Topgundreamer
Re: Bluetooth not working after update - information needed!
Sat Feb 18, 2017 7:42 am
Hi all, new to forum and to the raspberry pi, I have been trying for the last 5 hours to get bluetooth working on my pi 3, I have tried many different commands and still no luck
Under the status bluetooth.service I am seeing Active:failed
Once I type bluetoothctl I can no longer type anything else
Douglas6
Sat Feb 18, 2017 10:19 am
It sounds to me like you are using a very old version of the operating system. Best idea is to start with the latest version of Jessie.
Topgundreamer
Sat Feb 18, 2017 5:02 pm
Ok thank you, a coworker setup my pi so Ill try a new jesse, for got to mention I am using strictly for emulation station, the only thing I still cant understand is why the ps3 controller connects/pairs but nothing else will
If I do an hcitool scan I see the controller listed, but bluetoothctl still has no function
Douglas6
Sat Feb 18, 2017 5:19 pm
Topgundreamer wrote:If I do an hcitool scan I see the controller listed, but bluetoothctl still has no function
This is an old problem. Try 'sudo bluetoothctl'. However, I don't know what else might be out of date / not working.
adrianotanaka
Sat Apr 15, 2017 2:38 pm
cresfang wrote:For me its bcoz of the ps3controller driver from RetroPie.
I noticed the bluetooth in Raspbian Jessie stopped working after I installed RetroPie with ps3controller driver.
After I removed that driver, all worked OK again.
Thanks,
This solved my problem.
:D :D :D :D :D :D
xhit
Wed May 31, 2017 7:02 pm
The mini-uart bluetooth connection have become unstable following the lastest kernel and firmware upgrade (2017-04-27). I have installed it from scratch from the April raspbian image and the while on that version it works fine, but as soon as I do the apt-get upgrade it gets unstable. Initially the connection works but after a while the connection stops working and the most basic bluetooth commands becomes unresponsive.
hciconfig -a
hci0:	Type: BR/EDR  Bus: UART
	BD Address: XXXXXXXXXXXX  ACL MTU: 1021:8  SCO MTU: 64:1
	UP RUNNING
	RX bytes:915 acl:0 sco:0 events:42 errors:0
	TX bytes:1728 acl:6 sco:0 commands:55 errors:0
	Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
	Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
	Link policy: RSWITCH SNIFF
	Link mode: SLAVE ACCEPT
Can't read local name on hci0: Connection timed out (110)
At this point restarting hciuart service fails and I have to do a reboot to get the initial connection working again. I have tried to rollback of the firmware but that does not work since the whole upgrade is tied with a kernel upgrade. I have even lowered the baud-rate to 115200 in the hciattach command (/usr/bin/btuart) but to no avail. Any ideas to move forward?
config.txt additions:
enable_uart=1
core_freq=250
dtoverlay=pi3-miniuart-bt
Massi
Re: STICKY: Bluetooth not working after update - need info
Sat Aug 19, 2017 9:57 am
I ve just dist-upgraded my pi3, i saw some news on bluez and various firmware, upgraded and now my rfcomm virtual serial port returns only this odd error
read failed: device reports readiness to read but returne
d no data (device disconnected or multiple access on port
What was wrong? And i dont know how to debug this..
Douglas6
Sat Aug 19, 2017 12:22 pm
Several people seem to be having problems with Bluetooth after a dist-upgrade. First, check the adapter. What does 'hciconfig -a' tell you?
(On a clean install, rfcomm seems to be working fine.)
Massi
Sat Aug 19, 2017 2:09 pm
Hello douglas, i was hoping in you :)
Here is the output:
pi@baguette:~ $ hciconfig -a
        BD Address: 43:43:A1:12:1F:AC  ACL MTU: 1021:8  S
CO MTU: 64:1
        UP RUNNING
        RX bytes:1602 acl:6 sco:0 events:69 errors:0
        TX bytes:1668 acl:4 sco:0 commands:51 errors:0
        Class: 0x000000
        Service Classes: Unspecified
        Device Class: Miscellaneous,
        HCI Version: 4.1 (0x7)  Revision: 0x145
        LMP Version: 4.1 (0x7)  Subversion: 0x2209
        Manufacturer: Broadcom Corporation (15)
Thanks ;)
Douglas6
Sat Aug 19, 2017 2:57 pm
Well, that looks normal (except for the adapter name 😉). Maybe some more details; what are you trying to connect to? Are you connecting to the Pi or from the Pi? Is the SPP profile loaded ('sudo sdptool browse local')? What software are you using for serial comms? When exactly does the error occur?
Massi
Sat Aug 19, 2017 3:40 pm
This is an old working hc06 adapter, set up and working for ages.
But this seems interesting ;)
pi@baguette:~ $ sudo sdptool browse local
Failed to connect to SDP server on FF:FF:FF:00:00:00: No
such file or directory
Sounds arabic to me ;)
Douglas6
Sat Aug 19, 2017 3:55 pm
OK, is the compatibility flag still set on the bluetoothd command in /etc/systemd/system/dbus-org.bluez.service? Review this post and repeat if necessary: viewtopic.php?p=947185#p947185
You may need to unpair and re-pair the devices once you get SPP running.
Massi
Sat Aug 19, 2017 4:07 pm
I had to add the -C (never needed this before), but the sensor is still noto working.
Do you see anything useful in this? Andò thanks a lot, as always :)
pi@baguette:/usr/local/bin/classes/sensors $ sudo sdptool
 browse local
Browsing FF:FF:FF:00:00:00 ...
Service RecHandle: 0x10000
Service Class ID List:
  "PnP Information" (0x1200)
Profile Descriptor List:
    Version: 0x0103
Service Search failed: Invalid argument
Service Name: Serial Port
Service Description: COM Port
Service Provider: BlueZ
Service RecHandle: 0x10001
  "Serial Port" (0x1101)
Protocol Descriptor List:
  "L2CAP" (0x0100)
  "RFCOMM" (0x0003)
    Channel: 1
Language Base Attr List:
  code_ISO639: 0x656e
  encoding:    0x6a
  base_offset: 0x100
    Version: 0x0100
Service Name: Generic Access Profile
Service RecHandle: 0x10002
  "Generic Access" (0x1800)
  "L2CAP" (0x0100)
    PSM: 31
  "ATT" (0x0007)
    uint16: 0x0001
    uint16: 0x0008
Service Name: Generic Attribute Profile
Service RecHandle: 0x10003
  "Generic Attribute" (0x1801)
  "L2CAP" (0x0100)
    PSM: 31
  "ATT" (0x0007)
    uint16: 0x0010
    uint16: 0x0010
Service Name: AVRCP CT
Service RecHandle: 0x10004
  "AV Remote" (0x110e)
  "AV Remote Controller" (0x110f)
  "L2CAP" (0x0100)
    PSM: 23
  "AVCTP" (0x0017)
    uint16: 0x0103
    Version: 0x0105
Service Name: AVRCP TG
Service RecHandle: 0x10005
  "AV Remote Target" (0x110c)
  "L2CAP" (0x0100)
    PSM: 23
  "AVCTP" (0x0017)
    uint16: 0x0103
    Version: 0x0104
Douglas6
Sat Aug 19, 2017 4:22 pm
Hmm, that looks like Jessie results, not Stretch. Should still work. Are you running an rfcomm command? Is it still failing the same way? What does 'bluetoothd -v' return?
Massi
Sat Aug 19, 2017 4:35 pm
This is Jessie. I updated my Jessie install, maintenance i'd say :)
Still no stretch..
It's 5.23
This is the service file relevant part:
ExecStart=/usr/lib/bluetooth/bluetoothd -C
ExecStartPost=/usr/bin/sdptool add SP
ExecStartPost=/usr/bin/rfcomm bind rfcomm0 20:15:12:04:3$
ExecStartPost=/usr/bin/rfcomm bind rfcomm1 00:15:83:00:7$
Is this OK?
Then Ive always use the rfcomm0 port with python, but this stopped working with last update ;(
PS: until yesterday, it was working without the -C param and the add SP line..
Sadly i updated the system from an android SSH client while i'm on the seaside, it's a pain to debug it from here LOL
Douglas6
Sat Aug 19, 2017 4:48 pm
The -C flag wasn't needed in BlueZ 4, it's needed in 5. My only guess is that the rfcomm commands are trying to run too early, before the SPP gets set up. Can you try running them from the command line? Also what does this say? 'systemctl status bluetooth'
Also also, the bdaddrs look odd. I didn't know you could use $s.
Massi
Sat Aug 19, 2017 5:17 pm
The error OS noto something about the lack of the rfcomm porta, it's something happening in the communication over the port.
The bind commando cant be run since the address is already in use.
The bluetooth service seems also ok
So, i cant underatand ;)
Ill try fixing this next week when ill be back home.. In the meantime thanks for your help ;)
Btw i think the last update was something related to firmware, noto bluez, so probably its something deeper..
Massi
Sat Aug 19, 2017 5:23 pm
OK, so stupid..
The update simply deleted alla the trusted and paired devices
Had to trust and pair it again with bluetoothctl..
Happy ;)
(Working without -C and without the SP add)
asavah
Tue Aug 22, 2017 7:24 pm
No, it did not,the updated firmware seems to have a bug with BT MAC address.
Bluez stack saves it's pairing/trust data as /var/lib/blueetooth/AA:BB:CC:DD:EE:FF ,
Due to this bug all of us with updated firmware will have 43:43:A1:12:1F:AC as bt mac,
and due to this bluez will not use previously saved data.
The old data is still there.
See https://github.com/raspberrypi/firmware/issues/860
Douglas6
Tue Aug 22, 2017 7:36 pm
Thanks for pointing that out asavah. I can confirm the same Bluetooth device address.
Yotaphoner
Wed Aug 23, 2017 12:57 pm
Hi. My bluetooth problm is of another kind, but I think this is the best place to post it.
My bluetooth connection is good, but my probems are with two different bluetooth keyboards, which work perfectly with many of other devices and systems. The prblem is connection is lost after only 15 sec of non pressing any key, and then sometimes it's hard to reconnect. With the other keboard the problem is when I press Bloq Mayus It stops working, and I have toait an undefinied time.. And I repat, both keyboards works perfectly under ubuntu and and and android devices.
I tried if doing a apt-get dist-upgrade solve something, but nothing happend.
Maybe if someone knows about a program to send bluetooth keep alive packets It will solve the problem with one of my keyboards.
An idea_ Thanks
PhilE
Wed Aug 23, 2017 3:15 pm
From my answer on GitHub:
The new Bluetooth firmware seems to be ignoring the MAC address programmed into its OTP - the address you have now is a default for that chip (4343 A1 ...). Fortunately there is a way to set a MAC address using hciattach. Here is a modified version of the /usr/bin/btuart script that should set the MAC address correctly.
If you want to try it, download it to the home directory of user pi and:
sudo mv /usr/bin/btuart{,.orig}
sudo cp ~pi/btuart /usr/bin/btuart
sudo reboot
To return to the shipping version, which I recommend before updating the pi-bluetooth package, run:
sudo mv /usr/bin/btuart{.orig,}
Massi
Wed Aug 23, 2017 4:27 pm
Wow, thanks! I only saw the effect, you explained the source ;)
Yotaphoner
Sat Aug 26, 2017 4:11 pm
Any idea? Thanks
Some could say something about that? For example if are you using a bluetooth keyboard without any issues, or may beabout theexistence of the program I am requesting for?
Thanks!!
