Thanks for your instructions, Phil.PhilE wrote:You are in luck. The current RPi SPI driver, spi-bcm2835, support GPIO chip-selects. This means that any free GPIO line can be used as another chip select. In fact, as a result of some driver performance optimisations causing the hardware ("native") chip-selects to glitch, the driver will automatically convert native CS's to GPIO CS's.
/dts-v1/;
/plugin/;
compatible = "brcm,bcm2835", "brcm,bcm2836", "brcm,bcm2708", "brcm,bcm2709";
fragment@0 {
target = <&spi0>;
frag0: __overlay__ {
#address-cells = <1>;
#size-cells = <0>;
pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
status = "okay";
cs-gpios = <&gpio 22 1>, <&gpio 23 1>, <0>, <0>;
spidev@2{
compatible = "spidev";
reg = <2>; /* CE2 */
#size-cells = <0>;
spi-max-frequency = <500000>;
spidev@3{
reg = <3>; /* CE3 */
#size-cells = <0>;
fragment@1 {
target = <&gpio>;
__overlay__ {
spi0_cs_pins: spi0_cs_pins {
brcm,pins = <22 23>;
brcm,function = <1>; /* out */
__overrides__ {
cs0_pin = <&frag0>,"cs-gpios:12", <&spi0_cs_pins>,"brcm,pins:0";
cs1_pin = <&frag0>,"cs-gpios:24", <&spi0_cs_pins>,"brcm,pins:4";
dtparam=spi=on
dtoverlay=spi-gpio-cs,cs2_pin=5,cs3_pin=6
pi@raspberrypi ~> ls /dev/spi*
/dev/spidev0.0 /dev/spidev0.1
cs-gpios = <0>, <0>, <&gpio 22 1>, <&gpio 23 1>;
ls -l /dev/spidev*
__overrides__ {
__overrides__ {
cs2_pin = <&frag0>,"cs-gpios:12", <&spi0_cs_pins>,"brcm,pins:0";
cs3_pin = <&frag0>,"cs-gpios:24", <&spi0_cs_pins>,"brcm,pins:4";
brcm,pins = <8 7 22 23>;
cs-gpios = <&gpio 8 1>, <&gpio 7 1>, <&gpio 22 1>, <&gpio 23 1>;
__overrides__ {
cs0_pin = <&frag0>,"cs-gpios:4", <&spi0_cs_pins>,"brcm,pins:0";
cs1_pin = <&frag0>,"cs-gpios:16", <&spi0_cs_pins>,"brcm,pins:4";
cs2_pin = <&frag0>,"cs-gpios:28", <&spi0_cs_pins>,"brcm,pins:8";
cs3_pin = <&frag0>,"cs-gpios:40", <&spi0_cs_pins>,"brcm,pins:12";
/dts-v1/;
/plugin/;
fragment@0 {
target = <&spi0>;
#size-cells = <0>;
status = "okay";
cs-gpios = <0>, <0>, <&gpio 20 1>, <&gpio 21 1>;
spidev@2{
#size-cells = <0>;
spidev@3{
#size-cells = <0>;
fragment@1 {
target = <&gpio>;
__overlay__ {
brcm,pins = <20 21>;
__overrides__ {
dtc -@ -I dts -O dtb -o spi-gpio-cs.dtbo spi-gpio-cs-overlay.dts
sudo cp spi-gpio-cs.dtbo /boot/overlays
dtoverlay=piscreen
cs-gpios = <0>, <0>;
cs-gpios = <&gpio 8 1>, <&gpio 7 1>;
/dts-v1/;
/plugin/;
fragment@0 {
target = <&spi0>;
#size-cells = <0>;
status = "okay";
cs-gpios = <&gpio 8 1>, <&gpio 7 1>, <&gpio 20 1>, <&gpio 21 1>;
spidev@2{
#size-cells = <0>;
spidev@3{
#size-cells = <0>;
fragment@1 {
target = <&spi0_cs_pins>;
frag1: __overlay__ {
brcm,pins = <8 7 20 21>;
__overrides__ {
cs2_pin = <&frag0>,"cs-gpios:28", <&frag1>,"brcm,pins:8";
cs3_pin = <&frag0>,"cs-gpios:40", <&frag1>,"brcm,pins:12";
* Device tree overlay for mcp251x/can2 on spi0.2
/dts-v1/;
/plugin/;
/* disable spi-dev for spi0.2 */
fragment@0 {
target = <&spi0>;
__overlay__ {
status = "okay";
fragment@1 {
target = <&spidev2>;
__overlay__ {
status = "disabled";
/* the interrupt pin of the can-controller */
fragment@2 {
target = <&gpio>;
__overlay__ {
can2_pins: can2_pins {
brcm,pins = <25>;
brcm,function = <0>; /* input */
/* the clock/oscillator of the can-controller */
fragment@3 {
target-path = "/clocks";
__overlay__ {
/* external oscillator of mcp2515 on spi0.2 */
can2_osc: can2_osc {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <16000000>;
/* the spi config of the can-controller itself binding everything together */
fragment@4 {
target = <&spi0>;
__overlay__ {
/* needed to avoid dtc warning */
#size-cells = <0>;
can2: mcp2515@2 {
reg = <2>;
compatible = "microchip,mcp2515";
pinctrl-names = "default";
pinctrl-0 = <&can2_pins>;
spi-max-frequency = <10000000>;
interrupt-parent = <&gpio>;
interrupts = <25 0x2>;
clocks = <&can2_osc>;
__overrides__ {
oscillator = <&can2_osc>,"clock-frequency:0";
spimaxfrequency = <&can2>,"spi-max-frequency:0";
interrupt = <&can2_pins>,"brcm,pins:0",<&can2>,"interrupts:0";
sudo vcdbg log msg |& grep -v -E "(HDMI|gpioman)"
sudo vcdbg log msg |& grep dt
brcm,pins = <8 7>;
brcm,function = <1>; /* output */
fragment@1 {
cs_pins: __overlay__ {
brcm,pins = <8 7 6>;
__overrides__ {
cs2 = <&cs_pins>,"brcm,pins:8";
/dts-v1/;
/plugin/;
fragment@0 {
target = <&spi0>;
__overlay__ {
status = "okay";
fragment@1 {
fragment@2 {
target = <&gpio>;
__overlay__ {
brcm,pins = <25>;
fragment@3 {
__overlay__ {
#clock-cells = <0>;
fragment@4 {
target = <&spi0>;
__overlay__ {
#size-cells = <0>;
can2: mcp2515@2 {
reg = <2>;
__overrides__ {
pi@raspberrypi:~ $ sudo ip link set up can0 type can bitrate 500000
Cannot find device "can0"
pi@raspberrypi:~ $ sudo ip link set up can1 type can bitrate 500000
Cannot find device "can1"
pi@raspberrypi:~ $ sudo ip link set up can2 type can bitrate 500000
Cannot find device "can2"
pi@raspberrypi:~ $ sudo vcdbg log msg |& grep -v -E "(HDMI|gpioman)"
000979.762: *** Restart logging
000980.996: Read command line from file 'cmdline.txt'
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
001232.263: Loading 'kernel7.img' to 0x8000 size 0x4088d8
001235.912: Kernel trailer DTOK property says yes
001235.927: Kernel trailer DDTK property says yes
001238.916: Loading 'bcm2710-rpi-3-b.dtb' to 0x4108d8 size 0x3e78
001320.251: dtparam: uart0_clkrate=48000000
001333.899: dtparam: spi=off
001341.927: dtparam: audio=on
001368.790: Loaded overlay 'mcp2515-can0'
001368.808: dtparam: oscillator=10000000
001369.585: dtparam: interrupt=25
001437.190: Loaded overlay 'mcp2515-can1'
001437.209: dtparam: oscillator=10000000
001437.986: dtparam: interrupt=24
001509.997: Loaded overlay 'mcp2515-can2'
001510.015: dtparam: oscillator=10000000
001510.811: dtparam: interrupt=23
001636.188: dtparam: arm_freq=1200000000
001682.248: dtparam: core_freq=250000000
001694.830: dtparam: cache_line_size=64
001718.622: Device tree loaded to 0x2effb800 (size 0x47ee)
003379.068: vchiq_core: vchiq_init_state: slot_zero = 0xfac80000, is_master = 1
003388.297: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000010
pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.26-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #915 SMP Thu Oct 20 17:08:44 BST 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 808c2f80, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f61000 s22592 r8192 d22464 u53248
[ 0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2709.boardrev=0xa02082 bcm2709.serial=0x7a63b431 smsc95xx.macaddr=B8:27:EB:63:B4:31 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939068K/966656K available (6348K kernel code, 432K rwdata, 1716K rodata, 476K init, 764K bss, 19396K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807e8584 (8066 kB)
.init : 0x807e9000 - 0x80860000 ( 476 kB)
.data : 0x80860000 - 0x808cc290 ( 433 kB)
.bss : 0x808cf000 - 0x8098e1ec ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000025] Switching to timer-based delay loop, resolution 52ns
[ 0.000295] Console: colour dummy device 80x30
[ 0.000496] console [tty1] enabled
[ 0.000526] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000547] pid_max: default: 32768 minimum: 301
[ 0.000863] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000879] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001801] Disabling cpuset control group subsystem
[ 0.001832] Initializing cgroup subsys io
[ 0.001861] Initializing cgroup subsys memory
[ 0.001904] Initializing cgroup subsys devices
[ 0.001925] Initializing cgroup subsys freezer
[ 0.001945] Initializing cgroup subsys net_cls
[ 0.001994] CPU: Testing write buffer coherency: ok
[ 0.002062] ftrace: allocating 21225 entries in 63 pages
[ 0.051784] CPU0: update cpu_capacity 1024
[ 0.051815] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.051827] [bcm2709_smp_prepare_cpus] enter
[ 0.051976] Setting up static identity map for 0x8240 - 0x8274
[ 0.053597] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.053785] [bcm2709_secondary_init] enter cpu:1
[ 0.053827] CPU1: update cpu_capacity 1024
[ 0.053834] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.054210] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.054375] [bcm2709_secondary_init] enter cpu:2
[ 0.054395] CPU2: update cpu_capacity 1024
[ 0.054401] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.054773] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.054902] [bcm2709_secondary_init] enter cpu:3
[ 0.054923] CPU3: update cpu_capacity 1024
[ 0.054929] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.054989] Brought up 4 CPUs
[ 0.055012] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.055020] CPU: All CPU(s) started in HYP mode.
[ 0.055028] CPU: Virtualization extensions available.
[ 0.055647] devtmpfs: initialized
[ 0.067249] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.067576] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.068286] pinctrl core: initialized pinctrl subsystem
[ 0.068799] NET: Registered protocol family 16
[ 0.074046] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081856] bcm2709: Mini UART enabled
[ 0.081901] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.081912] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.082076] Serial: AMBA PL011 UART driver
[ 0.082218] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.082380] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.153900] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.154446] SCSI subsystem initialized
[ 0.154613] usbcore: registered new interface driver usbfs
[ 0.154693] usbcore: registered new interface driver hub
[ 0.154785] usbcore: registered new device driver usb
[ 0.161344] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-10-20 14:57
[ 0.188541] clocksource: Switched to clocksource arch_sys_counter
[ 0.233773] FS-Cache: Loaded
[ 0.234054] CacheFiles: Loaded
[ 0.246294] NET: Registered protocol family 2
[ 0.247150] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.247265] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.247454] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.247545] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.247591] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.247819] NET: Registered protocol family 1
[ 0.248150] RPC: Registered named UNIX socket transport module.
[ 0.248161] RPC: Registered udp transport module.
[ 0.248169] RPC: Registered tcp transport module.
[ 0.248178] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.249352] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.250712] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.264041] VFS: Disk quotas dquot_6.6.0
[ 0.264308] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.266516] FS-Cache: Netfs 'nfs' registered for caching
[ 0.267417] NFS: Registering the id_resolver key type
[ 0.267478] Key type id_resolver registered
[ 0.267487] Key type id_legacy registered
[ 0.269864] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.269992] io scheduler noop registered
[ 0.270013] io scheduler deadline registered (default)
[ 0.270068] io scheduler cfq registered
[ 0.272621] BCM2708FB: allocated DMA memory fac00000
[ 0.272647] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.295123] Console: switching to colour frame buffer device 128x48
[ 0.307915] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.308968] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 59, base_baud = 31250000) is a 16550
[ 1.209926] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.210119] vc-cma: Videocore CMA driver
[ 1.210130] vc-cma: vc_cma_base = 0x00000000
[ 1.210140] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.210149] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.210416] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.225270] brd: module loaded
[ 1.233888] loop: module loaded
[ 1.234803] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.236271] Loading iSCSI transport class v2.0-870.
[ 1.236922] usbcore: registered new interface driver smsc95xx
[ 1.236974] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.437223] Core Release: 2.80a
[ 1.437235] Setting default values for core params
[ 1.437269] Finished setting default values for core params
[ 1.637645] Using Buffer DMA mode
[ 1.637655] Periodic Transfer Interrupt Enhancement - disabled
[ 1.637664] Multiprocessor Interrupt Enhancement - disabled
[ 1.637674] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.637688] Dedicated Tx FIFOs mode
[ 1.638032] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 1.638062] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.638085] dwc_otg: Microframe scheduler enabled
[ 1.638135] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x804476e0
[ 1.638149] WARN::hcd_init_fiq:414: FIQ ASM at 0x80447a50 length 36
[ 1.638164] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbbb9c000
[ 1.638230] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.638267] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.638304] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.638353] Init: Port Power? op_state=1
[ 1.638361] Init: Power Port (0)
[ 1.638593] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.638609] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.638621] usb usb1: Product: DWC OTG Controller
[ 1.638633] usb usb1: Manufacturer: Linux 4.4.26-v7+ dwc_otg_hcd
[ 1.638645] usb usb1: SerialNumber: 3f980000.usb
[ 1.639438] hub 1-0:1.0: USB hub found
[ 1.639481] hub 1-0:1.0: 1 port detected
[ 1.640079] dwc_otg: FIQ enabled
[ 1.640088] dwc_otg: NAK holdoff enabled
[ 1.640096] dwc_otg: FIQ split-transaction FSM enabled
[ 1.640128] Module dwc_common_port init
[ 1.640350] usbcore: registered new interface driver usb-storage
[ 1.640597] mousedev: PS/2 mouse device common for all mice
[ 1.641315] bcm2835-cpufreq: min=600000 max=1200000
[ 1.641591] sdhci: Secure Digital Host Controller Interface driver
[ 1.641601] sdhci: Copyright(c) Pierre Ossman
[ 1.641934] sdhost: log_buf @ bac13000 (fac13000)
[ 1.698571] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.700841] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.700855] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.755402] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.757247] mmc0: new high speed SDHC card at address 0001
[ 1.757809] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 1.758686] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.759147] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.759176] mmcblk0: p1 p2
[ 1.759284] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.759483] usbcore: registered new interface driver usbhid
[ 1.759492] usbhid: USB HID core driver
[ 1.760055] Initializing XFRM netlink socket
[ 1.760093] NET: Registered protocol family 17
[ 1.760231] Key type dns_resolver registered
[ 1.760818] Registering SWP/SWPB emulation handler
[ 1.761617] registered taskstats version 1
[ 1.761815] vc-sm: Videocore shared memory driver
[ 1.761831] [vc_sm_connected_init]: start
[ 1.764376] [vc_sm_connected_init]: end - returning 0
[ 1.767607] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.768023] of_cfs_init
[ 1.768104] of_cfs_init: OK
[ 1.777277] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.778930] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.780486] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.783260] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.787493] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.787540] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.795204] devtmpfs: mounted
[ 1.795950] Freeing unused kernel memory: 476K (807e9000 - 80860000)
[ 1.838674] Indeed it is in host mode hprt0 = 00021501
[ 1.873954] mmc1: new high speed SDIO card at address 0001
[ 2.018582] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.018723] Indeed it is in host mode hprt0 = 00001101
[ 2.041180] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 2.080508] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.080909] systemd[1]: Detected architecture 'arm'.
[ 2.180011] NET: Registered protocol family 10
[ 2.181452] systemd[1]: Inserted module 'ipv6'
[ 2.183249] systemd[1]: Set hostname to <raspberrypi>.
[ 2.218869] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.218889] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.219686] hub 1-1:1.0: USB hub found
[ 2.219782] hub 1-1:1.0: 5 ports detected
[ 2.315955] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 56 bits of entropy available)
[ 2.387617] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.388988] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[ 2.390500] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[ 2.404835] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 2.405643] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 2.405835] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 2.437860] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 2.440512] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 2.498602] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.542251] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.542601] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.542680] systemd[1]: Starting Remote File Systems (Pre).
[ 2.542831] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.542974] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 2.543424] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.543506] systemd[1]: Starting Encrypted Volumes.
[ 2.543576] systemd[1]: Reached target Encrypted Volumes.
[ 2.543659] systemd[1]: Starting Swap.
[ 2.543726] systemd[1]: Reached target Swap.
[ 2.543797] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 2.543876] systemd[1]: Starting Root Slice.
[ 2.544020] systemd[1]: Created slice Root Slice.
[ 2.544091] systemd[1]: Starting User and Session Slice.
[ 2.544313] systemd[1]: Created slice User and Session Slice.
[ 2.544384] systemd[1]: Starting Delayed Shutdown Socket.
[ 2.544548] systemd[1]: Listening on Delayed Shutdown Socket.
[ 2.544619] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 2.544804] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.544877] systemd[1]: Starting Journal Socket (/dev/log).
[ 2.545062] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.545153] systemd[1]: Starting udev Control Socket.
[ 2.545303] systemd[1]: Listening on udev Control Socket.
[ 2.545387] systemd[1]: Starting udev Kernel Socket.
[ 2.545507] systemd[1]: Listening on udev Kernel Socket.
[ 2.545595] systemd[1]: Starting Journal Socket.
[ 2.545827] systemd[1]: Listening on Journal Socket.
[ 2.545951] systemd[1]: Starting System Slice.
[ 2.546167] systemd[1]: Created slice System Slice.
[ 2.546283] systemd[1]: Starting File System Check on Root Device...
[ 2.579267] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 2.579668] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.579794] systemd[1]: Starting system-autologin.slice.
[ 2.580068] systemd[1]: Created slice system-autologin.slice.
[ 2.580266] systemd[1]: Starting Increase datagram queue length...
[ 2.582975] systemd[1]: Starting Restore / save the current clock...
[ 2.590639] systemd[1]: Mounted Huge Pages File System.
[ 2.590781] systemd[1]: Starting udev Coldplug all Devices...
[ 2.593859] systemd[1]: Mounting Debug File System...
[ 2.599948] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.599970] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.603214] smsc95xx v1.0.4
[ 2.624371] systemd[1]: Started Set Up Additional Binary Formats.
[ 2.624817] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 2.630297] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.662191] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:63:b4:31
[ 2.673810] systemd[1]: Starting Load Kernel Modules...
[ 2.676754] systemd[1]: Starting Slices.
[ 2.676916] systemd[1]: Reached target Slices.
[ 2.683916] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 2.717539] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.717856] systemd[1]: Mounted Debug File System.
[ 2.720330] systemd[1]: Started Increase datagram queue length.
[ 2.730855] fuse init (API version 7.23)
[ 2.746652] systemd[1]: Started udev Coldplug all Devices.
[ 2.767976] i2c /dev entries driver
[ 2.776056] systemd[1]: Started Load Kernel Modules.
[ 2.798459] systemd[1]: Started Restore / save the current clock.
[ 2.815000] systemd[1]: Time has been changed
[ 2.859730] systemd[1]: Mounting FUSE Control File System...
[ 2.899467] systemd[1]: Mounting Configuration File System...
[ 2.901756] systemd[1]: Starting Apply Kernel Variables...
[ 2.904890] systemd[1]: Starting Syslog Socket.
[ 2.905271] systemd[1]: Listening on Syslog Socket.
[ 2.905423] systemd[1]: Starting Journal Service...
[ 2.908934] systemd[1]: Started Journal Service.
[ 3.078973] systemd-udevd[138]: starting version 215
[ 3.684796] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.613254] spi spi0.2: setup: only two native chip-selects are supported
[ 4.613284] spi-bcm2835 3f204000.spi: can't setup spi0.2, status -22
[ 4.613299] spi_master spi0: spi_device register error /soc/spi@7e204000/mcp2515@2
[ 4.613317] spi_master spi0: Failed to create SPI device for /soc/spi@7e204000/mcp2515@2
[ 4.614917] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.619537] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.648265] CAN device driver interface
[ 4.810966] usbcore: registered new interface driver brcmfmac
[ 4.945045] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[ 4.963818] random: nonblocking pool is initialized
[ 4.980097] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 5.018684] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 5.018713] cfg80211: World regulatory domain updated:
[ 5.018724] cfg80211: DFS Master region: unset
[ 5.018733] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 5.018748] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.018763] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.018775] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.018790] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 5.018807] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 5.018821] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 5.018833] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 5.018847] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 5.367285] systemd-journald[131]: Received request to flush runtime journal from PID 1
[ 6.437247] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 6.437262] brcmfmac: brcmf_add_if: ignore IF event
[ 6.441500] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.441536] brcmfmac: power management disabled
[ 6.606883] uart-pl011 3f201000.uart: no DMA platform data
[ 7.010649] cfg80211: Regulatory domain changed to country: GB
[ 7.010666] cfg80211: DFS Master region: ETSI
[ 7.010672] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.010680] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.010688] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.010696] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.010702] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[ 7.010708] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 7.339893] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.340084] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.802483] Adding 102396k swap on /var/swap. Priority:-1 extents:4 across:192508k SSFS
[ 8.878771] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.880623] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 11.205645] Bluetooth: Core ver 2.21
[ 11.205699] NET: Registered protocol family 31
[ 11.205705] Bluetooth: HCI device and connection manager initialized
[ 11.205721] Bluetooth: HCI socket layer initialized
[ 11.205731] Bluetooth: L2CAP socket layer initialized
[ 11.205754] Bluetooth: SCO socket layer initialized
[ 11.226951] Bluetooth: HCI UART driver ver 2.3
[ 11.226969] Bluetooth: HCI UART protocol H4 registered
[ 11.226974] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 11.227248] Bluetooth: HCI UART protocol BCM registered
[ 11.576341] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.576355] Bluetooth: BNEP filters: protocol multicast
[ 11.576370] Bluetooth: BNEP socket layer initialized
/dts-v1/;
/plugin/;
fragment@0 {
target = <&spi0>;
__overlay__ {
status = "okay";
fragment@1 {
fragment@2 {
target = <&gpio>;
__overlay__ {
brcm,pins = <25>;
fragment@3 {
__overlay__ {
#clock-cells = <0>;
fragment@4 {
target = <&spi0>;
spi: __overlay__ {
#size-cells = <0>;
cs-gpios = <&gpio 8 1>, <&gpio 7 1>, <&gpio 6 1>;
can2: mcp2515@2 {
reg = <2>;
__overrides__ {
cs2 = <&cs_pins>,"brcm,pins:8", <&spi>,"cs-gpios:28";
pi@raspberrypi:~ $ sudo ip link set up can0 type can bitrate 1000000;
RTNETLINK answers: Numerical argument out of domain
[ 5340.708426] mcp251x spi0.0 can0: bitrate error 16.6% too high
* Device tree overlay for mcp251x/can3 on spi0.3
/dts-v1/;
/plugin/;
/* disable spi-dev for spi0.3 */
fragment@0 {
target = <&spi0>;
__overlay__ {
status = "okay";
fragment@1 {
brcm,pins = <8 7 6 5>;
fragment@2 {
target = <&gpio>;
__overlay__ {
can3_pins: can3_pins {
brcm,pins = <25>;
fragment@3 {
__overlay__ {
/* external oscillator of mcp2515 on spi0.3 */
can3_osc: can3_osc {
#clock-cells = <0>;
fragment@4 {
target = <&spi0>;
spi: __overlay__ {
#size-cells = <0>;
cs-gpios = <&gpio 8 1>, <&gpio 7 1>, <&gpio 6 1>, <&gpio 5 1>;
can3: mcp2515@3 {
reg = <3>;
pinctrl-0 = <&can3_pins>;
clocks = <&can3_osc>;
__overrides__ {
oscillator = <&can3_osc>,"clock-frequency:0";
spimaxfrequency = <&can3>,"spi-max-frequency:0";
interrupt = <&can3_pins>,"brcm,pins:0",<&can3>,"interrupts:0";
cs3 = <&cs_pins>,"brcm,pins:12", <&spi>,"cs-gpios:40";
cs-gpios = <0>, <0>, <0>, <&gpio 5 1>;
cs3 = <&cs_pins>,"brcm,pins:12", <&spi>,"cs-gpios:16";
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f60000 s22592 r8192 d22464 u53248
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2709.boardrev=0xa02082 bcm2709.serial=0x7a63b431 smsc95xx.macaddr=B8:27:EB:63:B4:31 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Memory: 939064K/966656K available (6348K kernel code, 432K rwdata, 1716K rodata, 476K init, 764K bss, 19400K reserved, 8192K cma-reserved)
[ 0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000026] Switching to timer-based delay loop, resolution 52ns
[ 0.000300] Console: colour dummy device 80x30
[ 0.000503] console [tty1] enabled
[ 0.000535] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000556] pid_max: default: 32768 minimum: 301
[ 0.000868] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000883] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001808] Disabling cpuset control group subsystem
[ 0.001843] Initializing cgroup subsys io
[ 0.001874] Initializing cgroup subsys memory
[ 0.001916] Initializing cgroup subsys devices
[ 0.001937] Initializing cgroup subsys freezer
[ 0.001957] Initializing cgroup subsys net_cls
[ 0.002006] CPU: Testing write buffer coherency: ok
[ 0.002067] ftrace: allocating 21225 entries in 63 pages
[ 0.050521] CPU0: update cpu_capacity 1024
[ 0.050553] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.050565] [bcm2709_smp_prepare_cpus] enter
[ 0.050699] Setting up static identity map for 0x8240 - 0x8274
[ 0.052320] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.052508] [bcm2709_secondary_init] enter cpu:1
[ 0.052551] CPU1: update cpu_capacity 1024
[ 0.052557] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.052933] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.053097] [bcm2709_secondary_init] enter cpu:2
[ 0.053118] CPU2: update cpu_capacity 1024
[ 0.053124] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.053495] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.053625] [bcm2709_secondary_init] enter cpu:3
[ 0.053645] CPU3: update cpu_capacity 1024
[ 0.053651] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.053711] Brought up 4 CPUs
[ 0.053735] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.053743] CPU: All CPU(s) started in HYP mode.
[ 0.053751] CPU: Virtualization extensions available.
[ 0.054363] devtmpfs: initialized
[ 0.066224] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.066560] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.067269] pinctrl core: initialized pinctrl subsystem
[ 0.067783] NET: Registered protocol family 16
[ 0.073053] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081071] bcm2709: Mini UART enabled
[ 0.081116] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.081127] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.081290] Serial: AMBA PL011 UART driver
[ 0.081435] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.081603] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.152533] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.153094] SCSI subsystem initialized
[ 0.153256] usbcore: registered new interface driver usbfs
[ 0.153336] usbcore: registered new interface driver hub
[ 0.153431] usbcore: registered new device driver usb
[ 0.160050] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-10-20 14:57
[ 0.187285] clocksource: Switched to clocksource arch_sys_counter
[ 0.232550] FS-Cache: Loaded
[ 0.232827] CacheFiles: Loaded
[ 0.245070] NET: Registered protocol family 2
[ 0.245928] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.246042] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.246231] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.246323] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.246370] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.246598] NET: Registered protocol family 1
[ 0.246924] RPC: Registered named UNIX socket transport module.
[ 0.246934] RPC: Registered udp transport module.
[ 0.246943] RPC: Registered tcp transport module.
[ 0.246952] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.248153] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.249520] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.262862] VFS: Disk quotas dquot_6.6.0
[ 0.263136] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.265359] FS-Cache: Netfs 'nfs' registered for caching
[ 0.266269] NFS: Registering the id_resolver key type
[ 0.266310] Key type id_resolver registered
[ 0.266320] Key type id_legacy registered
[ 0.268699] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.268829] io scheduler noop registered
[ 0.268850] io scheduler deadline registered (default)
[ 0.268905] io scheduler cfq registered
[ 0.271472] BCM2708FB: allocated DMA memory fac00000
[ 0.271499] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.293995] Console: switching to colour frame buffer device 128x48
[ 0.306790] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.307819] console [ttyS0] disabled
[ 0.307861] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 59, base_baud = 31250000) is a 16550
[ 0.308383] console [ttyS0] enabled
[ 1.214380] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.214558] vc-cma: Videocore CMA driver
[ 1.214568] vc-cma: vc_cma_base = 0x00000000
[ 1.214578] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.214587] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.214824] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.229546] brd: module loaded
[ 1.238096] loop: module loaded
[ 1.239039] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.240500] Loading iSCSI transport class v2.0-870.
[ 1.241153] usbcore: registered new interface driver smsc95xx
[ 1.241204] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.441463] Core Release: 2.80a
[ 1.441481] Setting default values for core params
[ 1.441514] Finished setting default values for core params
[ 1.641890] Using Buffer DMA mode
[ 1.641901] Periodic Transfer Interrupt Enhancement - disabled
[ 1.641910] Multiprocessor Interrupt Enhancement - disabled
[ 1.641919] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.641934] Dedicated Tx FIFOs mode
[ 1.642229] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 1.642259] FIQ FSM acceleration enabled for :
[ 1.642283] dwc_otg: Microframe scheduler enabled
[ 1.642334] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x804476e0
[ 1.642349] WARN::hcd_init_fiq:414: FIQ ASM at 0x80447a50 length 36
[ 1.642364] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbbb9c000
[ 1.642428] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.642464] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.642498] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.642551] Init: Port Power? op_state=1
[ 1.642559] Init: Power Port (0)
[ 1.642759] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.642774] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.642787] usb usb1: Product: DWC OTG Controller
[ 1.642799] usb usb1: Manufacturer: Linux 4.4.26-v7+ dwc_otg_hcd
[ 1.642811] usb usb1: SerialNumber: 3f980000.usb
[ 1.643559] hub 1-0:1.0: USB hub found
[ 1.643602] hub 1-0:1.0: 1 port detected
[ 1.644154] dwc_otg: FIQ enabled
[ 1.644164] dwc_otg: NAK holdoff enabled
[ 1.644172] dwc_otg: FIQ split-transaction FSM enabled
[ 1.644211] Module dwc_common_port init
[ 1.644459] usbcore: registered new interface driver usb-storage
[ 1.644706] mousedev: PS/2 mouse device common for all mice
[ 1.645423] bcm2835-cpufreq: min=600000 max=1200000
[ 1.645694] sdhci: Secure Digital Host Controller Interface driver
[ 1.645703] sdhci: Copyright(c) Pierre Ossman
[ 1.646012] sdhost: log_buf @ bac13000 (fac13000)
[ 1.697316] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.699587] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.699601] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.754122] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.755968] mmc0: new high speed SDHC card at address 0001
[ 1.756538] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 1.757437] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.757871] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.757893] mmcblk0: p1 p2
[ 1.758003] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.758214] usbcore: registered new interface driver usbhid
[ 1.758222] usbhid: USB HID core driver
[ 1.758787] Initializing XFRM netlink socket
[ 1.758823] NET: Registered protocol family 17
[ 1.758960] Key type dns_resolver registered
[ 1.759575] Registering SWP/SWPB emulation handler
[ 1.760381] registered taskstats version 1
[ 1.760549] vc-sm: Videocore shared memory driver
[ 1.760564] [vc_sm_connected_init]: start
[ 1.764100] [vc_sm_connected_init]: end - returning 0
[ 1.767414] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.767775] of_cfs_init
[ 1.767856] of_cfs_init: OK
[ 1.777057] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.778659] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.780257] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.783033] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.787610] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.787657] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.795313] devtmpfs: mounted
[ 1.796060] Freeing unused kernel memory: 476K (807e9000 - 80860000)
[ 1.837420] Indeed it is in host mode hprt0 = 00021501
[ 1.873691] mmc1: new high speed SDIO card at address 0001
[ 2.017326] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.017473] Indeed it is in host mode hprt0 = 00001101
[ 2.041165] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 2.079301] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.079698] systemd[1]: Detected architecture 'arm'.
[ 2.179357] NET: Registered protocol family 10
[ 2.180930] systemd[1]: Inserted module 'ipv6'
[ 2.182847] systemd[1]: Set hostname to <raspberrypi>.
[ 2.217644] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.217664] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.218514] hub 1-1:1.0: USB hub found
[ 2.218612] hub 1-1:1.0: 5 ports detected
[ 2.279385] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 51 bits of entropy available)
[ 2.361482] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 2.362847] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 2.364433] random: systemd: uninitialized urandom read (16 bytes read, 64 bits of entropy available)
[ 2.379362] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.380101] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.380269] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.410842] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[ 2.413456] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[ 2.507347] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.514001] systemd[1]: Expecting device dev-ttyS0.device...
[ 2.514301] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.514517] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.514594] systemd[1]: Starting Remote File Systems (Pre).
[ 2.514667] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.514815] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 2.515263] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.515347] systemd[1]: Starting Encrypted Volumes.
[ 2.515416] systemd[1]: Reached target Encrypted Volumes.
[ 2.515499] systemd[1]: Starting Swap.
[ 2.515567] systemd[1]: Reached target Swap.
[ 2.515639] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 2.515710] systemd[1]: Starting Root Slice.
[ 2.515849] systemd[1]: Created slice Root Slice.
[ 2.515918] systemd[1]: Starting User and Session Slice.
[ 2.516139] systemd[1]: Created slice User and Session Slice.
[ 2.516212] systemd[1]: Starting Delayed Shutdown Socket.
[ 2.516369] systemd[1]: Listening on Delayed Shutdown Socket.
[ 2.516439] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 2.516617] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.516688] systemd[1]: Starting Journal Socket (/dev/log).
[ 2.516860] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.516951] systemd[1]: Starting udev Control Socket.
[ 2.517107] systemd[1]: Listening on udev Control Socket.
[ 2.517193] systemd[1]: Starting udev Kernel Socket.
[ 2.517459] systemd[1]: Listening on udev Kernel Socket.
[ 2.517555] systemd[1]: Starting Journal Socket.
[ 2.517740] systemd[1]: Listening on Journal Socket.
[ 2.517874] systemd[1]: Starting System Slice.
[ 2.518091] systemd[1]: Created slice System Slice.
[ 2.518208] systemd[1]: Starting File System Check on Root Device...
[ 2.557892] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 2.558322] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.558437] systemd[1]: Starting system-autologin.slice.
[ 2.558725] systemd[1]: Created slice system-autologin.slice.
[ 2.558799] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 2.559062] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.559258] systemd[1]: Starting Increase datagram queue length...
[ 2.561863] systemd[1]: Starting Restore / save the current clock...
[ 2.568187] systemd[1]: Mounted Huge Pages File System.
[ 2.568327] systemd[1]: Starting udev Coldplug all Devices...
[ 2.571721] systemd[1]: Mounting Debug File System...
[ 2.580009] systemd[1]: Started Set Up Additional Binary Formats.
[ 2.580502] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 2.583526] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.608059] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.608082] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.610395] systemd[1]: Starting Load Kernel Modules...
[ 2.611768] smsc95xx v1.0.4
[ 2.613262] systemd[1]: Starting Slices.
[ 2.613391] systemd[1]: Reached target Slices.
[ 2.621236] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 2.658166] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.672389] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:63:b4:31
[ 2.697405] fuse init (API version 7.23)
[ 2.713401] systemd[1]: Started udev Coldplug all Devices.
[ 2.716106] systemd[1]: Started Increase datagram queue length.
[ 2.717215] systemd[1]: Mounted Debug File System.
[ 2.718165] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.734071] i2c /dev entries driver
[ 2.738256] systemd[1]: Started Load Kernel Modules.
[ 2.768505] systemd[1]: Started Restore / save the current clock.
[ 2.778813] systemd[1]: Time has been changed
[ 2.803084] systemd[1]: Started Create Static Device Nodes in /dev.
[ 2.832915] systemd[1]: Starting udev Kernel Device Manager...
[ 2.868085] systemd[1]: Mounting FUSE Control File System...
[ 2.871085] systemd[1]: Mounting Configuration File System...
[ 2.873713] systemd[1]: Starting Apply Kernel Variables...
[ 2.876598] systemd[1]: Starting Syslog Socket.
[ 2.876892] systemd[1]: Listening on Syslog Socket.
[ 2.877100] systemd[1]: Starting Journal Service...
[ 2.880757] systemd[1]: Started Journal Service.
[ 2.898392] systemd-udevd[129]: starting version 215
[ 3.564818] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.516700] spi spi0.2: setup: only two native chip-selects are supported
[ 4.516725] spi-bcm2835 3f204000.spi: can't setup spi0.2, status -22
[ 4.516739] spi_master spi0: spi_device register error /soc/spi@7e204000/mcp2515@2
[ 4.516756] spi_master spi0: Failed to create SPI device for /soc/spi@7e204000/mcp2515@2
[ 4.521463] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.529927] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.578309] CAN device driver interface
[ 4.725597] usbcore: registered new interface driver brcmfmac
[ 4.856890] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[ 4.868008] random: nonblocking pool is initialized
[ 4.879449] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 4.952911] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 4.952943] cfg80211: World regulatory domain updated:
[ 4.952953] cfg80211: DFS Master region: unset
[ 4.952962] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 4.952977] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.952989] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.953002] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.953017] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 4.953032] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 4.953045] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 4.953078] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.953103] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 5.206605] systemd-journald[133]: Received request to flush runtime journal from PID 1
[ 6.335864] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 6.335881] brcmfmac: brcmf_add_if: ignore IF event
[ 6.340134] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.340168] brcmfmac: power management disabled
[ 6.444890] uart-pl011 3f201000.uart: no DMA platform data
[ 6.883548] cfg80211: Regulatory domain changed to country: GB
[ 6.883566] cfg80211: DFS Master region: ETSI
[ 6.883572] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.883580] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.883588] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.883595] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.883602] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[ 6.883608] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 7.278778] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.279307] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.760019] Adding 102396k swap on /var/swap. Priority:-1 extents:4 across:192508k SSFS
[ 8.745482] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.747151] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 11.029766] Bluetooth: Core ver 2.21
[ 11.029823] NET: Registered protocol family 31
[ 11.029828] Bluetooth: HCI device and connection manager initialized
[ 11.029843] Bluetooth: HCI socket layer initialized
[ 11.029854] Bluetooth: L2CAP socket layer initialized
[ 11.029873] Bluetooth: SCO socket layer initialized
[ 11.039867] Bluetooth: HCI UART driver ver 2.3
[ 11.039883] Bluetooth: HCI UART protocol H4 registered
[ 11.039888] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 11.040007] Bluetooth: HCI UART protocol BCM registered
[ 11.197920] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.197935] Bluetooth: BNEP filters: protocol multicast
[ 11.197952] Bluetooth: BNEP socket layer initialized
000982.176: *** Restart logging
000983.416: Read command line from file 'cmdline.txt'
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
001234.695: Loading 'kernel7.img' to 0x8000 size 0x4088d8
001238.346: Kernel trailer DTOK property says yes
001238.360: Kernel trailer DDTK property says yes
001241.347: Loading 'bcm2710-rpi-3-b.dtb' to 0x4108d8 size 0x3e78
001322.720: dtparam: uart0_clkrate=48000000
001336.375: dtparam: spi=off
001344.400: dtparam: audio=on
001371.266: Loaded overlay 'mcp2515-can0'
001371.285: dtparam: oscillator=10000000
001372.060: dtparam: interrupt=25
001439.665: Loaded overlay 'mcp2515-can1'
001439.685: dtparam: oscillator=10000000
001440.462: dtparam: interrupt=24
001512.328: Loaded overlay 'mcp2515-can2'
001512.347: dtparam: oscillator=10000000
001513.147: dtparam: interrupt=23
001591.618: Loaded overlay 'mcp2515-can3'
001591.638: dtparam: oscillator=10000000
001592.438: dtparam: interrupt=22
001722.448: dtparam: arm_freq=1200000000
001769.315: dtparam: core_freq=250000000
001782.192: dtparam: cache_line_size=64
001806.543: Device tree loaded to 0x2effb600 (size 0x4996)
003471.322: vchiq_core: vchiq_init_state: slot_zero = 0xfac80000, is_master = 1
003480.603: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000010
target-path = "/__overrides__";
If you change the config to is2_arm=on I'm assuming it uses 18-21. How does one enable I2S on pins 28-31 rather than the default 18-21?PhilE wrote:I'm sorry, but that isn't possible. If you download the BCM2835 ARM Peripherals documentation from here and turn to pages 102-103 you will see a map of the alternate functions available on each GPIO pin. The I2S functions are labelled as PCM, and appear in two groups - 18-21 and 28-31. Later Models A and B use 28-31 brought out onto a separate header (P5), but the Pluses and Pi 2 use 18-21 for I2S, the other group being used for I2C and as GPIOs to control on-board devices.
So the declarations of pin usage in Device Tree has prevented you from making a configuration error. By not enabling I2S you would be able to use GPIO18, and vice-versa, but you can't have both. (I realise you may know this, but not all readers will.)
dtoverlay=i2s-gpio28-31
/dts-v1/;
/plugin/;
compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
fragment@0 {
brcm,pins = <8>;
fragment@1 {
target = <&spi0>;
cs-gpios = <&gpio 8 1>,;
status = "okay";
__overrides__ {
cs0_pin = <&frag0>,"brcm,pins:0",
<&frag1>,"cs-gpios:4";
dtc -@ -I dts -O dtb -o spi0-1cs.dtbo spi0-1cs-overlay.dts
/dts-v1/;
/plugin/;
fragment@0 {
target = <&spi0_pins>;
__overlay__ {
brcm,pins = <10 11>;
