ahududu
Raspbian Stretch 2018-11-13 Repository Problem
Mon Dec 03, 2018 12:19 am
Hi All,
Hope you are fine. I downloaded from https://downloads.raspberrypi.org/raspbian_latest, then burned it, installed it.
Then i updated it via apt-get update, apt-get dist-upgrade, apt-get upgrade and rpi-update.
I was trying to install Tor and realized it's version. It's version is 0.2.9.16-1. I checked from https://dist.torproject.org/ and as i see it is too old version.
Then i looked my sources.list file:
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
I checked from this website https://dist.torproject.org/ and the latest stable version is 0.3.4.9
I used apt-get update tor --reinstall command for reinstall and fetch new version but it installed again 0.2.9.16-1, i couldn't understand.
Could you please help me about this issue?
Re: Raspbian Stretch 2018-11-13 Repository Problem
Mon Dec 03, 2018 6:20 am
Hi All,
First and foremost rpi-update install a testing kernel / firmware and has not been recommended for ages, as it does and can break Raspbian Stretch. The following is sufficient:
sudo apt update
sudo apt full-upgrade
Regards the TOR package Raspbian Stretch follows Debian Stretch ARMHF so unless you want to compile a newer version yourself you will get version 0.2.9.16-1
https://packages.debian.org/stretch/tor
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
ahududu
Wed Dec 05, 2018 3:11 am
Hi All,
sudo apt update
Thank you for your interest.
Is there a way to downgrade original kernel?
And as i understand Raspbian Stretch follows Debian Stretch ARMHF and stable version is 0.2.9.16-1, right? This means i shouldn't compile newer version of Tor.
Return to “Raspbian”
