ben_nuttall
STICKY: Python Usage Guide
Tue Jun 10, 2014 5:29 pm
I've written a usage guide for getting started with Python: http://www.raspberrypi.org/documentation/usage/python
Community Manager - Raspberry Pi Foundation
Author of GPIO Zero and creator of piwheels
buckyb
Re: Python Usage Guide
Sat Feb 07, 2015 11:43 am
Hi Ben
Just tried your Python examples with IDLE3. A number do not work as expected although they do with python in a terminal or with pyCharm on Ubuntu.
eg
for i in range(2):
    print("A")
print("B")
That was with two new last issues of raspian on a cleaned SD card using a B model with 8GB SD from RPi store. Running a file, after saving, from IDLE3 also did not seem to work.
Am I missing something?
regards
DirkS
Sat Feb 07, 2015 12:25 pm
The documentation is maintained on github.
I would create an issue there: https://github.com/raspberrypi/document ... /README.md
MisterEShopper
Wed Mar 11, 2015 9:57 pm
Thank you for the instructions, but they do not include a HOWTO INSTALL Python and Idle to get started. How does one install Python and IDLE?
Thu Mar 12, 2015 4:21 am
MisterEShopper wrote:Thank you for the instructions, but they do not include a HOWTO INSTALL Python and Idle to get started. How does one install Python and IDLE?
Are you using the recommended Raspbian OS?
If so, both Python and IDLE are already installed.
TerryC65
Re: Python Usage Guide - Using GPIO
Tue Jun 09, 2015 11:07 am
Ben,
In your Advanced User Guide, under the heading 'GPIO' you state:
To control the GPIO pins you'll need root access, so run sudo python, sudo ipython or sudo idle &.
Can I ask why this is? It seems to make life difficult and seems to go against everything I've ever known about not running anything as root unless something is being installed or configured.
Also, I have been playing around with Python using IDLE and am therefore most confident when I have the ability to use the debugger. At the moment I cannot see a way to run my code without giving myself root privileges or starting IDLE with sudo. Neither of these seem 'quite right', so I wonder if there's another way?
Tue Jun 09, 2015 11:24 am
TerryC65 wrote: Also, I have been playing around with Python using IDLE and am therefore most confident when I have the ability to use the debugger. At the moment I cannot see a way to run my code without giving myself root privileges or starting IDLE with sudo. Neither of these seem 'quite right', so I wonder if there's another way?
There is another way.
If your id is in the i2c group you can use I2C without root, if it's in the spi group you can use SPI without root and if it's in the gpio group you can use the /sys virtual filesystem to access GPIO pins without root.
The problem with /sys is that it's slow.
echo "17" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio17/direction
echo "1" > /sys/class/gpio/gpio17/value
And to drive that from python https://github.com/derekstavis/python-sysfs-gpio
This is a doctor free zone.
joan
Tue Jun 09, 2015 11:33 am
TerryC65 wrote:Ben,
You need root access to access memory and most modules access the gpios as memory mapped devices for performance reasons.
My pigpio Python module allows you to access the gpios without having to run Python as root.
TerryC65
Tue Jun 09, 2015 12:27 pm
joan wrote:You need root access to access memory and most modules access the gpios as memory mapped devices for performance reasons.
OK. So in other words the GPIO is directly mapped to memory to provide the best speed. Is that right?
That's why Dougie, in his earlier response says that putting the user into the GPIO group is slow, because access is then indirect, via /sys?
joan wrote:My pigpio Python module allows you to access the gpios without having to run Python as root.
So how does this provide the performance? (I'm not an experienced programmer, so can't work it out from the code 8-) )
Tue Jun 09, 2015 12:41 pm
Because Joan's pigpiod is a single purpose dedicated server that reads your request from a non-privileged client, runs optimised code to wiggle/read/furgle with your GPIO pins and posts the result back to the requester. It's not a generic interface.
joan
Tue Jun 09, 2015 12:57 pm
DougieLawson wrote: ...
Given that we now have a gpio group it should be straightforward to write a generic Python module to manipulate the gpios. It should be possible to do all the basics such as input/output, software PWM, callbacks on level changes in Python without requiring root access. That alone would probably cover 95% of usage. Bit of an opening there for anyone who wants to write a library.
Douglas6
Tue Jun 09, 2015 3:29 pm
joan wrote:Given that we now have a gpio group it should be straightforward to write a generic Python module to manipulate the gpios.... Bit of an opening there for anyone who wants to write a library.
Interesting. But what would it need to do differently than RPi.GPIO?
joan
Tue Jun 09, 2015 3:49 pm
I am not sure. I may be missing something but I do not see why RPi.GPIO could not be updated so that it did not require root access. croston (the author) should know off the top of his head.
croston
Tue Jun 09, 2015 4:28 pm
I am currently writing a mechanism for RPi.GPIO not to require root permissions.
Tue Jun 09, 2015 5:39 pm
croston wrote:I am currently writing a mechanism for RPi.GPIO not to require root permissions.
Excellent, I'll be willing to beta test your code.
TerryC65
Wed Jun 10, 2015 8:24 am
Excellent!
Also, thanks to Joan and Dougie for explaining things.
ugnelakys
Wed Jul 22, 2015 1:29 pm
ben_nuttall wrote:I've written a usage guide for getting started with Python: http://www.raspberrypi.org/documentation/usage/python
Don't forget the main manual; but i think it is for advanced learning https://docs.python.org/3.2/library/
Also some examples: Python examples
pirat3k
Mon Sep 28, 2015 9:07 pm
Can you tell me how to connect mysql?
I don't know how to install the package (mysql_connector or something like that)
direfulfoil23
Fri May 06, 2016 6:45 pm
I am using IDLE and am encountering a problem at times, an example would be when I try to write:
>>>for i in range(2):
print("A")
print("B")
How do I get the arrows to return, basically so I can end the loop and write something new? Sorry if I don't make much sense or use proper vernacular, I'm very new to this.
DirkS
Fri May 06, 2016 7:28 pm
direfulfoil23 wrote:Hello,
>>>for i in range(2):
print("A")
print("B")
leave line empty and press <ENTER>
BTW: in future please start a new topic for questions like this.
dgordon42
Fri May 06, 2016 7:41 pm
After you have entered all the code for the loop and pressed <Return>, press <Backspace> to loose the indent and get out of the loop.
Also, when posting Python code on the forums indentation is important, so after pasting your code highlight it and press the "Code" button at the top if the editor. That way, we can see the indentation, and make more sense of your code. You are more likely to get questions answered that way.
Hope this helps,
Dave.
B.Goode
Fri May 06, 2016 7:59 pm
>>>for i in range(2):
print("A")
print("B")
Before you write a lot of code and get very frustrated, please be aware that IDLE's shell window (identified by the '>>> ' prompt from the interactive python interpreter) does not allow you to (easily) save, reload and rerun your script.
You might want to look ahead in the guide to the section Python files in IDLE to see how to overcome this restriction by creating a new, blank, file into which you type your script.
The interactive shell window is a great tool for quick 'one-shot' experiments, but it is not a useful place for writing and saving permanent scripts. I think the Python Usage Guide which you seem to be following makes this clear eventually.
(If you are following the Python Usage Guide referenced in the first post in this topic then I see no reason why you should not have raised a query about it here.)
VladGets
Fri Nov 11, 2016 2:00 pm
IT IS
Thu Dec 22, 2016 4:58 pm
Wow, thank you for that guide.
I haven't read all the comments, but it seems to me as an python beginner that python could be little easier to learn than java or c++.
I'm looking forward to my first projekt :D
gkreidl
Mon May 15, 2017 6:33 am
AshPowers wrote:I would like to compile my program into a binary executable as it will be part of a product and do not want the source code being so easily obtainable.
What is the best method of doing this?
Thanks!
Nuitka.
http://nuitka.net/
Minimal Kiosk Browser (kweb)
Return to “Python”
