jwzumwalt wrote: ↑Mon Oct 07, 2013 5:55 am
I became very frustrated in my attempts to disable the screen saver. I finally found that there are two steps to this. The bash (shell) text terminal has its own blanking software, while the Xserver uses independant graphic settings.
To add to the frustration, many recommendations just don't work on the Raspbian version of Debian, or (as I found out) Raspbian used different files.
To view your Xsession screen saver setting, use this command (must be used from xterminal)
xset q
In brief, this is what must be done for Raspbian...
Disable text terminals from blanking
change two settings in
/etc/kbd/config
BLANK_TIME=0
POWERDOWN_TIME=0
Disable Xsession from blanking
Additional info
https://wiki.archlinux.org/index.php/Di ... _Signaling
Add these lines to
/etc/xdg/lxsession/LXDE/autostart
@xset s noblank
@xset s off
@xset -dpms
UpDate: (Jan 27th, 20115) - I just received an email from "Dirk" saying the file location has changed...
The file changed from
/etc/xdg/lxsession/LXDE/autostart -to-
/etc/xdg/lxsession/LXDE-pi/autostart
If the file location has changed on the version you are using, the script will need to be edited
Here is a script that will permanently disable Xsession blanking
no_blank.sh
#!/bin/bash
NOBLANK="
@xset s noblank
@xset s off
@xset -dpms
# Pretty ANSI text colors
OFF="\033[0m"
BOLD="\033[1m"
DIM="\033[2m"
RED="\033[1;31m"
GREEN="\033[1;32m"
YELLOW="\033[1;33m"
BLUE="\033[1;34m"
clear
printf "\n\n\t $YELLOW "; date ; printf "$OFF"
printf "\n $GREEN"
printf "\t +------------------------------------------------+\n"
printf "\t | no_blank.sh |\n"
printf "\t | rev Oct 1, 2013 |\n"
printf "\t | |\n"
printf "\t | by: Jan Zumwalt - net-wrench.com |\n"
printf "\t | |\n"
printf "\t | This script permanently disables the xsession |\n"
printf "\t | screen saver for RASPBIAN PI OS. It allows |\n"
printf "\t | the user to abort before any change is made. |\n"
printf "\t +------------------------------------------------+$OFF\n\n"
printf "\t This program will disable your xsession\n"
printf "\t screen saver permanently, is this what \n"
printf "\t you really want to do? $YELLOW<y/n>$OFF"; read -n 1 KEYIN
if [[ $KEYIN == "N" || $KEYIN == "n" ]]; then
printf "\n\n\t OK, I quit and did not do anything.\n\n"
exit 0
fi
printf "\n\n\t I intend to modify your current \n"
printf "\t /etc/xdg/lxsession/LXDE/autostart \n"
printf "\t I will add the$GREEN GREEN$OFF lines to the file...\n\n"
printf "$DIM\n"
pr -t -o 9 /etc/xdg/lxsession/LXDE/autostart
printf "$OFF$GREEN$NOBLANK" | pr -t -o 9
printf "$OFF\n\n"
printf "\t Is this really what you want to do? $YELLOW<y/n>$OFF"; read -n 1 KEYIN
exit 0
fi
cat /etc/xdg/lxsession/LXDE/autostart > /etc/xdg/lxsession/LXDE/autostart.`date +%m-%d-%Y_%I:%M:%S`
printf "\n\t Created backup copy of the autostart file...\n"
printf "$NOBLANK" >> /etc/xdg/lxsession/LXDE/autostart
printf "\t Your new file looks like this\n"
printf "$DIM\n"
printf "$OFF\n\n"
printf "\t$RED Modified file. Screensaver is now disabled.$OFF\n"
# required so xterm will not close
printf "\n\t press any key to exit: "; read -n 1 KEYIN
printf "\t$GREEN Program ended normaly $OFF\n\n"
For completeness here are the other methods that reportedly worked for other OS.
Stop Screen Blanking
1 & 2 work for the Raspbian
1) Stop
change in /etc/kbd/config these two:
BLANK_TIME=0
POWERDOWN_TIME=0
2) Stop Xsession from blanking
Additional info
Add these lines to /etc/xdg/lxsession/LXDE/autostart
@xset s noblank
@xset s off
@xset -dpms
A) Change your ~/.xinitrc or /etc/X11/xinit/xinitrc or /etc/xdg/lxsession/LXDE/autostart
NOTE: attempting to create a ~/.xinitrc and use in Raspbian crashed my Xserver
@xset s noblank
@xset s off
@xset -dpms
B) Change the /etc/lightdm/lightdm.conf and paste under the [SeatDefault]
xserver-command=X -s 0 dpms
"only effective if you boot straight into X using that particular display manager."
C) Use the xdotool to send a benign keyboard input to midori every ten minutes e.g. over crontab
...not a real solution, but it could work for my purpose.
D) Use a Display-Manager such as LXDE and run your browser there. User coolblue2000
had the same issue and finally went the way over a window manager, disabling the panel
(menu bar at the bottom) and setting the background picture to black - so you can't
see the whole LXDE. Here's a description:
http://pikiosk.tumblr.com/post/38721623 ... -static-ip
-- This will use more CPU - if anybody tries this, please leave a comment how much.
I'm really short of CPU, so I don't want to run an unnecessary windowmanager just to
prevent a screensaver...
E) Create a shell script disableblank.sh that runs the xset commands and add an entry
in .config/autostart/ calling that script. That way, everything is started with the
same method and either both work or neither works.
