natxo
i want to launch an app after the system has booted to desktop.
Sat Nov 11, 2017 12:04 pm
Hello
I think that in the system.d script i can choose when the app its launched setting the after parameter
[Unit]
Description=My App
After=??????
But i don't know what i have to put on after to get the app launched after the pi load the desktop.
Also there is a link where i can see the explain on those system.d parameters ???
klricks
Re: i want to launch an app after the system has booted to desktop.
Sat Nov 11, 2017 4:04 pm
Use autostart instead of system.d
nano /home/pi/.config/lxsession/LXDE-pi/autostart
Your entry in autostart should be like this:
@lxterminal -e path_to_my_app/my_app
Note that when the script returns back to the CL then the lxterminal will immediately close.
If your splash screen still says Pixel then you haven't updated in a long while.
natxo
Sat Nov 11, 2017 4:28 pm
Yes i have not updated for a time, its because the c++ framework im using does not compile on stretch so im still an older version.
Can you please elaborate this, i don't understand:
Thanks!
natxo
Sat Nov 11, 2017 4:46 pm
ok, now i understand what you are saying :)
I was reading https://wiki.archlinux.org/index.php/LXDE#Autostart and says:
If a line starts with @, and the command following it crashes, the command is automatically re-executed
Does it means that if my apps crash i will be launched again?? can this be disabled?
klricks
Sat Nov 11, 2017 5:12 pm
Thanks!
The lxterminal opened by the @lxterminal -e in autostart will immediately close when your script exits and returns to the cl.
So if your script outputs messages to the console for example: "Hello World", and then exits without delay, then you will not see the message.
The terminal will open and the script will run but the terminal session will close before you can see it.
This may or may not be an issue depending on what type of App you are wanting to run.
For example a standard app such as the File Manager can be started at desktop boot with no issues:
@lxterminal -e pcmanfm
klricks
Sat Nov 11, 2017 5:25 pm
Don't know.... Just omit the @ and see.
