan
JanSyk did you solve the problem? i am in the same situation with a pi tv hat and a hifiberry digi+ pro.
the hifiberry seems to work fine while the tv hat disappeared from tvheadend.
Anyone does know how to make these two hats working togheter?
tonyfixit
Sat Jan 18, 2020 9:38 am
Same problem here. TV hat work with tvHeadEnd when installed on its own, hifiBerry works when installed on its own. When the other is added (I have tried the hifiberry first, then the TV hat and the other way round) In either case the hifiberry either disappears from the audio menu, or is on the menu, but does not work. I have searched the internet and tried the suggested 'solutions; to no avail. Not reloaded tvHeadEnd if the audio failed, so I don't know if the TV hat would still work.
Using PI4, PI TV HAT, official PSU and hifiBerry DAC+.
Buster loaded from official image, and then updated to latest version, but no other changes to software except make it "headless" (/boot/config.txt). Also set VNC, SSH, I2C and SPI active in Configuration.-> Interfaces because, as I understand it, the TV hat uses SPI and the hifiBerry uses I2C.
I have used Kodi and Plex, but these make no difference (this is where the issues showed initially as I used the TV Hat first, then bought the hifiBerry).
So why the conflict? Any ideas out there?
Tony
