6by9
Re: hw-encode opengl output without glReadPixels in 2018 ("fastpath")?
Tue Oct 02, 2018 4:56 pm
dickon wrote:
Tue Oct 02, 2018 3:44 pm
It's quite astonishing. The work you lot at Pi Towers have done is incredible.
12b 8k p60 H.265 (encode and decode) is all I want from a new Pi. Please :-)
:D :D :D :D :o
tvjon
Wed Oct 03, 2018 8:18 am
" I hope my example project on github can help others on that matter...."
It certainly does, thank you. Your README contains helpful info' too.
This entire thread is useful.
Incidentally, only one example,
connection_decode_encode
fails using
-O3 (or2)
-01 works
It builds without errors, but runs thus:
$ ./connection_decode_encode
fourcc: I420, variant; width: 1280, height: 720, (0,0,1280,720)
start transcoding
stop transcoding
so generates an empty out.h264
All the others build & run fine using -O3
$ gcc -v
Using built-in specs.
gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)
6by9
Wed Oct 03, 2018 8:28 am
Probably the same issue I hit - eos_received isnt initialised so it will randomly immediately abort.
Return to “OpenMAX”
