Yes, of course I did (actually, I came here, to PINN after trying NOOB). All instructions about installing W10 IoT via NOOB, including "official" Micro$oft's are outdated, NOOB also don't have W10 IoT option nowfruitoftheloom wrote: ↑Thu Jul 27, 2017 12:29 amNow to your original question, have you tried NoobS ?? I have not personally used recently, but if an active internet connection is present W10IOTC was offered for RPi 2B & 3B:
https://www.raspberrypi.org/downloads/noobs/
https://github.com/raspberrypi/noobs/bl ... /README.md
So, I don't expect to get any help from MS or MSDN forums (I know that stuff for a very long-long time). The only hope is PINN developer; probably he already experimented (before releasing) with all supported OS'es and can provide an useful advise.
Internet (including this forum) are full of useless and almost stupid advises about "incompatible" sd-cards or "incompatible" power supplies but it's definitely not a my case, I have powerful enough power supplies (2A, 2.5A), fast enough sd-cards (SDHC UHS-I class 10 SanDisk 16 GB), and my RPi model B is working seamlessly (no single issue discovered!) almost two years on Raspbian (I'm running Apache with some useful apps, to control my X10 and thermometer, web-cam and some other stuff).
