nardev
Any example how to design board for the rpi computing module
Thu Feb 05, 2015 3:40 am
Is there any example how to design a board around the module?
IMHO it would be great if somebody could produce the design with all possible ports so that in eagle i only delete what i don't need and position things where i need them.
It would speed up prototyping A LOT!
Others???
GadgetUK
Re: Any example how to design board for the rpi computing mo
Thu Feb 05, 2015 7:36 am
Take a look at the following from WirelessThings,
https://www.kickstarter.com/projects/wi ... makers-and
They've made their Eagle design files available so you can adapt it as required.
nardev
Thu Feb 05, 2015 9:50 am
GadgetUK wrote:Take a look at the following from WirelessThings,
sweet, thank you very much
Return to “Compute Module”
