Okay, let’s start again as I’m getting confused with all your valuable feedback.
The PSU used and the SD are OK and they’re also working fine with a Raspberry Pi 1 B+ device. Thus, I may exclude any hardware problems here.
I flashed the SD card again with the Raspbian Stretch image of November 2017, just put the “ssh” and the same “wpa_supplicant.conf” files on the top level directory of the SD card.
Gently put the SD card in the reader of the Raspberry Pi Zero W device, and powered it on with the same PSU as used before with the Raspberry Pi 1 B+ device.
The green LED is flashing, thus some activity is going on there (i.e. partition resizing), after I while I can discover the device with my Wifi radar application on my PC and can connect to the Raspberry Pi Zero W device (maybe I missed to mention this somewhere in the initial post, but hey, the device always worked fine for me in the past) using SSH.
As proof, here the relevant entries of the “
/var/log/syslog” file:
Nov 29 02:56:34 raspberrypi kernel: [ 0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Nov 29 02:56:43 raspberrypi dhcpcd-run-hooks[382]: wlan0: starting wpa_supplicant
Nov 29 02:56:49 raspberrypi dhcpcd[355]: wlan0: waiting for carrier
Nov 29 02:56:49 raspberrypi dhcpcd[355]: wlan0: carrier acquired
Nov 29 02:56:52 raspberrypi dhcpcd[355]: DUID 00:01:00:01:21:b0:de:74:b8:27:eb:cb:76:07
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: IAID eb:cb:76:07
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: adding address fe80::a43f:84bf:ab99:1d32
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: carrier lost
Nov 29 02:56:52 raspberrypi dhcpcd[355]: wlan0: deleting address fe80::a43f:84bf:ab99:1d32
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: IAID eb:cb:76:07
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: adding address fe80::26c6:2f1b:ecd0:ca9e
Nov 29 02:57:30 raspberrypi dhcpcd[355]: wlan0: soliciting an IPv6 router
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: soliciting a DHCP lease
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: offered 192.168.0.31 from 192.168.0.254
Nov 29 02:57:31 raspberrypi dhcpcd[355]: wlan0: probing address 192.168.0.31/24
Nov 29 02:57:31 raspberrypi avahi-daemon[285]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::26c6:2f1b:ecd0:ca9e.
Nov 29 02:57:31 raspberrypi avahi-daemon[285]: New relevant interface wlan0.IPv6 for mDNS.
Nov 29 02:57:31 raspberrypi avahi-daemon[285]: Registering new address record for fe80::26c6:2f1b:ecd0:ca9e on wlan0.*.
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: leased 192.168.0.31 for 864000 seconds
Nov 29 02:57:35 raspberrypi avahi-daemon[285]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.31.
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: adding route to 192.168.0.0/24
Nov 29 02:57:35 raspberrypi dhcpcd[355]: wlan0: adding default route via 192.168.0.254
Nov 29 02:57:35 raspberrypi avahi-daemon[285]: New relevant interface wlan0.IPv4 for mDNS.
Nov 29 02:57:35 raspberrypi avahi-daemon[285]: Registering new address record for 192.168.0.31 on wlan0.IPv4.
Note: The date & time mention in the logs above are correct, as it is the 1st time boot of the image and the OS has not yet synchronised with an NTP source via Internet.
And here the relevant entries of the “
/var/log/kern.log” file:
Nov 29 02:56:46 raspberrypi kernel: [ 26.953253] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Nov 29 02:57:30 raspberrypi kernel: [ 70.654854] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Albeit my Wifi AP does not provide IPv6 services, the Raspberry Pi Zero W device connects correctly to my Wifi AP, and I can collect above log files with SSH through a Wifi connection.
On the same SSH prompt, I’m firing now the command “
sudo apt-get update ; sudo apt-get –y upgrade”, which shows the following output:
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org/debian stretch/main armhf Packages [139 kB]
Get:4 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [28.0 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian stretch/main armhf Packages [11.7 MB]
Get:6 http://mirrordirector.raspbian.org/raspbian stretch/contrib armhf Packages [56.8 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian stretch/non-free armhf Packages [95.2 kB]
Fetched 12.0 MB in 34s (349 kB/s)
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
wolfram-engine
The following packages will be upgraded:
base-files bind9-host bluez-firmware curl dbus dbus-user-session dbus-x11 erlang-base erlang-crypto erlang-syntax-tools firmware-atheros firmware-brcm80211
firmware-libertas firmware-misc-nonfree firmware-realtek gir1.2-gdkpixbuf-2.0 gstreamer1.0-omx gstreamer1.0-omx-rpi gstreamer1.0-omx-rpi-config gtk2-engines-clearlookspix
idle-python2.7 iproute2 libavcodec57 libavfilter6 libavformat57 libavresample3 libavutil55 libbind9-140 libcurl3 libcurl3-gnutls libdbus-1-3 libdns-export162 libdns162
libfm-data libfm-extra4 libfm-gtk-data libfm-gtk4 libfm-modules libfm4 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libicu57 libisc-export160 libisc160 libisccc140
libisccfg140 liblwres141 libobrender32v5 libobt2v5 libpoppler64 libpostproc54 libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libsqlite3-0
libssl1.0.2 libswresample2 libswscale4 libtasn1-6 libtiff5 libxcursor1 libxkbcommon-x11-0 libxkbcommon0 libxml2 lxpanel lxpanel-data lxplug-bluetooth lxplug-network
lxplug-ptbatt openbox openssh-client openssh-server openssh-sftp-server pcmanfm pi-bluetooth pipanel pishutdown poppler-utils python-scrollphathd python2.7 python2.7-dev
python2.7-minimal python3-scrollphathd raspberrypi-sys-mods raspberrypi-ui-mods raspi-config rc-gui rpd-icons rpi-chromium-mods rsync sensible-utils ssh tzdata
94 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 91.4 MB of archives.
After this operation, 1,169 kB of additional disk space will be used.
I reboot the device, once the all above cited OS packages updates have been completed. Some LED flashing activity is going on, then the LED stays steady lit.
Waited a while, however my Wifi radar cannot discover the device, a ping or SSH with the same known IP address not possible.
I unplug the PSU, remove the SD card from Raspberry Pi Zero W device, and insert it on the card reader of a Raspberry Pi 1 B+ device.
Powered it on, and it comes up without any problems allow me to connect via SSH to the device using Ethernet LAN.
Checking backwards the history of the “
/var/log/syslog” entries, I find the following:
Feb 9 11:45:33 raspberrypi kernel: [ 0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Feb 9 11:45:38 raspberrypi dhcpcd[283]: wlan0: waiting for carrier
Feb 9 11:45:38 raspberrypi dhcpcd[283]: wlan0: carrier acquired
Feb 9 11:45:38 raspberrypi dhcpcd[283]: DUID 00:01:00:01:21:b0:de:5a:b8:27:eb:93:6e:e8
Feb 9 11:45:38 raspberrypi dhcpcd[283]: wlan0: IAID eb:cb:76:07
Feb 9 11:45:38 raspberrypi dhcpcd[283]: wlan0: adding address fe80::dfb7:9c3:7432:8e
Feb 9 11:45:39 raspberrypi dhcpcd[283]: wlan0: carrier lost
Feb 9 11:45:39 raspberrypi dhcpcd[283]: wlan0: deleting address fe80::dfb7:9c3:7432:8e
Feb 9 11:45:37 pibox kernel: [ 17.902183] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Please let me know your observations…
