So I've gone through several iterations of this project. Basically, my wife and I are moving into an RV full time in July. Right now our home system is setup so we have a Mac mini with our video/music library on it and stream that through an Apple TV to the TV. That has to change though as the power demands of a Mac mini are just too high. So after some discussion with other computer geeks, they told me to try a Raspberry Pi. I had previously setup a Pi3 so that I could play old school games on it, so I have a Pi already, just need to instal Raspbian instead of RetroPie on a different SD card to make sure I can get it working before I move it over to the RV.
Here's what I want to be able to do with it, and I did find some resources, but I figured I'd post here with updates and questions to see if any of you can offer experience and input.
I want it to be a media hub. I have all my files on a Windows exFAT formatted drive. Some of them will have to be converted out of the AAC format, but I think most of it is mp4 and m4a. Hopefully that works. I want the Pi to be able to display movies on a TV that will be about 10 feet away, so running an HDMI cable shouldn't be a problem. The Pi itself will be in the dash in a small opening that used to hold an old tube TV.
Second, I want to back up important files from our Mac laptops. I need the Pi to somehow be able to mount a network drive on macOS. I haven't figured out how to do this yet. I have it on the RetroPie setup, so it should be pretty easy.
I want to add a dash cam I can get files off of. I've read about the official raspberry camera, so I'm thinking this is my best bet. If I can set up several cameras, that would be great, but I don't know if Raspbian allows this. Ideally, I'd like to have several video feeds going at once since we will be making videos for others to watch. I'll be editing them on my MacBook Pro with Premiere, so I don't need the Pi to handle that part.
And finally, I'm not sure how to control all this. If I can have a second monitor attached, I'll get a small 7 or 9 inch screen to mount in front of the Pi in the aforementioned TV slot, touchscreen would be great. If I can dual monitor a Pi with two screens, one the mini control box screen and one the TV for watching movies, that would be awesome.
Oh yeah, it will be connected to the network via ethernet, so wifi isn't a problem, but if I can share a iPhone LTE connection, that would be great. That was what I originally bought the Pi3 for, but I couldn't seem to get it to share with iOS 10 and Raspbian. I did a lot of research and work, and everything said it should work, but it just didn't. If I can plug a iPhone in via USB and share the wifi with the rest of the RV, it would be perfect.
So yeah, that's the project. Any hints or ideas on how I can get this to work?
