CookieGamez2018
Keypad Passcode
Sun Dec 09, 2018 9:36 pm
i need some help with setting up a pass-code with my raspberry pi. i would like it to be a four digit code that you enter on the keypad and it prints "access granted" if right and "access denied" if wrong. any help would be great!
my code so far, it prints the button you hit:
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
MATRIX = [
     [1,2,3,'A'],
     [4,5,6,'B'],
     [7,8,9,'C'],
     ['*',0,'#','D']
ROW = [3,5,8,10]
COL = [19,21,23,24]
for j in range(4):
    GPIO.setup(COL[j], GPIO.OUT)
    GPIO.output(COL[j], 1)
for i in range(4):
    GPIO.setup(ROW[i], GPIO.IN, pull_up_down = GPIO.PUD_UP)
try:
    while(True):
        for j in range(4):
            GPIO.output(COL[j],0)
            for i in range(4):
                if GPIO.input(ROW[i]) == 0:
                    print (MATRIX[i][j])
                    time.sleep(0.2)
                    while(GPIO.input(ROW[i]) == 0):
                        pass
            GPIO.output(COL[j],1)
except KeyboardInterupt:
    GPIO.cleanup()
Last edited by CookieGamez2018 on Thu Dec 13, 2018 12:13 am, edited 3 times in total.
Andyroo
Re: Keypad Passcode
Mon Dec 10, 2018 11:42 am
Welcome to the forum.
What keypad do you have?
Could please edit your post so the code is in the 'code' tag:
[ c o d e ] Python goes here [ / c o d e ]
(without the spaces by using the </> button>)
Then we can see the indents in the program - these are vital for Python :lol:
scotty101
Re: Keypad Passcode
Mon Dec 10, 2018 11:57 am
import time
MATRIX = [
     [1,2,3,'A'],
     [4,5,6,'B'],
     [7,8,9,'C'],
     ['*',0,'#','D']
ROW = [3,5,8,10]
COL = [19,21,23,24]
for j in range(4):
for i in range(4):
try:
    while(True):
        for j in range(4):
            for i in range(4):
                    time.sleep(0.2)
                        pass
    GPIO.cleanup()
Does your code currently work? As in does it print out the correct key when you press a button?
If so, all you need to do is add each key pressed to a list and compare the contents of the list to another list that contains the correct password.
Might look something like
#Start with a blank list
userEntry = []
# Define the correct answer
correctKey = [1,2,3,4]
#Add the pressed key to the list
userEntry.append(MATRIX[i][j])
#compare the length of the list of entered keys against the correct answer
if len(userEntry) == len(correctKey):
    #If they match, check to see if the value is correct
    if userEntry == correctKey:
        print("Correct")
    else:
        print("Incorrect!!")
    #Clear the list for next time.
    userEntry.clear()
Andyroo
Re: Keypad Passcode
Mon Dec 10, 2018 12:02 pm
@scotty101 - I hope your indents match his as that could be part of his problem :lol: :mrgreen:
scotty101
Re: Keypad Passcode
Mon Dec 10, 2018 12:17 pm
Not sure what you mean.
Andyroo
Re: Keypad Passcode
Mon Dec 10, 2018 7:29 pm
Apologies - spent part of the weekend sorting a working program where my indentation did not match the original and that was the issue - only when it was posted in code blocks did I find it :oops:
CookieGamez2018
Re: Keypad Passcode
Wed Dec 12, 2018 6:54 pm
import time
MATRIX = [
     [1,2,3,'A'],
     [4,5,6,'B'],
     [7,8,9,'C'],
     ['*',0,'#','D']
ROW = [3,5,8,10]
COL = [19,21,23,24]
for j in range(4):
for i in range(4):
try:
    while(True):
        for j in range(4):
            for i in range(4):
                    time.sleep(0.2)
                        pass
    GPIO.cleanup()
userEntry = []
        print("Correct")
    else:
    userEntry.clear()
Yes it does print the correct key that I press. also where would i put the code that you provided
Last edited by CookieGamez2018 on Thu Dec 13, 2018 1:49 am, edited 1 time in total.
CookieGamez2018
Re: Keypad Passcode
i am using a 4x4 keypad
scotty101
Re: Keypad Passcode
Thu Dec 13, 2018 9:43 am
Did you try using the code example I provided?
CookieGamez2018
Re: Keypad Passcode
Thu Dec 13, 2018 9:02 pm
Yes it did work thank you so much
CookieGamez2018
Re: Keypad Passcode
Thu Dec 13, 2018 9:04 pm
Thank you Scotty101 so much for helping me and solving the problem :D
Return to “Python”
