This is the code........
I don't know if the python version is changed ......
#!#!/usr/bin/env python
# -*- coding: utf-8 -*-
# This code uses the Beebotte API, you must have an account.
# You can register here:
http://beebotte.com/register
import time
import Adafruit_DHT
from beebotte import *
### Replace API_KEY and SECRET_KEY with those of your account
bbt = BBT("00000000000000000000000", "00000000000000000000000000000000000000")
period = 300 ## Sensor data reporting period (1 minute)
pin = 4 ## Assuming the DHT11 sensor is connected to GPIO pin number 4
### Change channel name and resource names as suits you
temp_resource = Resource(bbt, 'PI2B', 'temperatura')
humid_resource = Resource(bbt, 'PI2B', 'umidita')
now = time.strftime("%c")
def run():
while True:
### Assume
humidity, temperature = Adafruit_DHT.read_retry( Adafruit_DHT.DHT11, pin )
if humidity is not None and temperature is not None:
print "Temp={0:f}*C Humidity={1:f}%".format(temperature, humidity)
print time.strftime("%c")
try:
#Send temperature to Beebotte
temp_resource.write(temperature)
#Send humidity to Beebotte
humid_resource.write(humidity)
except Exception:
## Process exception here
print "Error while writing to Beebotte"
else:
print "Failed to get reading. Try again!"
#Sleep some time
time.sleep( period )
run()
CPaolo
