Here is some code you put into a file called "graph.c" and you include it in your c program like this:
#include "graph.c"
(quotes, NOT < > and to call it relative it has to be in the same directory as your C source file)
Here is the code. Just copy and paste it to a text file called "graph.c":
// GRAPH3.C - Basic Graphics Support for CLI's
//statically allocated arrays for graphics output
//main historgram display. 10 viewports
char red[640][480][10];
char green[640][480][10];
char blue[640][480][10];
long sx=640; //dimensions of viewport
long sy=480;
//CURRENT COLOR SUPPORT
long cur_red[10];
long cur_green[10];
long cur_blue[10];
//note if using a refreshing browser page for output remember to include cache defeating
// FUNCTION PROTOTYPES
// Limited graphics support
//void writebmp(char *fname); //writes out the graphics arrays to a BMP file
//void bar2(int x, int y, int w, int h, char i);
//void clrscr();
// END OF FUNCTION PROTOTYPES
//Graphics Support Routines
initgraph3()
int a;
//set all current colors to white
//for all viewports
//(this way it will draw right out of the package)
for (a=0;a<10;a++)
cur_red[a]=255;
cur_green[a]=255;
cur_blue[a]=255;
setcolor(int vp, int r, int g, int b)
cur_red[vp]=r; cur_green[vp]=g; cur_blue[vp]=b;
clrscr(int vp)
int x,y;
//clearscreen to white
for (x=0;x<sx;x++)
for (y=0;y<sy;y++)
// red[x][y][vp]=255; //to white
// green[x][y][vp]=255;
// blue[x][y][vp]=255;
red[x][y][vp]=0; //to black
green[x][y][vp]=0;
blue[x][y][vp]=0;
getpixel(int vp, int x, int y, char *r, char *g, char *b)
if ((x>0)&&(x<sx)&&(y>0)&&(y<sy))
*r=red[x][y][vp];
*g=green[x][y][vp];
*b=blue[x][y][vp];
else
*r=0; //returns black on a clip
*g=0;
*b=0;
putpixel(int vp, int x, int y)
//wrap the putpixel to reduce segmentation faults
//"clipping"
if ((x>=0)&&(x<sx)&&(y>=0)&&(y<sy))
//uses current color
red[x][y][vp]=cur_red[vp];
green[x][y][vp]=cur_green[vp];
blue[x][y][vp]=cur_blue[vp];
swap(int *a, int *b)
int tmp; tmp=*a; *a=*b; *b=tmp;
bar(int vp, int x1, int y1, int x2, int y2)
int a,b;
//draws a rectangle in the current color
if (y2<y1) swap(&y1,&y2);
if (x2<x1) swap(&x1,&x2);
for (a=x1;a<=x2;a++)
for (b=y1;b<=y2;b++)
putpixel(vp,a,b);
bar2(int vp, int x, int y, int w, int h)
//w and h have to be positive
//draws rectangle in the current color for the viewport
int a,b;
for (a=x;a<=(x+w-1);a++)
for (b=y;b<=(y+h-1);b++)
putpixel(vp,a,b);
line(int vp, int x1, int y1, int x2, int y2)
double m;
double c=0.0;
int a;
if (x2<x1)
swap(&x1,&x2);
swap(&y1,&y2);
//intercept the divide by zero error
if ((x2-x1)==0)
m=99999;
else
m=((double)(y2-y1))/((double)(x2-x1));
if (m<1)
for (a=x1;a<x2;a++)
c+=m;
bar2(vp,a,y1+c,2,2);
else
if (y2<y1)
swap(&x1,&x2);
swap(&y1,&y2);
for (a=y1;a<y2;a++)
c+=1/m;
bar2(vp,x1+c,a,2,2);
circle(int vp, int x, int y, int r)
double a;
//draws a circle in the current color
for (a=0;a<(2*3.14159);a+=0.001)
bar2(vp,(int)(cos(a)*r)+x,(int)(sin(a)*r)+y,1,1);
textout(int vp, int x,int y, char s[], int fs)
int cx,cy;
int c,d;
char o;
char font[41][8]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}, //space
{0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0x00,0x00}, //white block - Use for unrecognized chars
{0x70,0x88,0x88,0xF8,0x88,0x88,0x00,0x00}, //A
{0xF0,0x88,0xF0,0x88,0x88,0xF0,0x00,0x00}, //B
{0x70,0x88,0x80,0x80,0x88,0x70,0x00,0x00}, //C
{0xE0,0x90,0x88,0x88,0x88,0xF0,0x00,0x00}, //D
{0xF8,0x80,0xE0,0x80,0x80,0xF8,0x00,0x00}, //E
{0xF8,0x80,0xF0,0x80,0x80,0x80,0x00,0x00}, //F
{0x78,0x80,0x80,0x98,0x88,0x70,0x00,0x00}, //G
{0x88,0x88,0x88,0xF8,0x88,0x88,0x00,0x00}, //H
{0xF8,0x20,0x20,0x20,0x20,0xF8,0x00,0x00}, //I
{0xF8,0x10,0x10,0x10,0x90,0x60,0x00,0x00}, //J
{0x90,0x0A,0xC0,0xE0,0x90,0x88,0x00,0x00}, //K
{0x80,0x80,0x80,0x80,0x80,0xF8,0x00,0x00}, //L
{0x88,0xD8,0xA8,0x88,0x88,0x88,0x00,0x00}, //M
{0x88,0xC8,0xC8,0xA8,0x98,0x98,0x00,0x00}, //N
{0x70,0x88,0x88,0x88,0x88,0x70,0x00,0x00}, //O
{0xF0,0x88,0x88,0xF0,0x80,0x80,0x00,0x00}, //P
{0x70,0x88,0x88,0xA8,0x98,0x78,0x00,0x00}, //Q
{0xF0,0x88,0x88,0xF0,0x90,0x88,0x00,0x00}, //R
{0x70,0x88,0xE0,0x18,0x88,0x70,0x00,0x00}, //S
{0xF8,0x20,0x20,0x20,0x20,0x20,0x00,0x00}, //T
{0x88,0x88,0x88,0x88,0x88,0x70,0x00,0x00}, //U
{0x88,0x88,0x88,0x88,0x50,0x20,0x00,0x00}, //V
{0x88,0x88,0xA8,0xA8,0xD8,0x88,0x00,0x00}, //W
{0x88,0x40,0x20,0x20,0x50,0x80,0x00,0x00}, //X
{0x88,0x88,0x88,0x50,0x20,0x20,0x00,0x00}, //Y
{0xF8,0x10,0x20,0x20,0x40,0xF8,0x00,0x00}, //Z
{0x20,0x60,0xE0,0x20,0x20,0xF8,0x00,0x00}, //1
{0x70,0x88,0x08,0x30,0x40,0xF8,0x00,0x00}, //2
{0x70,0x88,0x38,0x38,0x88,0x70,0x00,0x00}, //3
{0x30,0x50,0x90,0xF8,0x10,0x10,0x00,0x00}, //4
{0xF8,0x80,0xF0,0x08,0x88,0x70,0x00,0x00}, //5
{0x38,0x40,0xF0,0x88,0x88,0x70,0x00,0x00}, //6
{0xF8,0x08,0x10,0x20,0x20,0x20,0x00,0x00}, //7
{0x70,0x88,0x70,0x88,0x88,0x70,0x00,0x00}, //8
{0x70,0x88,0x78,0x18,0x20,0x40,0x00,0x00}, //9
{0x70,0x88,0x98,0xA8,0xC8,0x70,0x00,0x00}, //0
{0x00,0x20,0x20,0xF8,0x20,0x20,0x00,0x00}, //+
{0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00}, //-
{0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00} //.
cx=x; cy=y;
for (c=0;c<strlen((char *)s);c++)
//map characters to array ordinal (doesn't use ASCII)
switch(toupper(s[c]))
case ' ': o=0; break;
case 'A': o=2; break;
case 'B': o=3; break;
case 'C': o=4; break;
case 'D': o=5; break;
case 'E': o=6; break;
case 'F': o=7; break;
case 'G': o=8; break;
case 'H': o=9; break;
case 'I': o=10; break;
case 'J': o=11; break;
case 'K': o=12; break;
case 'L': o=13; break;
case 'M': o=14; break;
case 'N': o=15; break;
case 'O': o=16; break;
case 'P': o=17; break;
case 'Q': o=18; break;
case 'R': o=19; break;
case 'S': o=20; break;
case 'T': o=21; break;
case 'U': o=22; break;
case 'V': o=23; break;
case 'W': o=24; break;
case 'X': o=25; break;
case 'Y': o=26; break;
case 'Z': o=27; break;
case '1': o=28; break;
case '2': o=29; break;
case '3': o=30; break;
case '4': o=31; break;
case '5': o=32; break;
case '6': o=33; break;
case '7': o=34; break;
case '8': o=35; break;
case '9': o=36; break;
case '0': o=37; break;
case '+': o=38; break;
case '-': o=39; break;
case '.': o=40; break;
default: o=1; break;
for (d=0;d<8;d++)
//write text in current color
if (font[o][d]&0x80) bar2(vp,cx,cy+d*fs,fs,fs);
if (font[o][d]&0x40) bar2(vp,cx+1*fs,cy+d*fs,fs,fs);
if (font[o][d]&0x20) bar2(vp,cx+2*fs,cy+d*fs,fs,fs);
if (font[o][d]&0x10) bar2(vp,cx+3*fs,cy+d*fs,fs,fs);
if (font[o][d]&0x08) bar2(vp,cx+4*fs,cy+d*fs,fs,fs);
if (font[o][d]&0x04) bar2(vp,cx+5*fs,cy+d*fs,fs,fs);
if (font[o][d]&0x02) bar2(vp,cx+6*fs,cy+d*fs,fs,fs);
if (font[o][d]&0x01) bar2(vp,cx+7*fs,cy+d*fs,fs,fs);
cx+=8*fs;
writebmp(char *fname, int vp)
FILE *fptr;
long fs,is,a,b; //filesize, image size, counters
int yr;
char s[255];
char n,o,p; //color save values
//save the current color and restore at the end of the function
//usually this is the last call to a viewport, but sometimes not.
n=cur_red[vp]; o=cur_green[vp]; p=cur_blue[vp];
//minimalist graphics support for CLI's
char bmp_hdr[54]={ 0x42,0x4D,0x46,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x36,0x00, 0x00,0x00,
0x28,0x00,0x00,0x00, 0x02,0x00,0x00,0x00, 0x02,0x00,0x00,0x00, 0x01,0x00,
0x18,0x00,0x00,0x00, 0x00,0x00,0x10,0x00, 0x00,0x00,0x13,0x00, 0x00,0x00,
0x13,0x0B,0x00,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00};
fs=54+(sx*sy*3); //filesize is the dimentions of the array multiplied by 3 bytes (R,G and B bytes)
is=(sx*sy*3);
//put RED registration square in top-left hand corner at (20,20), height =20, width=20
//for (a=0;a<20;a++)
// for (b=0;b<20;b++)
// red[a+20][b+20][vp]=255;
setcolor(vp,255,255,255);
//textout(vp,20,20,"Reg",1);
//Stanford Systems copyright notice
yr=2016;
//sprintf(s,"%d (c) Copyright Stanford Systems",yr);
//textout(vp,sx/2-(8*strlen(s))/2,sy-10,s,1);
memcpy((void *)&bmp_hdr[2],(void *)&fs,4);
memcpy((void *)&bmp_hdr[18],(void *)&sx,4);
memcpy((void *)&bmp_hdr[22],(void *)&sy,4);
memcpy((void *)&bmp_hdr[34],(void *)&is,4);
if ((fptr=fopen(fname,"wb"))!=NULL)
fwrite(bmp_hdr,54,1,fptr);
for (b=sy;b>0;b--)
for (a=0;a<sx;a++)
fwrite(&blue[a][b][vp],1,1,fptr);
fwrite(&green[a][b][vp],1,1,fptr);
fwrite(&red[a][b][vp],1,1,fptr);
else
printf("failed to open BMP file.\n");
return -1; //error code indicating file could not be opened
fclose(fptr);
//restore any viewport vars we changed here
cur_red[vp]=n; cur_green[vp]=o; cur_blue[vp]=o;
return 1;
writebmp(filename,viewport#);
its based on ten viewports that you can use to write graphics to. Its interface is procedural and statically-defined, so to change the color of a pixel, you just change the number of an array element to the intensity of that color. Don't forget to specify which viewport though, like this:
red[100][100][0]=255;
...will put a red pixel in viewport 0. You just keep writing to the array (i.e. buffer) and when you are finished your image call the writebmp() function.
