I understand that USB/PXE boot is still being tested. Apparently these features are enabled by writing an OTP bit and pulling a GPIO pin.
Therefore, presumably we will need an SD card with a boot.txt config something along the lines of "program_enable_pxe=1" to initially enable PXE booting? Could someone enlighten me what that config is and which GPIO to pull so that I can see DHCP/PXE packets with wireshark?
Many thanks
