dividuum wrote:Any hints on how to get 1080p60?
Have not looked into that deep yet.
dividuum wrote:I took a completely different approach for video walls: Every Pi works independent but plays its content synced by the wall clock.
We will be implementing this also, mostly for syncing non-video/image content across Players that are not part of a video wall and just want media synchronization. If it works good, it could also be used for the Video Wall as well.
Generally, we want to allow our video wall setup to handle any type of content. This included web, GL, video, and anything combined. So, capturing and broadcasting the video stream is better suited, since we can do anything. The idea is that you could set up the video wall with LKV373A and 4 Yodeck Players (licensed at a very low one-off cost), and use Info-Beamer (or anything with HDMI output) as a content Player.
dividuum wrote:For that I render the video in a GL texture that can then be freely transformed. 1080p30 is possible that way.
I remember from another one of your posts that this had inherent restrictions. Can't recall exactly now, but I remember you said something about 720p only. Perhaps I am wrong though.
