guillaumekh
CM3+ availability
Fri May 17, 2019 2:51 pm
Raspberry Pi Trading's Approved Resellers in Europe RS & Farnell/Element14 are currently out-of-stock of most CM3+ references (CM3+/Lite, CM3+/8GB, CM3+/16GB, CM3+/32GB). This doesn't paint a complete picture since these huge companies have stocks in multiple locations around the world, but it seems supply is still quite constrained globally.
Can you share some info on how CM3+ production is ramping up and — ideally — when we can expect availability to improve ?
Best,
Guillaume
RaTTuS
Re: CM3+ availability
Fri May 17, 2019 2:56 pm
Available for backorder to lead times shown
Check Stock & Lead Times
More stock available week commencing 14/10/19
I don't think the foundation has any control over it
Covfefe
guillaumekh
Fri May 17, 2019 3:01 pm
RaTTuS wrote: I don't think the foundation has any control over it
That's correct if i understand the foundation's governance correctly.
However, I'm hoping someone from Raspberry Pi Trading Limited — which handles manufacturing if I'm not mistaken — can chip in.
RaTTuS
Fri May 17, 2019 3:05 pm
..... — can chip in.
pun intended ?
and it does seem a long time - 3mnth is usually backlog for chip production.... so maybe there has been a massive order somewhere down the line
Covfefe
guillaumekh
Fri May 17, 2019 3:13 pm
pun intended ?
ah, did not notice :lol:
A Farnell/Element14 representative told me over that the current 14/10/19 backorder delay on their EMEA website is a floating estimate because they have no restocking planned. This date will keep shifting further in the future every day until they have a restock planned.
It also means Farnell/Element14 has no restock planned before 14/10/19 — or further — as far as they let us know. :?
Fri May 17, 2019 3:46 pm
pun intended ?
Maybe placing an Order would give an idea of quantities required to either RS or Element14, unless you just need the odd 1 or 2 ?
Retired disgracefully.....
guillaumekh
Fri May 17, 2019 3:57 pm
fruitoftheloom wrote: Maybe placing an Order would give an idea of quantities required to either RS or Element14, unless you just need the odd 1 or 2 ?
Isn't it easier to just call them ? :) I've directly reached out to Farnell Europe and they've reported that, for the 32GB CM3+ which I inquired about :
- they are currently out-of-stock
- they will receive 4000 units in early June which are all already booked by customers
- they currently have no planned restock
Availability might differ slightly for other references (8GB, 16GB, Lite) based on distributor (RS, Farnell), and geographical situation, but it seems there's a pattern of general low availability for all CM3+ references right now.
6by9
Fri May 17, 2019 4:31 pm
https://www.raspberrypi.org/forums/view ... 9#p1462310
(Mike does all the coordination with RS and Farnell).
guillaumekh
Fri May 17, 2019 4:33 pm
6by9 wrote: https://www.raspberrypi.org/forums/view ... 9#p1462310
Ah, sorry i missed that post. Thanks!
Return to “Compute Module”
