very new to begin with but have jessie running on rasp pi zero w. ran the install line for Flick gesture control without issue.When i run the flick demo in the terminal i get this
pi@raspberrypi:~ $ flick-demo
Did not receive firmware info
File "/usr/local/bin/flick-demo", line 4, in <module>
__import__('pkg_resources').run_script('flicklib==0.0.1', 'flick-demo')
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 534, in run_script
self.require(requires)[0].run_script(script_name, ns)
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1445, in run_script
exec(script_code, namespace, namespace)
File "/usr/local/lib/python2.7/dist-packages/flicklib-0.0.1-py2.7.egg/EGG-INFO/scripts/flick-demo", line 4, in <module>
File "build/bdist.linux-armv6l/egg/flicklib.py", line 479, in <module>
NameError: name 'sys' is not defined
Error in atexit._run_exitfuncs:
File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
func(*targs, **kargs)
File "build/bdist.linux-armv6l/egg/flicklib.py", line 462, in _exit
TypeError: 'NoneType' object is not callable
Error in sys.exitfunc:
have no idea whats going on. I did notice at one point when i checked directories it installed at "root" instead of pi but even changing that produced same result. Do i need to update the flick software? and how do I do that?
Any help is appreciated. Yup, 30 seconds for most people but hours later......sniffle....
