I work for a small nonprofit that developed a Raspberry Pi kit and curriculum based on the Model B+. Our kit includes an SD card with slightly customized version of Raspbian from 2014 (we don't have the manpower to keep up with hardware/software updates as fast as they come out, so this is what I've got for now. Bear with me.). Recently we had two Pis returned to us, along with their respective SD cards, because customers claimed they wouldn't boot up - they would either hang on some error message or the screen would go blank.
Wanting to test this for myself, I assumed the customers just wound up with bad SD cards (which they may have caused themselves by improper shutdowns). I tested both Pis and cards and found what the customers did - the Pis would either start booting then the screen would go blank, or they would hang on some error message (more on those in a minute). So, to confirm that the problem is the cards, I stick them each in a third B+ that I already had in my office...and it boots up just fine. Weird.
So, maybe the problem is actually with the Pis somehow? I flash a new card with the latest Raspbian to try that...and both of the returned Pis boot up fine. So, nothing inherently wrong with them. Now I'm really confused. Time for more tests.
I have three different Pis (all Model B+ V1.2, 2014), two SD card images (our 2014 Raspbian image and the May 2016 Raspbian), and two different physical cards (a Kingston card from Amazon and one of the RPi-branded ones from SparkFun). That gives me twelve different boot combinations depending on which image I flash to which card. Everything else - USB keyboard, power supply, HDMI-DVI cable and monitor always remains the same. I ran through dozens of boots with all combinations and this is what I found:
- Pi #1 (the one I had in my office) always boots, regardless of the image or physical card
- Pis 2 and 3 (the ones that got returned) only boot with the latest Raspbian, regardless of the image or physical card
- Pis 2 and 3 give all sorts of crazy, inconsistent behavior when I try to boot them with the older Raspbian. A list of that behavior, as best as I could document it, is below.
So, at this point, I'm pretty stumped. I can't imagine why, given three supposedly identical models of the Pi, two of them would never successfully boot from an SD card that works fine with a third Pi. If the problem was the SD card itself I would have expected at least one failed boot on the good Pi, but nope. The only other guess I have is that the Pis come from different production runs/factories and maybe have slight variations in the firmware that are causing the errors with older Raspbian? I notice that the SoC on the Pi in my office says "SAMSUNG K4P4G324EQ-RGC2" whereas the returned Pis say "4DAI8 D9QHN" and "3UA78 D9QHN" respectively. Not sure if there's other identifying information on the Pis that could tell me when or where they were manufactured, or if that's a wild goose chase anyway since it shouldn't matter.
Here's a list of the behavior I saw when the Pis failed to boot:
- Starts to boot then screen goes blank, too fast for me to read the last line of text before it goes black
- I get crazy colored vertical stripes on the screen and it freezes
- Text stays on screen but gets distorted with crazy colored, flickering flecks everywhere on screen
- It freezes with the last line of text on the screen as one of the following (I tried googling many of these without much luck)
- [warn] Kernel lacks cgroups of memory controller not available, not starting cgroups … (warning). [27.636199] -- [end trace 7cff435ea161522a ]---
- [29.695409] Fixing recursive fault but reboot is needed! [ ok ] Starting enhanced syslogd: rsyslogd[….] Network Interface Plugging Daemon…skip eth0…done. [info] Initializing cgroups. [….] _
- Kernal panic - not syncing - fatal exception in interrupt
- Unable to handle kernel paging request at virtual address beecb140
- [28.577165] [<c03c22640>] (usbnet_get_link) from [<c0484998>] (dev_ethtool+0x17b4/0x1b84)
- INIT: entering runlevel: 2
- Segmentation fault (crazy yellow flecks on screen)
I know that was a long post...any help would be appreciated!
