I'm using
http://www.ebay.co.uk/itm/3-5v-ADXL345- ... 1074086394.
Works fine with I2C on the raspberry.
You need to enable the i2c module
sudo modprobe i2c-dev
sudo chmod o+rw /dev/i2c*
The module I use needs CS tied to VCC and SDO tied to ground.
I use the following code to read a SRF02 and the ADXL345 on the same I2C bus.
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
#include <string.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <linux/i2c-dev.h>
#define SRF02_I2C_ADDR 0x70
#define ADXL345_I2C_ADDR 0x53
void selectDevice(int fd, int addr, char * name)
if (ioctl(fd, I2C_SLAVE, addr) < 0)
fprintf(stderr, "%s not present\n", name);
//exit(1);
void writeToDevice(int fd, int reg, int val)
char buf[2];
buf[0]=reg; buf[1]=val;
if (write(fd, buf, 2) != 2)
fprintf(stderr, "Can't write to ADXL345\n");
//exit(1);
int main(int argc, char **argv)
unsigned int range;
int count, b;
short x, y, z;
float xa, ya, za;
int fd;
unsigned char buf[16];
if ((fd = open("/dev/i2c-0", O_RDWR)) < 0)
// Open port for reading and writing
fprintf(stderr, "Failed to open i2c bus\n");
exit(1);
/* initialise ADXL345 */
selectDevice(fd, ADXL345_I2C_ADDR, "ADXL345");
writeToDevice(fd, 0x2d, 0);
writeToDevice(fd, 0x2d, 16);
writeToDevice(fd, 0x2d, 8);
writeToDevice(fd, 0x31, 0);
writeToDevice(fd, 0x31, 11);
while (1)
/* select SRF02 */
selectDevice(fd, SRF02_I2C_ADDR, "SRF02");
buf[0]=0; buf[1]=81;
if ((write(fd, buf, 2)) != 2)
fprintf(stderr, "Can't write to SRF02\n");
//exit(1);
usleep(100000); // wait long enough to ensure ping
buf[0] = 0;
if ((write(fd, buf, 1)) != 1)
//exit(1);
if (read(fd, buf, 4) != 4)
fprintf(stderr, "Can't read from SRF02\n");
//exit(1);
else
range = buf[2]<<8 | buf[3];
printf("%3u ", range);
/* select ADXL345 */
buf[0] = 0x32;
// Send the register to read from
fprintf(stderr, "Error writing to i2c slave\n");
//exit(1);
if (read(fd, buf, 6) != 6)
// X, Y, Z accelerations
fprintf(stderr, "Unable to read from ADXL345\n");
//exit(1);
else
x = buf[1]<<8| buf[0];
y = buf[3]<<8| buf[2];
z = buf[5]<<8| buf[4];
xa = (90.0 / 256.0) * (float) x;
ya = (90.0 / 256.0) * (float) y;
za = (90.0 / 256.0) * (float) z;
//printf("x=%d, y=%d, z=%d\n", x, y, z);
printf("%4.0f %4.0f %4.0f\n", xa, ya, za);
//for (b=0; b<6; b++) printf("%02x ",buf[b]); printf("\n");
usleep(900000);
return 0;
