roe1974
Changing LED (ex. Heartbeat) when service is active/running
Thu Jul 26, 2018 6:55 am
I want to change die green LED to heartbeat when a certain service (homebridge) is up and running and turn it of when homebridge is stopped ....
Is this possible ?
Richard
lmarmisa
Re: Changing LED (ex. Heartbeat) when service is active/running
Thu Jul 26, 2018 1:27 pm
You will need to develop a script. This command will help:
service --status-all | grep homebridge
These other commands could be more useful:
service --status-all | grep homebridge | cut -d' ' -f3
status=$(service --status-all | grep homebridge | cut -d' ' -f3)  #the variable status will contain a char "+" if the service homebridge is running
https://askubuntu.com/questions/407075/ ... ll-results
roe1974
Thu Jul 26, 2018 2:06 pm
its a systemd service an is not listed @
sudo service --status-all
and i am not able to write a "script " :-(
any helo out there ?
Richard
lmarmisa
Thu Jul 26, 2018 2:09 pm
Richard
Hi Richard,
what about this command?
ps -ef | grep homebridge
roe1974
Thu Jul 26, 2018 2:33 pm
yes....
here the result:
avahi      316     1  0 12:35 ?        00:00:08 avahi-daemon: running [homebridge-raspi.local]
root       485     1  0 12:35 ?        00:02:20 homebridge
pi        1202   879  0 16:31 pts/0    00:00:00 grep --color=auto homebridge
and now ?
Richard
lmarmisa
Thu Jul 26, 2018 3:10 pm
One question, Richard. How do you launch the program homebridge?.
roe1974
Thu Jul 26, 2018 6:14 pm
systemd service......
as described here:
http://pysselilivet.blogspot.com/2017/0 ... stemd.html
regards, richard
lmarmisa
Fri Jul 27, 2018 2:01 pm
This is a starting point for your script:
#!/bin/bash
ps -A | grep -q homebridge
if [ $? -eq 0 ]; then
  echo "LED on"
else
  echo "LED off"
fi
exit 0
If homebridge is running, the outputl will show LED on. If homebridge is not running, the output will be LED off.
If you want to use this shell script, follow this procedure:
1) Create a bin directory for binaries and scripts:
mkdir -p ~/bin
2) Update your environment running this command:
. ~/.profile
3) Edit the script file:
nano ~/bin/ledcontrol.sh
Copy the text, save and exit.
4) Give exec permission to script
chmod +x ~/bin/ledcontrol.sh
5) Run the script:
ledcontrol.sh
The script is not complete. You should substitute the command echo with an appropriate command for controlling the LED.
roe1974
Fri Jul 27, 2018 8:19 pm
ok !!!! .... thx a lot !!!!!!!
will try it and come back with feedback ;-)
greetings from vienna
richard
roe1974
Sat Jul 28, 2018 7:11 am
ok...works......
but how/when running the script .... with cron job ?
Richard
lmarmisa
Mon Jul 30, 2018 3:39 pm
ok...works......
Richard
Of course, you can use cron. Type the command:
crontab -e
For example, if you want to run your script every two minutes, add an entry like this:
*/2 * * * * /home/pi/ledcontrol.sh
If you prefer a period lower than 60 seconds, you will have to modify your script. This is an example:
#!/bin/bash
while true; do
  ps -A | grep -q ntp
    echo "LED on"
  else
    echo "LED off"
  fi
  sleep 10
done
Then define an entry like this on crontab:
@reboot /home/pi/ledcontrol.sh
