Google Keyboard (Gboard)Paul Webster wrote: ↑Fri Oct 19, 2018 6:22 pm... and shipping packaging shows uHat (can’t find the micro symbol on phone keyboard) confirming the new name.
DarkPlatinum wrote: ↑Fri Oct 19, 2018 6:58 pmHow much beter is this from this since they are similarly priced ?https://shop.pimoroni.com/products/mini ... l-tv-stick
Might be rpi fault or tuner fault?fruitoftheloom wrote: ↑Fri Oct 19, 2018 7:38 pmDarkPlatinum wrote: ↑Fri Oct 19, 2018 6:58 pmHow much beter is this from this since they are similarly priced ?https://shop.pimoroni.com/products/mini ... l-tv-stick
When I had a RPi 1B+ did try a similar TV Stick, but experienced power issues and picture lag. The OS was Raspbian Wheezy.
The hat does DVB-T2, HD.DarkPlatinum wrote: ↑Fri Oct 19, 2018 6:58 pmHow much beter is this from this since they are similarly priced ?https://shop.pimoroni.com/products/mini ... l-tv-stick
DarkPlatinum wrote: ↑Fri Oct 19, 2018 7:40 pmMight be rpi fault or tuner fault?fruitoftheloom wrote: ↑Fri Oct 19, 2018 7:38 pmDarkPlatinum wrote: ↑Fri Oct 19, 2018 6:58 pmHow much beter is this from this since they are similarly priced ?https://shop.pimoroni.com/products/mini ... l-tv-stick
I'm using official 2 amp pi power supplyjamesh wrote: ↑Fri Oct 19, 2018 2:45 pmThat sounds like a power supply problem. What are you using?riggo wrote: ↑Fri Oct 19, 2018 2:29 pmrecieved my tv hat this afternoon, followed the tutorial on PiHut to set up Tvheadend but the hat seems to kill the Pi's wifi, when the hat is removed the Pi connects to the network no problem, happens with Pi0w and Pi3. haven't tried ethernet yet, need to investigate further, hope I've not got a duff.
[54163.601735] Under-voltage detected! (0x00050000)
riggo wrote: ↑Sat Oct 20, 2018 11:05 amI'm using official 2 amp pi power supplyjamesh wrote: ↑Fri Oct 19, 2018 2:45 pmThat sounds like a power supply problem. What are you using?riggo wrote: ↑Fri Oct 19, 2018 2:29 pmrecieved my tv hat this afternoon, followed the tutorial on PiHut to set up Tvheadend but the hat seems to kill the Pi's wifi, when the hat is removed the Pi connects to the network no problem, happens with Pi0w and Pi3. haven't tried ethernet yet, need to investigate further, hope I've not got a duff.
Looks good. ThanksDougieLawson wrote: ↑Fri Oct 19, 2018 5:31 pmhttps://thepihut.com/products/flirc-usb ... spberry-pi looks like it's designed for the job (although it costs the same as the DVB TV μHAT).
DarkPlatinum wrote: ↑Sat Oct 20, 2018 6:23 pmWhat channels can you get from freeview anyway? anything worth watcing?
Thanks.fruitoftheloom wrote: ↑Sat Oct 20, 2018 6:25 pmDarkPlatinum wrote: ↑Sat Oct 20, 2018 6:23 pmWhat channels can you get from freeview anyway? anything worth watcing?
https://www.freeview.co.uk/tv-guide
Can't comment on that but the link from that page to something cheap (£10/£12-inc-VAT) which can do ADS-B real-time plane tracking is of interest to me seeing as I can't get a decent DVB-T signal where I am, and don't do streaming anyway, but am just a few miles from an international airport and under an incoming flight path -DarkPlatinum wrote: ↑Fri Oct 19, 2018 6:58 pmHow much beter is this from this since they are similarly priced ?https://shop.pimoroni.com/products/mini ... l-tv-stick
Expensive no?gordon77 wrote: ↑Sat Oct 20, 2018 2:17 pmLooks good. ThanksDougieLawson wrote: ↑Fri Oct 19, 2018 5:31 pmhttps://thepihut.com/products/flirc-usb ... spberry-pi looks like it's designed for the job (although it costs the same as the DVB TV μHAT).
Did you mean you can, or can't get a good signal? Im planning on buying that one for flight tracking and getting a free business account with flightradar24hippy wrote: ↑Sat Oct 20, 2018 7:42 pmCan't comment on that but the link from that page to something cheap (£10/£12-inc-VAT) which can do ADS-B real-time plane tracking is of interest to me seeing as I can't get a decent DVB-T signal where I am, and don't do streaming anyway, but am just a few miles from an international airport and under an incoming flight path -DarkPlatinum wrote: ↑Fri Oct 19, 2018 6:58 pmHow much beter is this from this since they are similarly priced ?https://shop.pimoroni.com/products/mini ... l-tv-stick
https://shop.pimoroni.com/products/dvb- ... e-tracking
