CM3+ with 7" display on DSI0
Posted: Tue Apr 30, 2019 12:11 pm
by sworteu
Hi readers,
We have a customised CM3+ board which uses DSI0 (display port) to use the official raspberry pi 7" display.
The i2c connections are made for the display GPIO0 = SCL0 and GPIO1 = SDA0.
The dsi0 is connected using the flatcable to the 7" official display driver board.
The driver board is powered with a 5v and gnd connection to our main power (5v).
When power is applied to the board, the CM3+ and the display are fed power but the display won't turn on.
When connecting the display to a RPI 3B+ the display magically works.
Some important questions we would like to have confirmed about this:
- Is it true that DSI0 is not enabled by defaut? We tried to change the dt-blob to DSI "0" but that didn't seem to work.
- Which is the default I2C port (and which pins) that are used for the default display on a CM3+ ?
We'd like to use the DEFAULT display port and I2C (an others if any required) that come with the Raspbian OS if anyone can shed some light on what those are as it doesn't seem to be documented well for the Compute Module (3+).
Thanks.
Re: CM3+ with 7" display on DSI0
Posted: Tue Apr 30, 2019 1:43 pm
by 6by9
On the CM neither DSI port is enabled by default. The display requires I2C to function, and all resources are left for the user to assign as they see fit.
sworteu wrote:- Which is the default I2C port (and which pins) that are used for the default display on a CM3+ ?
There isn't one. See above.
Documentation for configuring the display for a CM is at https://www.raspberrypi.org/documentati ... display.md.
It looks like the dt-blob and notes should be updated to add the section
            pin_define@DISPLAY_DSI_PORT {
               type="internal";
               number=<1>;
to denote DSI1 as the default. You can set it to 0 to select DSI0 if you should so wish.
Posted: Wed May 01, 2019 8:35 am
by sworteu
Hi 6by9,
Thanks for your fast response.
So i've tested this, but it doesn't seem to work for me somehow.
This is my dt-blob.dts (i've compiled to be dt-blob.bin) part for the cm3 pins:
(i've left out the videocore stuff and other boards)
pins_cm3 { // Pi 3 CM3
         pin_config {
            pin@default {
               polarity = "active_high";
               termination = "pull_down";
               startup_state = "inactive";
               function = "input";
            }; // pin
            pin@p4  { function = "output"; termination = "no_pulling"; polarity = "active_low"; }; // CTMR POWER DOWN
            pin@p5  { function = "input"; termination = ""; polarity = ""; }; // CTMR TEMP SENSOR (1-wire)
            pin@p14 { function = "uart0";  termination = "no_pulling"; drive_strength_mA = < 8 >; }; // TX uart0
            pin@p15 { function = "uart0";  termination = "pull_up"; drive_strength_mA = < 8 >; }; // RX uart0
            pin@p46 { function = "input";   termination = "pull_up";    }; // SMPS_SCL
            pin@p47 { function = "input";   termination = "pull_up";    }; // SMPS_SDA
            pin@p48 { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD CLK
            pin@p49 { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD CMD
            pin@p50 { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D0
            pin@p51 { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D1
            pin@p52 { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D2
            pin@p53 { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D3
            pin@p128 { function = "input";  termination = "no_pulling"; polarity = "active_low"; }; // Hotplug
            pin@p129 { function = "output"; termination = "no_pulling"; polarity = "active_low"; }; // EMMC_ENABLE_N
         }; // pin_config
         pin_defines {
            pin_define@HDMI_CONTROL_ATTACHED {
               type = "external";
               number = <0>;
            pin_define@EMMC_ENABLE {
               type = "external";
               number = <1>;
            pin_define@NUM_CAMERAS {
               type = "internal";
               number = <0>;
            pin_define@POWER_LOW {
               type = "absent";
            pin_define@LEDS_DISK_ACTIVITY {
               type = "absent";
            pin_define@LAN_RUN {
               type = "absent";
            pin_define@SMPS_SDA {
               type = "internal";
               number = <46>;
            pin_define@SMPS_SCL {
               type = "internal";
               number = <47>;
            pin_define@ETH_CLK {
               type = "absent";
            pin_define@WL_LPO_CLK {
               type = "absent";
            pin_define@USB_LIMIT_1A2 {
               type = "absent";
            pin_define@SIO_1V8_SEL {
               type = "absent";
            pin_define@PWML {
               type = "absent";
            pin_define@PWMR {
               type = "absent";
            pin_define@SAFE_MODE {
               type = "absent";
            pin_define@SD_CARD_DETECT {
               type = "absent";
            pin_define@ID_SDA {
               type = "absent";
            pin_define@ID_SCL {
               type = "absent";
            pin_define@DISPLAY_SDA {
               type = "internal";
               number = <0>;
            pin_define@DISPLAY_SCL {
               type = "internal";
               number = <1>;
            pin_define@DISPLAY_I2C_PORT {
               type="internal";
               number=<0>;
		type="internal";
		number=<0>;
         }; // pin_defines
      }; // pins
We use I2C pins 0 and 1 and DSI0 (display port 0). As in the dts above DISPLAY_DSI_PORT is set to <0> ...
Are the I2C pins set correctly ?
The dt-blob.bin seems to be the right one, but the compute module doesn't want to activate the display on display port 0.
I've programmed the compute module from the waveshare CM IO Board using HDMI, maybe that's the cause?
The /boot/config.txt has not been modified should we have some entries there?
Thanks.
Posted: Wed May 01, 2019 9:46 am
by 6by9
As long as they are present in the file you actually compiled, then that is fine.
         pin_config {
            pin@default {
               function = "input";
            }; // pin
         }; // pin_config
         pin_defines {
               type = "external";
               number = <0>;
               type = "external";
               number = <1>;
               type = "internal";
               number = <0>;
               type = "absent";
               type = "absent";
               type = "absent";
               type = "internal";
               number = <46>;
               type = "internal";
               number = <47>;
               type = "absent";
               type = "absent";
               type = "absent";
               type = "absent";
            pin_define@PWML {
               type = "absent";
            pin_define@PWMR {
               type = "absent";
               type = "absent";
               type = "absent";
            pin_define@ID_SDA {
               type = "absent";
            pin_define@ID_SCL {
               type = "absent";
               type = "internal";
               number = <0>;
               type = "internal";
               number = <1>;
               type="internal";
               number=<0>;
		type="internal";
		number=<0>;
         }; // pin_defines
      }; // pins
Your dt-blob.bin looks OK.
  • Use "vcgencmd get_config ignore_lcd" to confirm that the firmware has seen the I2C setup. It should be 0 (ie don't ignore).
  • Temporarily add "dtparam=i2c_vc=on" to config.txt to enable i2c-0 under Linux. "sudo i2cdetect -y 0" should detect all attached I2C peripheral addresses. The display should be on 0x38 and 0x45. If they aren't detected then look at your I2C wiring. (You may need to run "sudo modprobe i2c_dev" in order to provide userspace access to the I2C controllers.)
Posted: Wed May 01, 2019 12:53 pm
by sworteu
Hi 6by9,
- Use "vcgencmd get_config ignore_lcd" to confirm that the firmware has seen the I2C setup. It should be 0 (ie don't ignore).
-- Tried it was set to "1", so i added to /boot/config.txt "ignore_lcd=-0", then tested again and it showed "0" as expected.
- Temporarily add "dtparam=i2c_vc=on" to config.txt to enable i2c-0 under Linux. "sudo i2cdetect -y 0" should detect all attached I2C peripheral addresses. The display should be on 0x38 and 0x45. If they aren't detected then look at your I2C wiring. (You may need to run "sudo modprobe i2c_dev" in order to provide userspace access to the I2C controllers.)
-- i'm unable to do "sudo i2cdetect -y 0" as i've no USB, display, UART or anything to communicate with the CM3 from the board. It's designed to be compact and have minimal features.
-- it's connected in the hardware pcb to GPIO 0 and GPIO 1 (trough the DSI cable).
Could there be anything i'm missing?
for example the dt-blob.bin is added to /boot/config.txt using: "device-tree=dt-blob.bin" should that be correct?
i'm trying to confirm the issue is a faulty desing or wrong settings.
Posted: Wed May 01, 2019 1:23 pm
by 6by9
Your dt-blob.bin isn't being accepted then.
ignore_lcd is initialised to -1. If it finds a DISPLAY_SDA value defined via dt-blob.bin then it will be set to 0, otherwise 1.
Manually setting it in config.txt overrides that, but doesn't make the configuration valid.
sworteu wrote:- Temporarily add "dtparam=i2c_vc=on" to config.txt to enable i2c-0 under Linux. "sudo i2cdetect -y 0" should detect all attached I2C peripheral addresses. The display should be on 0x38 and 0x45. If they aren't detected then look at your I2C wiring. (You may need to run "sudo modprobe i2c_dev" in order to provide userspace access to the I2C controllers.)
You've rather backed yourself into a corner if you have no way of debugging. Tacking wires on to get to the serial console would be the easiest bet if GPIOs 14&15 aren't used for other things. Alternatively put the CM back into a CMIO board, connect GPIO0 to CD0_SDA and GPIO1 to CD0_SCL, and get it working with the display there where you can at least debug things.
sworteu wrote: for example the dt-blob.bin is added to /boot/config.txt using: "device-tree=dt-blob.bin" should that be correct?
NO!
device-tree= sets the Linux kernel device-tree file, and that is very different from dt-blob.bin. They both use the same syntax, but are very different in function.
The firmware will always look at dt-blob.bin and no other file.
Posted: Wed May 01, 2019 1:27 pm
by sworteu
Got i2c command tested trough a log, with this output:
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
It seems the i2c0 is not being added correctly perhaps in the dtblob?
Posted: Wed May 01, 2019 1:51 pm
by 6by9
Did you load i2c_dev? Either load it via modprobe, or add it to /etc/modules.
Posted: Wed May 01, 2019 2:28 pm
by sworteu
i've removed the manual override in config.txt and am now testing the last updates to the dt blob. It still doesn't work for now.
We're going to redisign this so we can ssh into the device. For now i'll log it and use the CMIO board to read it.
Also i don't currently have the display adapter CMDK for the board so i can't test it on the CMIO board untill i received it.
NO!
Ok i've removed the "device-tree=dt-blob.bin" from the config.txt still doesn't work...
I've done the command sudo modprobe i2c_dev
i'm not sure how to add it to /etc/modules ?
Posted: Wed May 01, 2019 2:44 pm
by 6by9
Stop and fix this first. You can do this solely with the CM in the CMIO, even without the display connected.
Until your dt-blob.bin results in ignore_lcd=0 you will be wasting your effort as the GPU won't start to look at probing the display.
Download the standard dt-blob.bin file from the documentation page and confirm that those give the intended result for ignore_lcd. Both DTS and BIN files are available at https://github.com/raspberrypi/document ... putemodule.
Post the output of "cat /proc/cpuinfo | grep Revision" if those don't work.
The contents of my /etc/modules file
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
i2c-dev
Or use raspi-config to enable i2c and it'll do that change for you.
Posted: Wed May 01, 2019 2:56 pm
by sworteu
i2c-dev
output of "cat /proc/cpuinfo | grep Revision"":
Revision : a02100
as it should be, a CM3+ (that's correct)
- my /etc/modules looks the same.
module i2c_dev is loaded
Posted: Thu May 02, 2019 10:18 am
by John Westlake
Might be a silly question, your not missing I2C pull-up resistors or some such on your PCB are you by anychance?
(I'm not sure if the panel has them on its interface PCB or not - but just wondering if you have a hardware issue that's causing you to chase your tail...
Posted: Thu May 02, 2019 10:32 am
by sworteu
The i2c ports seems to be connected wrong way round.
This issue will be in the fridge for now. Hardware related.
Thanks for your support all!
Posted: Thu May 02, 2019 1:52 pm
by John Westlake
Great you can move forward now - this is always the hardest stage of development when your not sure if your battling a hardware or software issue!
Posted: Fri May 03, 2019 11:26 am
by sworteu
Yes it is, we'll report when it's working so it may be helpfull to others.
Posted: Wed May 08, 2019 4:04 pm
by sworteu
We have it working. The device tree is functioning normally when set to display port 0 with i2c port 0 and sda scl on gpio 0 and 1.
We had the i2c hardware traces the wrong way round.
Thanks @6by9 @John Westlake
Posted: Mon Jun 03, 2019 2:47 pm
by sworteu
So i'm back here to inform everyone of another issue i had.
When using DISPLAY_DSI_PORT <0> the screen colors are "inverted" sometimes.
It seems the DSI PORT 0 is unstable. Testing on DSI PORT 1 i can't seem to get any issues.
The colors seem to be fine always.
So having these dt-blob parts (_cm3+ module):
pin_config {
pin@default {
function = "input";
}; // pin
pin@p4 { function = "output"; termination = "pull_up"; polarity = "active_high"; startup_state = "active"; };
pin@p5 { function = "input"; termination = "pull_up"; polarity = "active_low"; };
pin@p18 { function = "output"; termination = "pull_down"; polarity = "active_low"; startup_state = "active"; };
}; // pin_config
pin_defines {
type = "external";
number = <0>;
type = "external";
number = <1>;
type = "internal";
number = <0>;
type = "absent";
type = "absent";
type = "absent";
type = "internal";
number = <46>;
type = "internal";
number = <47>;
type = "absent";
type = "absent";
type = "absent";
type = "absent";
pin_define@PWML {
type = "absent";
pin_define@PWMR {
type = "absent";
type = "absent";
type = "absent";
pin_define@ID_SDA {
type = "absent";
pin_define@ID_SCL {
type = "absent";
type = "internal";
number = <0>;
type = "internal";
number = <1>;
type="internal";
number=<0>;
type = "internal";
number = <1>;
}; // pin_defines
}; // pins
is indeed having issues with the official 7" display. It looks like a timing issue or something.
The colors of the display seem to be flipped sometimes, and "may" become normal if the display was off/on switched.
It's very odd, but i should say use "DSI PORT 1" instead of "DSI PORT 0" when you can.
I think the raspberry pi foundation should try to track this down, as it could be a serious issue.
The setup is using startx with a custom gui program, working fine without problems when using DSI PORT 1 but having inverted colors "sometimes" (50% of the time probably) when using DSI PORT 0.
Or somebody can tell me why this could happen?
Posted: Mon Jun 03, 2019 2:51 pm
by jamesh
Odd. There's no real difference in the ports, and nothing like this has been previously reported (including time when the chip was used in other devices). Not sure what to suggest, if anything comes to mind will report back.
Posted: Mon Jun 03, 2019 3:03 pm
by sworteu
hi jamesh, please do so. It's very odd and we can't find how this happens. We'll move to display port 1 and keep that.
by 6by9
Please create an issue in the firmware issue tracker with details and a link back to here
I can't promise that we'll look at it immediately, but it's less likely to get lost than a report as one of (currently) 1.38million other posts on the forum.
Posted: Mon Jun 03, 2019 3:14 pm
by sworteu
Done
https://github.com/raspberrypi/firmware/issues/1149
