Thanks this helps a lot, my only question is to record IPTV can you use the back end software OR hardware or do you need both.
Ok thanks that makes sense, yes I'm using Libreelec and I tvheadend is already there. Looks like I'll be in the market for a tuner now!default_user8 wrote: ↑Fri Dec 28, 2018 8:56 pmYou will need a tuner(HDHomerun) pointed at at backend, typically something like TVheadend. If you used the Libreelec image for kodi tvheadend is already installed you just need to choose which one you want to use and enable it.
https://kodi.wiki/view/Add-on:IPTV_Simple_Clientthadaddyy wrote: ↑Fri Dec 28, 2018 9:41 pmOk thanks that makes sense, yes I'm using Libreelec and I tvheadend is already there. Looks like I'll be in the market for a tuner now!default_user8 wrote: ↑Fri Dec 28, 2018 8:56 pmYou will need a tuner(HDHomerun) pointed at at backend, typically something like TVheadend. If you used the Libreelec image for kodi tvheadend is already installed you just need to choose which one you want to use and enable it.
Oh yeah I've used IPTV Simple Client, it works great for watching IPTV but my issue was recording something from the guide (without a tuner).fruitoftheloom wrote: ↑Fri Dec 28, 2018 10:38 pmhttps://kodi.wiki/view/Add-on:IPTV_Simple_Clientthadaddyy wrote: ↑Fri Dec 28, 2018 9:41 pmOk thanks that makes sense, yes I'm using Libreelec and I tvheadend is already there. Looks like I'll be in the market for a tuner now!default_user8 wrote: ↑Fri Dec 28, 2018 8:56 pmYou will need a tuner(HDHomerun) pointed at at backend, typically something like TVheadend. If you used the Libreelec image for kodi tvheadend is already installed you just need to choose which one you want to use and enable it.
Should be all you need to watch IPTV ?? have you tried ??
thadaddyy wrote: ↑Sat Dec 29, 2018 12:32 amOh yeah I've used IPTV Simple Client, it works great for watching IPTV but my issue was recording something from the guide (without a tuner).fruitoftheloom wrote: ↑Fri Dec 28, 2018 10:38 pmhttps://kodi.wiki/view/Add-on:IPTV_Simple_Client
