Xavier Darkwell wrote: ↑Mon May 28, 2018 10:50 amHow do I use a raspberry pi 3 as a Ethernet to hdmi converter.
We don't know what you want to do; we're not mind readers.Xavier Darkwell wrote: ↑Mon May 28, 2018 10:50 amHow do I use a raspberry pi 3 as a Ethernet to hdmi converter.
you gave not much more info, but it seems to be a very "naive" question.I have the Pc connected to the raspberry pi with an Ethernet cable. The raspberry pi is connected to the tv with an hdmi cable. I'm trying to use this method to use my tv as a monitor since my vga cable is broken.
Xavier Darkwell wrote: ↑Mon May 28, 2018 12:21 pmI have the Pc connected to the raspberry pi with an Ethernet cable. The raspberry pi is connected to the tv with an hdmi cable. I'm trying to use this method to use my tv as a monitor since my vga cable is broken.
No. First of all, you would need to find a way to make the PC output its video to Ethernet.Xavier Darkwell wrote: ↑Mon May 28, 2018 4:49 pmI was wondering if I could program the raspberry pi to be a Ethernet to hdmi video converter.
You cannot program a RPi or anything else to be an "ethernet to HDMI converter" because there is no such thing as an ethernet to HDMI converter.Xavier Darkwell wrote: ↑Mon May 28, 2018 4:49 pmSo remote software is required? I was wondering if I could program the raspberry pi to be a Ethernet to hdmi video converter.
The simplest, easiest and least expensive method. And it will not introduce additional jerkiness which the VNC and other remote desktop methods could.
